m1 |
m2 |
ρ |
θ |
Jahr |
Koordinaten (J2000.0) |
SIN128 |
AC |
7m.3 |
7m.6 |
2.6" |
193° |
1985 |
Aur |
06h01m14.73s / +31°32'28.10" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
Selbst bei hoher Vergrößerung keine Anzeichen für einen Doppelstern. Auch kam mir die Helligkeit geringer vor als angegeben!? |
STF825 |
AB |
7m.9 |
9m.1 |
8.0" |
146° |
2015 |
Aur |
06h01m37.21s / +36°30'55.70" |
Mark McCarthy
Fremont (California/USA) |
178mm (148x) |
Nice, easy wide Struve, white A and light yellow B, not quite delta mag |
BU16, 3 Mon |
5m.0 |
8m.0 |
1.9" |
355° |
1996 |
Mon |
06h01m50.42s / -10°35'52.60" |
Uwe Pilz
Leipzig (Germany) |
105mm (260x) |
schwache Aufhellung im ersten Ring |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
Begleiter schwach |
STF830 |
AB |
8m.9 |
9m.6 |
11.5" |
263° |
2015 |
Gem |
06h03m26.56s / +27°38'32.70" |
Mark McCarthy
178mm (205x) |
Dim pair for a Struve, slightly red color near equal stars, wide, part of a neat triangle with a slightly fainter star making the third (AC). Not physical |
AG104 |
9m.6 |
10m.2 |
2.5" |
81° |
2015 |
Aur |
06h03m34.99s / +35°49'53.00" |
Mark McCarthy
178mm (148x) |
Very fine split of 1 delta mag white stars, about 3" separation, but still striking and small at this magnification |
HDS824 |
8m.2 |
9m.2 |
2.3" |
149° |
2019 |
Ori |
06h03m48.13s / +18°15'53.30" |
Mark McCarthy
203mm (205x) |
Fine pair, yellow-orange A and white-yellow B, two delta mag |
J310 |
9m.8 |
10m.0 |
2.4" |
319° |
2015 |
Ori |
06h03m54.49s / +10°14'50.90" |
Mark McCarthy
203mm (205x) |
Beautiful matched orange pair, nicely split, very delicate. [surprisingly not a physical pair] |
J335 |
8m.4 |
9m.5 |
1.3" |
271° |
2015 |
Ori |
06h04m08.29s / +11°00'57.00" |
Mark McCarthy
203mm (205x) |
White A, B resolves with seeing, hairline split and two delta mag. Tough at this aperture |
STT128 & HU559 |
STT128 |
A-BC |
6m.4 |
9m.3 |
39.5" |
15° |
2019 |
Aur |
06h04m29.10s / +51°34'24.20" |
HU559 |
BC |
9m.6 |
10m.6 |
0.6" |
309° |
1999 |
René Merting
Drachhausen (Germany) |
15x56 |
STT128 (A-BC): ein gut getrenntes Paar, Komponente BC liegt nördlich von A und ist gerade so sichtbar - A ist reinweiß und BC ist … schwach |
HO228 |
7m.7 |
10m.2 |
2.4" |
267° |
2000 |
Ori |
06h06m00.88s / +12°28'45.60" |
Mark McCarthy
203mm (205x) |
Very fine indeed. A white and bright in comparison to B which is in A's glow but faint, resolved, ~2" and two delta mag |
STF840 |
A-BC |
7m.2 |
8m.9 |
21.5" |
248° |
2014 |
Ori |
06h06m28.04s / +10°45'01.00" |
BC |
9m.8 |
10m.1 |
0.4" |
126° |
1997 |
Mark McCarthy
203mm (205x) |
A-BC: White A and slightly blue B, wide, two delta mag. [Did not see BC, 0.4" near equal] |
Mark McCarthy
317mm (170x) |
A-BC: Wide blue-white and slightly red pair, 1 delta mag. |
Mark McCarthy
317mm (553x) |
BC: B maybe elongated? Not certain. |
MLB1065 |
AB |
8m.8 |
9m.1 |
10.1" |
238° |
2014 |
Aur |
06h07m03.10s / +41°45'41.30" |
Mark McCarthy
178mm (148x) |
White stars, B appears with averted vision, can't hold it direct, very well split. Physical |
STT131 |
7m.0 |
9m.4 |
1.5" |
277° |
2012 |
Aur |
06h07m25.84s / +36°16'28.70" |
Mark McCarthy
178mm (410x) |
It begins to resolve better with 300x, obvious with 410x with seeing. A is a greenish blue and B is very faint, 1", very close, an excellent pair |
Mark McCarthy
317mm (270x) |
Very close, need seeing to resolve 2 delta mag white A and light blue B |
STF851 |
8m.9 |
9m.5 |
2.9" |
34° |
2019 |
Ori |
06h08m04.43s / +03°17'23.70" |
Mark McCarthy
203mm (205x) |
Fine white nearly matched pair of white stars, very nice |
STT132 |
7m.2 |
9m.6 |
1.8" |
332° |
2012 |
Aur |
06h08m11.68s / +37°58'57.90" |
Mark McCarthy
317mm (270x) |
White A and slightly red B. Fine pair. 2 delta mag. |
STF844 & ARN64 |
STF844 |
AB |
8m.5 |
9m.3 |
23.4" |
10° |
2017 |
Ori |
06h08m18.38s / +13°59'50.30" |
ARN64 |
AC |
8m.5 |
10m.4 |
31.9" |
172° |
2017 |
René Merting
18x70 |
AB: Komponente B steht unmittelbar nordwestlich von A und ist deutlich schwächer AC: Komponente C ist schwächer als B und steht im SO von A, alle drei Sterne bilden eine Linie |
BU17 |
AB |
6m.9 |
9m.3 |
3.6" |
192° |
2019 |
Mon |
06h08m25.39s / -11°08'46.60" |
AC |
6m.9 |
10m.8 |
10.2" |
260° |
2015 |
BC |
9m.3 |
10m.8 |
9.3" |
276° |
1998 |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
Dreifachstern! (Burnham 17) |
STF848 |
AB |
7m.3 |
8m.2 |
2.6" |
110° |
2019 |
Ori |
06h08m30.36s / +13°58'15.80" |
AC |
7m.3 |
11m.7 |
18.1" |
296° |
2019 |
AD |
7m.3 |
8m.3 |
28.3" |
122° |
2019 |
AE |
7m.3 |
9m.0 |
42.6" |
188° |
2019 |
DH |
8m.3 |
10m.0 |
54.0" |
111° |
2019 |
René Merting
18x70 |
AD: Komponente D ist mit etwas Abstand östlich von Komponente A zu erkennen AE: Komponente E ist schwächer als D und steht südöstlich von A in doppeltem Abstand wie AD DH: Komponente H ist noch schwächer als D und steht östlich in dreifachem Abstand wie AD |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
AB: Deutlich getrennt mit ebenso deutlichem Helligkeitsunterschied. |
Christopher Hay
Seeheim (Germany) |
125mm (100x) |
AB: Beim beiläufigen Betrachten des “37 Cluster” NGC 2169 fiel mir auf, dass der hellste Stern in der 37, nämlich jener an der NW Ecke der Zahl 3, ein hübsch getrennter Doppel mit einem Hauch Schwarz zwischen den Komponenten ist. PA fügt sich gut in den oberen Strich der 3 ein. Stelledoppie gibt Komponenten für STF848 von A bis K, weist aber daraufhin, dass sie sämtlich entweder nicht physikalisch sind, oder ungewiß. Für mein Empfinden erscheint nur das Paar A-B Doppelstern-artig. |
Mark McCarthy
203mm (205x) |
AB: The "37" cluster. This pair is the star at the tip of the upper part of the three where it turns down to the center. Fine white pair, close but nicely split, two delta mag, busy field |
Mark McCarthy
317mm (170x) |
AB: Close bluish pair near the center of the open cluster NGC 2169 |
STF854 |
8m.8 |
9m.8 |
5.7" |
321° |
2019 |
Ori |
06h08m32.08s / +05°48'01.20" |
Mark McCarthy
203mm (205x) |
White stars, one delta mag, wide. In a pretty winter Milky Way field |
STF849 |
9m.2 |
9m.5 |
0.9" |
241° |
2015 |
Ori |
06h08m44.48s / +17°24'07.00" |
Mark McCarthy
203mm (205x) |
Snow man at this aperture and mag, near equal |
STT134 |
AB |
7m.5 |
9m.1 |
31.0" |
189° |
2015 |
Gem |
06h09m15.94s / +24°25'40.30" |
René Merting
100mm (32x) |
bei 32x zeigt sich südlich von A ein gut 1.5 Magnituden schwächerer Begleiter - ein ordentlich getrenntes Pärchen - im Umfeld nicht sehr auffällig (logisch bei einem Doppelstern in M 35) |
COU1101 |
10m.8 |
10m.8 |
0.9" |
167° |
2015 |
Gem |
06h09m35.99s / +26°29'49.10" |
Mark McCarthy
508mm (333x) |
Just split, white, half delta mag, in a nice field near some open clusters |
WEB5 |
7m.1 |
9m.2 |
43.8" |
216° |
2015 |
Aur |
06h09m39.64s / +43°08'26.70" |
René Merting
15x56 |
Komponente B zeicht sich ganz schwach südwestlich von A - ordentlich getrennt - A strahlt reinweiß, bei B bin ich froh, dass ich den Stern überhaupt erkennen kann |
STF869 |
8m.2 |
9m.1 |
24.5" |
280° |
2017 |
Mon |
06h10m44.34s / -09°51'08.30" |
René Merting
100mm (32x) |
bei 32x gut getrennt - Komponente B im Westen ist halb so hell wie A - dadurch leichter Farbkontrast, A weiß, B grauweiß - der Doppelstern ist auffallend, weil im Umfeld nicht viel los ist |
STF860 |
8m.6 |
9m.8 |
5.9" |
358° |
2018 |
Gem |
06h11m04.87s / +24°52'56.30" |
Mark McCarthy
508mm (333x) |
Blue-white A and slightly red B, wide, ~2 delta, nice |
STF845, 41 Aur |
6m.2 |
6m.9 |
7.6" |
357° |
2018 |
Aur |
06h11m36.59s / +48°42'39.60" |
Robert Zebahl
Leipzig (Germany) |
55mm (25x) |
Relativ dicht zusammen mit sichtbarem Helligkeitsunterschied. |
Mark McCarthy
178mm (148x) |
White stars, 1 delta mag, wide |
J2016, xi Ori |
AB |
4m.4 |
13m.0 |
37.8" |
187° |
2008 |
Ori |
06h11m56.40s / +14°12'31.60" |
Mark McCarthy
203mm (205x) |
Xi Ori. There are a few faint stars around the bright white A star, but certainly the closest is the B. Surprised I can see it given A's glare. [5 star system all faint & wide] |
AG107 |
9m.6 |
9m.8 |
1.5" |
179° |
2019 |
Gem |
06h12m49.60s / +24°25'36.20" |
Mark McCarthy
508mm (333x) |
Very nice white pair, near equal, ~1.5" nicely split |
HO22 |
8m.5 |
8m.6 |
1.0" |
211° |
2019 |
Ori |
06h13m27.53s / +10°14'52.40" |
Mark McCarthy
203mm (205x) |
Very fine hairline split, near equal. Nice! |
HO23 |
BC |
8m.0 |
11m.5 |
3.1" |
245° |
1991 |
Ori |
06h14m14.70s / +14°26'55.00" |
Mark McCarthy
508mm (333x) |
Excellent! BC is very delicate, very close to bright C, very faint and just appears with direct vision. Part of the widely separated S 509 AB |
STF865 |
8m.1 |
10m.3 |
5.2" |
69° |
2018 |
Aur |
06h14m22.32s / +51°09'59.30" |
Mark McCarthy
178mm (148x) |
Faint B emerges with seeing, widely separated from white a. Physical |
AG108 |
9m.5 |
9m.9 |
12.3" |
278° |
2015 |
Aur |
06h14m27.34s / +38°23'41.00" |
Mark McCarthy
178mm (148x) |
Wide near equal white stars |
KUI24 |
6m.3 |
7m.2 |
0.3" |
144° |
2014 |
Ori |
06h14m28.59s / +17°54'22.80" |
Mark McCarthy
508mm (667x) |
Bright white, olive shape is the best I can see. Physical with 260-year period, it will tighten to invisibility the next 15 years |
STF877 |
AB |
7m.5 |
8m.0 |
5.7" |
263° |
2019 |
Ori |
06h14m42.67s / +14°35'10.80" |
Robert Zebahl
Leipzig (Germany) |
70mm (44x) |
Schön getrennt, aber recht dicht zusammen. Kleiner Helligkeitsunterschied sichtbar. |
Mark McCarthy
203mm (205x) |
Near equal white, wide |
BU1008, eta Gem, 7 Gem, Propus |
3m.5 |
6m.2 |
1.7" |
255° |
2018 |
Gem |
06h14m52.69s / +22°30'24.60" |
Uwe Pilz
Leipzig (Germany) |
105mm (260x) |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
sehr schwierig |
Robert Zebahl
Leipzig (Germany) |
152mm (225x) |
Bereits bei 180x vergleichsweise einfach. Der schwache Begleiter ist als recht deutliche, leicht längliche, teils runde Aufhellung gut zu sehen. Ab 225x einfach und sofort auffällig, auch wenn die Beugungsringe der Hauptkomponente bedingt durch das Seeing nicht dauerhaft klar zu sehen sind. Die Hauptkomponente strahlte in einem hellen Orange. |
Mark McCarthy
203mm (333x) |
Propus. Yellow A and blue-yellow B, 2 delta mag, 1.5" very nice |
A2446 |
9m.0 |
11m.5 |
2.9" |
103° |
2007 |
Ori |
06h15m29.11s / +19°31'22.10" |
Mark McCarthy
203mm (205x) |
Can just keep faint B star with direct vision. It's quite faint, well away from A |
STF880 |
8m.4 |
8m.7 |
5.6" |
55° |
2019 |
Ori |
06h15m29.13s / +10°34'42.40" |
Mark McCarthy
203mm (205x) |
Nice near equal orange-white, well split |
STF872 |
AB |
6m.9 |
7m.4 |
11.4" |
216° |
2020 |
Aur |
06h15m39.06s / +36°08'55.30" |
Robert Zebahl
Leipzig (Germany) |
55mm (25x) |
Gut trennbar mit deutlichem Helligkeitsunterschied. |
Mark McCarthy
178mm (148x) |
White stars, wide, 1 delta or or less. Physical |
BU894 |
7m.3 |
11m.6 |
5.1" |
134° |
2015 |
Ori |
06h16m31.78s / +19°00'47.50" |
Mark McCarthy
508mm (333x) |
Bright white A, B just appears with direct vision, brightens with averted, wide. Discovered with the 18.5-inch at 5.1", no change |
J686 |
10m.5 |
10m.7 |
2.3" |
49° |
2015 |
Gem |
06h17m26.20s / +22°25'37.00" |
Mark McCarthy
203mm (333x) |
Very fine pair, near equal to half delta mag white stars, nicely separated but pleasingly close pair |
STF876 |
AB |
9m.2 |
11m.8 |
8.7" |
41° |
2014 |
Aur |
06h18m30.80s / +53°39'29.00" |
Mark McCarthy
178mm (148x) |
Wide B needs averted vision to see |
STF883 |
AB |
9m.3 |
9m.7 |
3.5" |
265° |
2019 |
Aur |
06h19m08.03s / +39°46'28.70" |
Mark McCarthy
178mm (148x) |
Very fine 2+1 all nearly in a line. The two closest white stars are near equal, about 3" separated, nice. Physical |
AG109 |
9m.4 |
9m.7 |
2.4" |
16° |
2019 |
Gem |
06h19m44.83s / +21°28'27.70" |
Mark McCarthy
203mm (333x) |
Very nice, half delta mag, nicely split white stars. Very good |
AG323 |
AB |
9m.0 |
10m.2 |
1.8" |
49° |
2015 |
Gem |
06h19m45.23s / +22°06'38.80" |
Mark McCarthy
203mm (333x) |
Wow! pops with seeing, 1 delta mag, ~2". Very nice. Two other stars much fainter on the outer reaches likely part of system [these are AC and AD] |
HU452 |
9m.5 |
10m.8 |
2.6" |
343° |
2001 |
Gem |
06h19m46.83s / +22°18'16.60" |
Mark McCarthy
508mm (333x) |
Light yellow orange and light blue stars, more than half delta mag, pretty wide [not physical] |
STF889 |
AB |
7m.6 |
9m.9 |
21.3" |
244° |
2015 |
Gem |
06h19m51.77s / +25°00'49.10" |
René Merting
18x70 |
mit etwas Konzentration sind beide Sterne getrennt zu erkennen - A und B sind halb so weit voneinander entfernt wie das nahe liegende Pärchen STTA74 - Komponente B im SW ist genauso schwach wie B bei STTA74, aber dadurch, dass er näher zum Hauptstern steht, ist er schwächer sichtbar |
René Merting
100mm (32x) |
bei 32x unscheinbarer als der 14' nordöstlich liegende STTA74 - die Komponenten von STF889 wirken beide schwächer als die von STTA74 - Komponente B im SW ist gerade so erkennbar, Helligkeitsunterschied mindestens 2 Größenklassen, B ist gut abgesetzt von A - Farbkontrast gelblich, B farblos |
TDS3753 |
11m.2 |
11m.4 |
0.9" |
78° |
1991 |
Gem |
06h20m30.31s / +25°05'21.40" |
Mark McCarthy
508mm (333x) |
Quite faint B star, very tough, ~1" and 1 delta mag |
STF884 |
8m.7 |
8m.9 |
8.9" |
272° |
2018 |
Aur |
06h20m33.58s / +47°07'13.00" |
Mark McCarthy
178mm (148x) |
Easy, wide, near equal, white |
STTA75 |
7m.7 |
8m.9 |
46.9" |
129° |
2019 |
Ori |
06h20m34.48s / +18°02'56.70" |
René Merting
18x70 |
ein mit ordentlichem Abstand getrenntes Sternpaar - B im SO ist halb so hell wie A |
STTA74 |
AB |
7m.1 |
8m.9 |
57.4" |
265° |
2015 |
Gem |
06h20m36.35s / +25°11'20.40" |
AC |
7m.1 |
12m.0 |
41.5" |
291° |
2015 |
René Merting
18x70 |
AB: westlich von Komponente A blinkt in ziemlich weitem Abstand die viel schwächere Komponente B hervor - A ist reinweiß, B wirkt grau |
René Merting
100mm (32x) |
AB: bei 32x weit getrennt - Komponente B im SW ist 1.5 Magnituden schwächer und wirkt farblos gegen die weiß strahlende Komponente A |
S513 |
AB |
7m.3 |
8m.9 |
59.4" |
258° |
2014 |
Gem |
06h21m14.48s / +21°07'56.70" |
AC |
7m.3 |
12m.0 |
47.1" |
251° |
2014 |
AD |
7m.3 |
7m.6 |
264.9" |
24° |
2015 |
AE |
7m.3 |
11m.3 |
83.5" |
285° |
2015 |
BE |
8m.9 |
11m.3 |
40.7" |
327° |
2015 |
BT |
8m.9 |
12m.2 |
37.8" |
295° |
2014 |
René Merting
18x70 |
AB: weit getrenntes Pärchen - Komponente B im Westen ist gut 1.5 Größenklassen schwächer und wirkt dadurch bräunlich ggü. der weiß schimmernden Komponente A |
René Merting
100mm (20x) |
AB: bei 32x popeleinfach, weit getrennt - Komponente B im Westen ist gut 1.5 Magnituden schwächer - zurück auf 20x nach wie vor sehr einfach, ein unauffälliger Doppelstern |
STF3116, FR CMa |
AB |
5m.5 |
9m.7 |
3.9" |
23° |
2003 |
Mon |
06h21m24.71s / -11°46'23.60" |
Uwe Pilz
Leipzig (Germany) |
105mm (130x) |
schwach, knapp außerhalb des ersten Rings, kein Problem |
Uwe Pilz
Leipzig (Germany) |
105mm (137x) |
einfach |
Uwe Pilz
Leipzig (Germany) |
105mm (198x) |
oberhalb ß Cma |
STF898 |
AB |
9m.0 |
9m.6 |
6.2" |
122° |
2018 |
Ori |
06h21m57.42s / +10°58'16.50" |
Mark McCarthy
203mm (205x) |
Equal pair, wide, may be part of triple, in nebulosity? [Is part of a triple, WAL 44 is AC, 9.00/11.28 26.5"] |
STF881, 4 Lyn |
AB |
6m.1 |
7m.7 |
0.6" |
149° |
2016 |
Lyn |
06h22m03.57s / +59°22'19.50" |
Frederik Wanink
Itterbeck (Germany) |
254mm (640x) |
schwierig wegen Helligkeitsunterschied |
OSB3 |
9m.8 |
11m.0 |
7.9" |
4° |
2015 |
Gem |
06h22m23.33s / +22°43'07.40" |
Mark McCarthy
508mm (333x) |
Extremely faint B, approximately 2 delta mag. B seen with averted vision only, well separated. It is a physical pair. W.H. Osborn, who has eight discoveries to his name, about whom I can't find any further information (I assume he is not the railroad tycoon in the Google search results) |
STF899 |
7m.4 |
8m.0 |
2.2" |
17° |
2019 |
Gem |
06h22m49.64s / +17°34'27.30" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
Getrennt, aber recht dicht zusammen bei sichtbarem Helligkeitsunterschied. |
Mark McCarthy
203mm (333x) |
Near equal, rather wide, one a little yellow the other light blue-white |
OL67 |
10m.9 |
11m.9 |
5.2" |
39° |
2015 |
Gem |
06h23m00.44s / +22°13'12.80" |
Mark McCarthy
203mm (333x) |
Averted vision only, wide, pops with seeing, just able to see it |
BU1059, mu Gem |
BC |
11m.5 |
12m.4 |
0.6" |
265° |
1944 |
Gem |
06h23m02.65s / +22°29'24.40" |
Mark McCarthy
508mm (333x) |
A-BC is the very bright orange A star Mu Gem, with several faint widely separated stars around, the brightest of which is BC. BC was quite faint, flashing a definite elongation but no separation with averted vision, significant delta mag. Discovered in 1889 36-inch at 0.8", it has narrowed since |
STF900, epsilon Mon, 8 Mon |
AB |
4m.4 |
6m.6 |
12.2" |
30° |
2019 |
Mon |
06h23m46.10s / +04°35'34.20" |
Robert Zebahl
Leipzig (Germany) |
55mm (42x) |
Relativ großer Abstand und deutlicher Helligkeitsunterschied. Die hellere Komponente wirkte weiß-gelblich, die Schwächere schien leicht grün-bläulich. Der Farbkontrast war allerdings nicht sonderlich auffällig. |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
Blau-rot |
A2356 |
8m.9 |
9m.0 |
0.8" |
263° |
2016 |
Aur |
06h24m59.81s / +42°32'45.90" |
Mark McCarthy
178mm (410x) |
I can tell is double with 148x, it appears as a near equal notched elongation. The notch gets stronger with each magnification jump, until 410x when it hairline splits at the best moments and best focus |
STT140 |
AB |
6m.9 |
10m.1 |
3.0" |
119° |
2012 |
Gem |
06h26m37.73s / +15°31'25.30" |
Mark McCarthy
203mm (333x) |
Nice 3 delta mag pair, wide, clean with seeing, bluish stars |
STF914 |
6m.3 |
9m.2 |
21.1" |
300° |
2019 |
Mon |
06h26m44.85s / -07°30'43.00" |
René Merting
18x70 |
ein ordentlich getrenntes Pärchen, wobei die Komponente B westnordwestlich von A nur knapp sichtbar ist - Helligkeitsunterschied mindestens 3, wenn nicht sogar 4 Größenklassen |
René Merting
100mm (20x) |
bei 32x kommen beide Sterne wie großer und kleiner Bruder daher - Komponente B im steht NW in guter Entfernung zu A - Komponente A ist strahlend weiß, B wirkt aufgrund des Helligkeitsunterschiedes farblos - zurück auf 20x ist B auch noch knapp zu erkennen und immernoch ordentlich getrennt von A |
AG112 |
AB |
9m.8 |
9m.9 |
2.8" |
209° |
2019 |
Gem |
06h27m30.03s / +24°32'00.80" |
Mark McCarthy
508mm (333x) |
Very pretty equal white, wide ~4". Not physical |
BRT2351 |
10m.3 |
10m.9 |
4.4" |
39° |
2010 |
Gem |
06h27m36.35s / +21°53'38.80" |
Mark McCarthy
508mm (333x) |
White, half delta mag, wide ~5", makes a wide equilateral triangle with two other stars. [not physical] |
SHJ70, 15 Gem |
AB |
6m.7 |
8m.2 |
24.7" |
203° |
2019 |
Gem |
06h27m46.58s / +20°47'22.60" |
AC |
6m.7 |
12m.7 |
85.6" |
35° |
2015 |
Robert Zebahl
Leipzig (Germany) |
16x70 |
AB: 22.02.2021: Klar getrennt mit deutlichem Helligkeitsunterschied. Zart orange mit deutlich schwächerem Begleiter. Zusammen mit Nu Gem & 16 Gem in einer schönen, gebogenen Sternkette. |
René Merting
18x70 |
AB: ein schönes enges Sternpaar, Komponente B ist SW ist ordentlich getrennt von A zu erkennen - etwas über eine Größenklasse Helligkeitsunterschied, dadurch leichter Farbkontrast |
Mark McCarthy
317mm (553x) |
AB: Very pretty orange A, with a brown B, ~1.5 delta mag. |
J1092 |
AB |
11m.6 |
12m.5 |
6.8" |
226° |
2016 |
Gem |
06h27m51.15s / +22°51'06.20" |
Mark McCarthy
508mm (333x) |
A bit faint, bluish, wide ~5", half delta mag |
beta Mon, 11 Mon |
STF919 |
AB |
4m.6 |
5m.0 |
7.1" |
133° |
2019 |
Mon |
06h28m49.07s / -07°01'59.00" |
STF919 |
AC |
4m.6 |
5m.4 |
9.9" |
126° |
2019 |
STF919 |
BC |
5m.0 |
5m.3 |
3.0" |
109° |
2019 |
BU570 |
AD |
4m.6 |
12m.1 |
26.5" |
56° |
2014 |
René Merting
18x70 |
das Mehrfachsystem ist als 8 erkennbar, eine extrem knappe Berührung, wobei die Komponenten B und C im SO nur als ein Stern gesehen werden können - BC ist gleich hell wie A allein |
René Merting
100mm (32x) |
A-BC: bei 32x ein wunderschöner eng stehender Doppelstern - die bei dieser Vergrößerung noch nicht trennbare Komponenten B und C im SO wirken leicht gelblich und ist leicht heller als A - die Komponenten A und BC wollen sich berühren, schaffen es aber nicht ;-) BC: bei 64x wirkt BC leicht länglich wie ein Stäbchen - bei 107x dann der Aha-Effekt, es sind zwei Sterne, knapp getrennt und mit gleichem Positionswinkel wie A-BC - beide Komponenten B und C sind gleich hell und einzeln jeweils etwa eine halbe Größenklasse schwächer als A im NW |
Uwe Pilz
Leipzig (Germany) |
105mm (137x) |
Dreifachsystem, drei fast gleichhelle Sterne. Alle blau-weiß |
STF905 |
AB |
8m.2 |
9m.9 |
1.7" |
130° |
2016 |
Aur |
06h28m53.76s / +40°07'11.10" |
Mark McCarthy
178mm (148x) |
Excellent, superfine pair, 2 delta mag and 2" sep |
STTA77, nu Gem, 18 Gem |
AB |
4m.1 |
8m.0 |
112.8" |
330° |
2015 |
Gem |
06h28m57.79s / +20°12'43.80" |
Christopher Hay
Seeheim (Germany) |
15x45 |
Fernglas mit interner Stabilisierung, handgehalten. AB weit auseinander. Große Helligkeitsdifferenz. A reinweiss, B eventuell bläulich. Ein physikalischer Doppelstern in 545 Lichtjahren Abstand zu uns. |
STF912 |
8m.8 |
10m.9 |
3.4" |
28° |
2017 |
Aur |
06h29m46.47s / +36°36'11.40" |
Mark McCarthy
178mm (148x) |
B star is quite faint but can see it with direct vision, 2 delta mag from white A, about 4-5", a very nice pair. Full moon and haze affecting faint stars |
STT141 |
AB |
7m.7 |
9m.8 |
2.3" |
144° |
2013 |
Gem |
06h30m01.34s / +17°54'23.80" |
Mark McCarthy
203mm (333x) |
Beautiful blue-white A star and 2 delta mag B, nice split, ~2.5" |
STF904 |
AB |
10m.3 |
11m.2 |
4.9" |
165° |
2015 |
Aur |
06h30m12.03s / +51°46'58.80" |
Mark McCarthy
178mm (148x) |
Faint B about 5" separation, a little more than 1 delta mag. Physical |
WEI12 |
8m.6 |
8m.7 |
8.6" |
66° |
2015 |
Gem |
06h31m08.66s / +21°43'06.00" |
Mark McCarthy
508mm (333x) |
Near equal white, wide, unremarkable |
STT143 & FOX147 |
STT143 |
AB |
6m.2 |
10m.1 |
7.9" |
103° |
2015 |
Gem |
06h31m09.99s / +16°56'19.00" |
FOX147 |
AC |
6m.2 |
11m.4 |
47.3" |
346° |
2015 |
Mark McCarthy
203mm (333x) |
STT143 (AB): Very pretty yellow-white A star with blue-white B, 3 delta mag., well split |
Mark McCarthy
317mm (553x) |
STT143 (AB): Orange A, very faint B, ~3", PA due east. 3rd to the north is FOX 147 |
Mark McCarthy
317mm (553x) |
FOX147 (AC): 3rd star in STT 143, to the north, faint and widely separated |
STF908 |
10m.7 |
10m.7 |
8.6" |
359° |
2019 |
Aur |
06h31m16.69s / +53°50'52.40" |
Mark McCarthy
178mm (148x) |
Faint but seen easily, near equal, wide |
STT519 |
8m.4 |
10m.9 |
8.4" |
78° |
2015 |
Gem |
06h31m17.74s / +15°44'14.40" |
Mark McCarthy
508mm (205x) |
Pretty 2 delta mag, wide, light yellow A and very light blue B. Physical |
FAB5 & STF926 |
FAB5 |
Aa-Ab |
7m.2 |
9m.6 |
0.9" |
18° |
1991 |
Mon |
06h31m40.54s / +05°46'08.80" |
STF926 |
AB |
7m.2 |
8m.6 |
10.8" |
287° |
2017 |
Mark McCarthy
317mm (170x) |
STF926 (AB): In a triangle of stars which points toward the Rosette Nebula. Blue-white A star and slightly red B, 1 delta mag, wide. The A star is FAB 5 |
Mark McCarthy
317mm (553x) |
FAB5 (Aa-Ab): Misshapen disk at best moments, very difficult |
TDS254 |
10m.6 |
10m.6 |
0.8" |
287° |
2016 |
Gem |
06h31m46.04s / +21°24'25.60" |
Mark McCarthy
508mm (333x) |
Just split, noticeable delta mag, yellow-white A star |
STF924, 20 Gem |
AB |
6m.3 |
6m.9 |
19.9" |
212° |
2019 |
Gem |
06h32m18.52s / +17°47'03.40" |
BC |
6m.9 |
13m.0 |
47.8" |
144° |
2014 |
Robert Zebahl
Leipzig (Germany) |
16x70 |
AB: 22.02.2021: Einfach trennbar bei geringem Helligkeitsunterschied. Auffälliger Doppelstern. Weiß-gelblich & weiß-bläulich. |
René Merting
18x70 |
AB: das dicht stehende Paar fällt sofort ins Auge - Komponente A im Norden ist vielleicht eine halbe Magnitude heller als Komponente B, die leicht gräulich strahlt |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
AB: Bei 22x hell, sofort auffällig, obwohl in vergleichsweise sternreicher Umgebung. Mäßiger, aber schöner Farbkontrast: helles Orange, dezentes Blau. Auch bei 44x sehr schöner Anblick. |
Robert Zebahl
Leipzig (Germany) |
152mm (69x) |
AB: Einfach, hell, mäßiger Helligkeitsunterschied. Schöner Farbkontrast: leicht orange, weiß-bläulich. |
STT145 |
7m.3 |
9m.9 |
1.5" |
338° |
1991 |
Gem |
06h32m20.69s / +15°42'22.30" |
Mark McCarthy
508mm (333x) |
Bright yellow-white B and very much fainter B, just outside of A's glare, ~1.5", 3 delta mag |
J1956 |
9m.5 |
9m.9 |
9.8" |
60° |
2015 |
Gem |
06h33m02.93s / +17°05'11.70" |
Mark McCarthy
203mm (333x) |
Faint but wide pair, blue color due to faintness, one more visible than other. Seems in a string of three [not physical] |
STF918 |
AB |
7m.3 |
8m.2 |
4.9" |
336° |
2019 |
Aur |
06h33m57.62s / +52°27'41.80" |
Robert Zebahl
Leipzig (Germany) |
55mm (40x) |
Bei 40x dicht zusammen, bei 55x gut trennbar mit deutlich schwächerem Begleiter. |
Mark McCarthy
178mm (148x) |
White stars, 1 delta mag, well split |
S524 |
AB |
7m.2 |
7m.4 |
53.0" |
244° |
2017 |
Gem |
06h34m07.10s / +22°07'27.20" |
René Merting
18x70 |
AB: popeleinfach mit dem FG - ein mehr als gut getrenntes Pärchen zweier gleich heller Sterne - die östliche Komponente wirkt ein klein wenig heller - A warmweiß, B blauweiß |
René Merting
100mm (20x) |
AB: bei 32x zeigen sich zwei annähernd gleichhelle Sterne weit getrennt voneinander - Komponente B im SW wirkt kühler als A AC: bei 32x ist südöstlich von A in doppeltem Abstand wie AB eine weitere Komponente erkennbar - C ist mindestens 2 Größenklassen schwächer als B - alle drei Sterne bilden ein schönes rechtwinkliges Dreieck, wobei die Ecke von A den rechten Winkel bildet - zurück auf 20x ist C auch noch knapp sichtbar |
STT147 |
AB |
6m.8 |
8m.7 |
42.7" |
74° |
2016 |
Aur |
06h34m19.37s / +38°04'33.60" |
A-CD |
6m.8 |
9m.8 |
44.5" |
119° |
2016 |
CD |
10m.6 |
11m.0 |
0.5" |
109° |
1957 |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
Robert Zebahl
Leipzig (Germany) |
152mm (69x) |
Bei 22x sind die Komponenten A,B und CD sofort auffällig, wobei A dominiert. Sie bilden ein schönes, spitzwinkliges Dreieck. Bei 69x sind auch Farbunterschiede erkennbar. A: dezent orangefarben; B: grau-bläulich; CD: Tendenz zu Orange. Lohnend, da auch die Doppelsterne STF 928 & STF 929 sowie der sehr auffällige Kohlenstoffstern UU Aur in unmittelbarer Nähe stehen und teils zusammen in einem Gesichtsfeld beobachtet werden können! |
STF932 |
8m.3 |
8m.5 |
1.6" |
305° |
2019 |
Gem |
06h34m21.57s / +14°45'08.30" |
Robert Zebahl
Leipzig (Germany) |
70mm (150x) |
Leider störte eine nahestehende Lampe bei der Beobachtung. Ich konnte den Stern zumindest ansatzweise länglich erkennen. |
Mark McCarthy
203mm (333x) |
Very neat near equal white stars, well split |
STF928 |
AB |
7m.9 |
8m.6 |
3.4" |
131° |
2019 |
Aur |
06h34m41.81s / +38°32'24.50" |
AC |
7m.9 |
12m.4 |
130.9" |
124° |
2002 |
BC |
8m.6 |
12m.4 |
127.3" |
124° |
2015 |
Robert Zebahl
Leipzig (Germany) |
102mm (62x) |
AB: Bei 28x erschien der Doppelstern bereits länglich, bei 62x wunderschön getrennt, wobei die Komponente A in einem warmen, dezenten Orange leuchtete. Bei 125x erschien A orangefarben, B grau-bläulich. |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
AB: kühl-weiß und lila |
Robert Zebahl
Leipzig (Germany) |
152mm (69x) |
AB: Klar getrennt, aber dicht zusammen. Mäßiger Helligkeitsunterschied. Schöner Anblick mit den nahestehenden Doppelsternen STT147 & STF 929 sowie dem Kohlenstoffstern UU Aur! |
Mark McCarthy
178mm (148x) |
AB: Classic Struve, very lightly yellow-white stars, about 1 delta, well separated |
J1093 |
9m.8 |
10m.5 |
1.3" |
4° |
1959 |
Gem |
06h34m43.85s / +26°05'20.70" |
Mark McCarthy
508mm (333x) |
Tough near equal pair, I have trouble to resolve the elongation which appears in all powers through 533x, but can tell this is double |
STF938, 14 Mon |
6m.5 |
10m.6 |
11.0" |
211° |
2012 |
Mon |
06h34m46.33s / +07°34'21.00" |
Mark McCarthy
317mm (170x) |
Bright A and very faint 4 delta mag B |
STF929 |
7m.3 |
8m.4 |
6.5" |
24° |
2016 |
Aur |
06h35m22.03s / +37°42'55.10" |
Robert Zebahl
Leipzig (Germany) |
152mm (69x) |
Einfach zu trennen, deutlicher Helligkeitsunterschied, leichter Farbkontrast. Hauptkomponente zeigte sich leicht orangefarben, die Farbe des Begleiters war nicht klar definierbar. Schöner Anblick mit den nahestehenden Doppelsternen STT147 & STF 928 sowie dem Kohlenstoffstern UU Aur! |
BU194 |
8m.6 |
8m.9 |
1.6" |
278° |
2019 |
Aur |
06h36m17.41s / +37°59'31.40" |
Mark McCarthy
178mm (148x) |
Very fine pair of near equal light orange stars, 1" separation very good |
SHJ73, nu 1 CMa |
5m.8 |
7m.4 |
17.4" |
265° |
2019 |
CMa |
06h36m22.85s / -18°39'35.60" |
Christopher Hay
Seeheim (Germany) |
10x56 |
Auf Stativ. Fein getrennt. Schönes 6,3° Gesichtsfeld mit Nü2 und Nü3. Ein physikalischer Doppelstern in 351 Lichtjahren Abstand zu uns. |
VDK1 |
AB |
10m.3 |
11m.4 |
3.0" |
43° |
2002 |
Gem |
06h36m29.25s / +26°43'39.50" |
Mark McCarthy
508mm (205x) |
Attractive pair, approximately 2 delta and 3", slightly light orange A, well split. Sadly not physical. One of three discoveries by J. Vanderdonck |
S529 |
AB |
6m.9 |
9m.3 |
52.7" |
130° |
2019 |
Gem |
06h37m33.90s / +12°10'50.00" |
AC |
6m.9 |
8m.1 |
143.5" |
165° |
2012 |
René Merting
18x70 |
AB: ein weit getrenntes Sternpaar - Komponente B im SO ist kupferbraun, die gut 2 bis 2.5 Größenklassen hellere Komponente A strahlt weiß |
STF942 |
10m.1 |
10m.1 |
3.5" |
246° |
2015 |
Gem |
06h37m40.87s / +23°38'54.20" |
Mark McCarthy
317mm (553x) |
Faint near equal brightness, well split |
STF943 |
AB |
9m.2 |
9m.4 |
31.1" |
135° |
2015 |
Gem |
06h37m47.00s / +23°10'36.00" |
Mark McCarthy
508mm (205x) |
Not sure why this one was picked out as a double, it's such a rich field any could be any such pair. Wide near equal white |
A2452 |
9m.3 |
9m.6 |
0.9" |
89° |
2015 |
Gem |
06h38m07.10s / +19°52'38.70" |
Mark McCarthy
508mm (333x) |
Fine near equal pair, well split but close |
STF922 |
AB |
7m.7 |
10m.8 |
10.5" |
137° |
2015 |
Cam |
06h38m18.76s / +64°44'06.00" |
AC |
7m.7 |
11m.2 |
24.4" |
9° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
16.04.2020: Die Komponente A wirkte leicht gelblich, die Komponenten B & C erschienen eher schwach. |
STF935 |
9m.2 |
9m.9 |
3.6" |
325° |
2019 |
Aur |
06h38m32.20s / +52°17'40.60" |
Mark McCarthy
178mm (148x) |
1 delta mag, about 5" separation, white stars |
STF941 |
AB |
7m.2 |
8m.2 |
2.0" |
83° |
2019 |
Aur |
06h38m40.76s / +41°34'53.40" |
AC |
7m.2 |
10m.5 |
83.9" |
135° |
2015 |
Robert Zebahl
Leipzig (Germany) |
102mm (28x) |
AC: Weit entfernter, schwacher Begleiter, der kaum auffällt. Vergrößerungen zwischen 28x und 125x verwendet. |
Robert Zebahl
Leipzig (Germany) |
102mm (86x) |
AB: Bei 62x nur als '8' sichtbar. Der Helligkeitsunterschied ist kaum wahrnehmbar. Bei 86x knapp getrennt, auffällig. Bei 125x deutlich getrennt, aber noch recht dicht zusammen bei moderatem Helligkeitsunterschied. |
Mark McCarthy
178mm (148x) |
AB: Wow, great pair. White A and light blue B, >1 delta mag and about 2", such a fine pair |
STF934 |
9m.8 |
10m.5 |
4.1" |
332° |
2015 |
Lyn |
06h39m06.40s / +55°02'30.20" |
Mark McCarthy
178mm (148x) |
Pretty faint for a Struve, 1 delta mag, wide about 4", white stars |
STT152, 54 Aur |
6m.2 |
7m.8 |
0.8" |
34° |
2016 |
Aur |
06h39m33.12s / +28°15'47.40" |
Frederik Wanink
254mm (640x) |
schwierig, Luftunruhe |
J353 |
9m.4 |
10m.3 |
4.1" |
65° |
2015 |
Gem |
06h39m57.85s / +16°21'39.20" |
Mark McCarthy
508mm (333x) |
White A and slightly red B, wide ~5", 2 delta mag |
STF925 |
8m.1 |
10m.5 |
3.5" |
93° |
2003 |
Cam |
06h40m10.00s / +67°19'24.50" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
16.04.2020: Bei 100x und 133x nicht getrennt. |
BRT1208 |
7m.9 |
10m.5 |
5.1" |
175° |
2015 |
Gem |
06h40m35.04s / +17°38'26.50" |
Mark McCarthy
508mm (333x) |
Easy wide pair, white A and a little red B, ~2 delta mag |
STF944 |
AB |
8m.4 |
10m.2 |
6.4" |
58° |
2018 |
Aur |
06h40m50.72s / +48°15'18.70" |
Mark McCarthy
178mm (148x) |
Slightly yellow-white stars, 2 delta, wide companion. Physical |
STF950, S Mon |
AB |
4m.7 |
7m.8 |
3.0" |
214° |
2018 |
Mon |
06h40m58.66s / +09°53'44.70" |
Mark McCarthy
178mm (205x) |
Lovely white and 3 delta mag fainter B, approximately 4". In NGC 2264, the Christmas Tree Cluster |
Mark McCarthy
317mm (170x) |
This is the brightest star, forming the trunk, of the Christmas Tree cluster, NGC 2264. Bright white and wide 4 delta mag B star, well separated. Spent some time at 71x to look at the cluster as a whole. |
STF949 |
9m.2 |
9m.7 |
3.6" |
289° |
2019 |
Mon |
06h41m00.18s / +05°42'26.70" |
Mark McCarthy
178mm (205x) |
Faint, well separated white stars with significant delta mag, almost 1 delta, about 5". Not physical |
STF953 |
7m.1 |
7m.7 |
7.3" |
330° |
2018 |
Mon |
06h41m09.41s / +08°59'05.00" |
Mark McCarthy
178mm (205x) |
Easy light yellow pair, 1 delta mag, wide. Near NGC 2264, the Christmas Tree Cluster |
STF954 |
AB |
7m.2 |
10m.2 |
12.9" |
153° |
2015 |
Mon |
06h41m09.60s / +09°27'57.50" |
Mark McCarthy
178mm (205x) |
Nice white A, widely separated faint B, about 3 delta mag. In NGC 2264, the Christmas Tree Cluster |
STF3117 |
9m.2 |
9m.8 |
0.9" |
77° |
2015 |
Mon |
06h41m22.05s / +09°43'51.60" |
Mark McCarthy
178mm (205x) |
Very fine, split with seeing, dull white stars, significant delta mag, very close 1" In NGC 2264, the Christmas Tree Cluster |
STF3118 |
AB |
9m.8 |
9m.9 |
2.8" |
174° |
2019 |
Mon |
06h41m30.09s / +09°49'48.50" |
Mark McCarthy
178mm (205x) |
Faint but easy pair, wide, approximately 3" separation, almost 1 delta mag. Not physical. In NGC 2264, the Christmas Tree Cluster |
KU27 |
10m.1 |
10m.4 |
6.9" |
187° |
2015 |
Gem |
06h42m11.50s / +14°51'29.50" |
Mark McCarthy
508mm (333x) |
Easy equal white, wide, in a rich field |
STF956 |
AB |
8m.0 |
10m.7 |
6.9" |
194° |
2015 |
Mon |
06h42m40.55s / +01°42'58.20" |
AC |
8m.0 |
8m.9 |
36.3" |
158° |
2015 |
AD |
8m.0 |
11m.1 |
56.4" |
181° |
2015 |
CD |
8m.9 |
11m.1 |
27.2" |
213° |
2015 |
René Merting
18x70 |
AC: leicht - Komponente C zeigt sich gut getrennt im Südwesten von A und ist mehr als eine Größenklasse schwächer |
Mark McCarthy
178mm (205x) |
AB: Faint B noticed with averted vision but can hold it with direct, a fine pair, A is in an arc of three similar magnitude stars. Not physical |
A2823 |
8m.0 |
10m.3 |
4.5" |
300° |
2015 |
Mon |
06h43m15.27s / +06°07'01.00" |
Mark McCarthy
178mm (205x) |
White A and much fainter B, can see just see it with direct vision, wide about 5" and 3 delta mag. It is sharper with seeing. Not physical |
A511 |
9m.6 |
10m.4 |
1.6" |
157° |
2016 |
Gem |
06h44m20.42s / +28°22'08.10" |
Mark McCarthy
508mm (205x) |
Wonderfully close pair, looks like the small snowman's head popped off the body, close split, 1 delta mag, white stars |
AG119 |
8m.9 |
9m.1 |
1.5" |
83° |
2015 |
Gem |
06h44m37.54s / +23°26'48.90" |
Mark McCarthy
508mm (333x) |
Fine near equal white, nicely split ~1.5". There's another pair on the edge of the field, wider and brighter |
STF946 |
7m.3 |
9m.1 |
4.0" |
129° |
2019 |
Lyn |
06h44m51.62s / +59°26'57.40" |
Robert Zebahl
Leipzig (Germany) |
102mm (86x) |
Einfach trennbar bei deutlichem Helligkeitsunterschied. Sehr schön zusammen mit dem Dreifachsystem STF 948 in einem Gesichtsfeld! |
Uwe Pilz
Leipzig (Germany) |
105mm (88x) |
im selben Feld mit 12 Lyn |
Robert Zebahl
Leipzig (Germany) |
152mm (100x) |
Bei 100x und 129x einfach zu trennen bei deutlichem Helligkeitsunterschied. Hauptkomponente erscheint leicht gelblich, die schwächere eher gräulich. Grandioser Anblick zusammen mit 12 Lyn (STF 948) in einem Gesichtsfeld! |
AGC1, 9 CMa, alpha CMa, Sirius |
AB |
-1m.5 |
8m.4 |
10.7" |
75° |
2016 |
CMa |
06h45m08.92s / -16°42'58.00" |
Uwe Pilz
Leipzig (Germany) |
105mm (198x) |
mit ADV, ohne nicht trennbar. Eindeutig |
Robert Zebahl
Leipzig (Germany) |
120mm (150x) |
02.03.2021: Vergrößerungen von 86x bis 200x unter Verwendung einen Baader-Gelbfilters benutzt. Das Beugungsscheibchen war relativ gut zu sehen, die Beugungsringe dagegen deutlich in Bewegung (Seeing 3/5). |
Jörg S. Schlimmer
Germany |
127mm (136x) |
Visuell nicht zu trennen, die Beugungsringe sind wesentlicht heller wie der Begleiter, so dass dieser überstrahlt wird. Während die Beugungsringe gut zu sehen sind, ist der zentrale Teil der Abbildung nicht klar definiert. Speckles erscheinen radial vom Zentrum nach außen. Atmosphärische Refraktion deutlich sichtbar. |
Mark McCarthy
203mm (368x) |
Small disk formed on diffraction spike at correct separation and PA (Feb. 2016) |
Mark McCarthy
317mm (443x) |
A faint yellow-orange disk, to the edge of Sirius A's diffraction and just below my spider's diffraction spike. I let Sirius pass beyond the field stop, and for an instant there was Sirius B, clearly separated, before it too passed beyond the field stop. |
Jörg S. Schlimmer
Germany |
305mm |
Visuell nicht zu trennen. Bei gutem Seeing ist der Begleiter mit Hilfe einer CMOS Video Kamera hingegen deutlich zu sehen. |
STF957 |
AB |
7m.5 |
9m.4 |
3.8" |
90° |
2019 |
Gem |
06h45m10.02s / +30°49'33.50" |
AC |
7m.5 |
13m.8 |
19.3" |
100° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
AB: Zu schwach für eine Trennung. Hauptkomponente sichtbar, Begleiter nicht. Verwendete Vergrößerungen von 67x bis 133x. Beobachtung aus der Stadt bei Mond (83%). |
Robert Zebahl
Leipzig (Germany) |
152mm (129x) |
AB: Einfach, deutlicher Helligkeitsunterschied bei moderatem Abstand. |
Mark McCarthy
203mm (205x) |
AB: Lovely blue-white A and light orange B, pleasingly close and a good 2 delta mag |
POU1983 |
11m.3 |
11m.6 |
2.9" |
315° |
2015 |
Gem |
06h45m16.14s / +24°12'43.50" |
Mark McCarthy
508mm (333x) |
Faint but easily seen, near equal, well split to wide, ~2.5" , bluish due to faintness |
STT155 |
7m.1 |
10m.9 |
15.1" |
261° |
2015 |
Gem |
06h45m23.51s / +24°40'20.90" |
Mark McCarthy
317mm (553x) |
Pretty orange star with 2x fainter B, also orange, due west, ~6" |
A122 |
8m.9 |
9m.4 |
0.4" |
24° |
2016 |
Gem |
06h45m27.02s / +29°21'59.80" |
Mark McCarthy
508mm (533x) |
Nice light orange stars, hairline split with indifferent seeing, PA to the SW. Slight magnitude difference. Physical with 102.3-year period, I have the PA reversed in my estimate, it's to the NE -- still can claim it though. It is coming off apastron and will close slightly in the next 20 years. Aiken discovered in 1900 with the Lick 36-inch also at 0.4" -- 118 years since, so it has made a little more than one revolution |
WFC42 |
10m.1 |
10m.8 |
4.5" |
358° |
2015 |
Gem |
06h45m27.48s / +33°12'55.40" |
Mark McCarthy
508mm (205x) |
White stars, wide split, very slight delta mag, quite pretty. Physical pair |
A2680 |
9m.6 |
9m.7 |
1.6" |
161° |
2006 |
Mon |
06h45m51.88s / +03°24'01.30" |
Mark McCarthy
178mm (205x) |
Nice! Very fine, with seeing, close less than 2", around 1 delta mag, light orange A and white B. A really fine pair |
BRT146 |
11m.2 |
11m.8 |
3.6" |
47° |
2015 |
Gem |
06h45m55.18s / +24°05'58.00" |
Mark McCarthy
508mm (333x) |
Faint, 1 delta mag, ~1.5" well split |
COU472 |
11m.4 |
11m.3 |
1.9" |
83° |
2015 |
Gem |
06h46m07.21s / +22°33'06.80" |
Mark McCarthy
508mm (333x) |
Faint but very fine pair, really pretty in the field, a little blue, half delta mag, ~1.5" Nice |
STF948, 12 Lyn |
AB |
5m.4 |
6m.0 |
1.9" |
64° |
2019 |
Lyn |
06h46m14.15s / +59°26'30.10" |
AC |
5m.4 |
7m.0 |
8.9" |
309° |
2019 |
Robert Zebahl
Leipzig (Germany) |
55mm (27x) |
AC: Komponenten A/B und C gut trennbar, aber dicht zusammen. Helligkeitsunterschied deutlich. Die schwächere C-Komponente wirkte leicht orange, die Komponente A/B weiß-bläulich. |
Robert Zebahl
Leipzig (Germany) |
55mm (167x) |
AB: Die Komponenten A und B trennbar, wobei sich die Beugungsscheibchen leicht überlappen. Der Helligkeitsunterschied war gut zu sehen. |
Robert Zebahl
Leipzig (Germany) |
63mm (140x) |
AB: Die Komponenten A und B trennbar mit nahezu keinem Zwischenraum. Sichtbarer Helligkeitsunterschied. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
AC: Gut trennbar, relativ dicht zusammen bei deutlicher Helligkeitsdifferenz. |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
AB: Die beiden Komponenten A + B deutlich voneinander getrennt, wobei die Beugungsringe miteinander verschmolzen. Ein sehr schöner Anblick zusammen mit der Komponente C. Ich habe eine Zeichnung angefertigt, welche meinen Eindruck gut wiedergibt. Leider sind Abstand und Positionswinkel nicht besonders gut erfasst. Auch den Helligkeitsunterschied der Komponenten A und B habe ich nicht bewusst gesehen. |
Robert Zebahl
Leipzig (Germany) |
102mm (129x) |
Bei 28x ist ohne Probleme das Paar AC schön getrennt. Das enge Paar AB ist bereits bei 86x als deutliche '8' erkennbar, bei 125x wunderbar getrennt. Die Komponenten A & B erscheinen gelblich. Sehr schöner Anblick zusammen mit STF 946 in einem Gesichtsfeld! |
Uwe Pilz
Leipzig (Germany) |
105mm (88x) |
im selben Feld mit STF 946 |
Robert Zebahl
Leipzig (Germany) |
152mm (129x) |
Bei 49x ist das Paar AC wunderschön getrennt mit deutlichem Helligkeitsunterschied. Bei 100x zeigt sich dann auch das enge Paar AB getrennt, wenn auch noch sehr dicht zusammenstehend. Ein geringer Helligkeitsunterschied ist erkennbar. Bei 129x ist der Anblick grandios. Die beiden hellen Komponenten A & B präsentieren sich gelblich, die schwächere Komponente C eher gräulich. STF 948 lässt sich wunderbar in einem Gesichtsfeld mit dem benachbarten Doppelstern STF 946 beobachten. Beide zeigen ein schönes Gesamtbild. |
Mark McCarthy
178mm (148x) |
AB: Gorgeous triple star, pale yellow A and B, and 1 delta blue C. really stunning. AB physical with a 733-year period |
HO238 |
8m.9 |
9m.1 |
0.3" |
174° |
2013 |
Gem |
06h46m20.91s / +18°12'08.20" |
Mark McCarthy
508mm (1067x) |
Barely hairline split at best moments, but conditions have a lot of haze and bloating. A half delta mag is noticeable. I can tell the star is a pair at 333x, but no where near resolvable |
HWE15 |
8m.9 |
10m.3 |
13.2" |
218° |
2015 |
CMa |
06h46m35.21s / -20°34'45.80" |
Mark McCarthy
317mm (553x) |
Orange, a wide faint blue B star |
POU2009 |
12m.6 |
12m.7 |
6.4" |
215° |
2015 |
Gem |
06h47m00.33s / +23°35'21.90" |
Mark McCarthy
508mm (333x) |
Just barely there, averted vision brightend it up, but I can still pull it out direct. Faint, bluish, wide, near equal |
BRT2362 |
11m.9 |
12m.6 |
3.4" |
7° |
2015 |
Gem |
06h47m12.56s / +17°27'46.50" |
Mark McCarthy
508mm (333x) |
Dare I say a glittering pair, faint but it twinkles, wide, bluish, probably parts of a plus one about twice as separated but with similar mag [not physical] |
STT157 |
7m.2 |
9m.2 |
0.6" |
161° |
2018 |
Mon |
06h47m47.56s / +00°20'24.50" |
Mark McCarthy
317mm (277x) |
Yellow A, widely separated from blue B. 2 magnitude difference. Did not notice 0.8" separation in A |
J992 |
11m.5 |
12m.3 |
4.0" |
100° |
2015 |
Gem |
06h48m08.72s / +16°53'16.60" |
Mark McCarthy
508mm (333x) |
B star almost needs averted vision to see, but shows up direct when seeing stills. Wide ~5", 1 delta mag, nice pair [not physical] |
STF958 |
AB |
6m.3 |
6m.3 |
4.5" |
77° |
2019 |
Lyn |
06h48m12.29s / +55°42'15.10" |
Robert Zebahl
Leipzig (Germany) |
70mm (33x) |
Deutlich getrennt, gleich hell, dicht zusammen. Schöner Anblick. |
Robert Zebahl
Leipzig (Germany) |
102mm (62x) |
Sehr schön getrennt. Beide Komponenten wirken gleichhell und weiß-gelblich. |
Mark McCarthy
178mm (148x) |
Near equal dull white typical Struve. Not much to look at but it's physical with a 2023 year period, with not much movement now but will whip around the A star pretty quickly when it reaches periastron 150 years from now |
STF972 |
A-BC |
8m.3 |
9m.3 |
12.5" |
154° |
2016 |
CMa |
06h48m22.15s / -15°19'47.30" |
René Merting
100mm (64x) |
bei 64x ein schwaches, unscheinbares, etwas mehr als knapp getrenntes Sternpaar - B im SO ist nur unwesentlich schwächer (lt. Stelle Doppie aber doch 0.99 mag) |
A58 |
AB |
7m.4 |
8m.7 |
5.0" |
161° |
2015 |
Mon |
06h48m35.78s / -04°04'32.60" |
René Merting
100mm (64x) |
bei 64x ein knapp getrenntes Pärchen - Komponente B im Süden ist eine Größenklasse schwächer und wirkt grau |
A2731 |
AB |
8m.2 |
9m.5 |
1.3" |
67° |
2016 |
Mon |
06h48m39.38s / +07°37'20.40" |
Mark McCarthy
178mm (205x) |
Excellent pair, around 2 two delta mag, more than 1" separated, very fine, dull white A and light yellow B. Physical with a 247 year period |
WFC45 |
10m.0 |
10m.5 |
7.0" |
321° |
2015 |
Mon |
06h49m49.42s / +06°56'04.20" |
Mark McCarthy
178mm (205x) |
Faint pair, wide, 1 delta. Does not seem like an obvious double |
STF964 |
8m.9 |
9m.7 |
1.6" |
183° |
2019 |
Aur |
06h50m21.58s / +43°45'15.20" |
Mark McCarthy
178mm (148x) |
Exceptionally fine at this magnification. The pair is in one corner of an equilateral triangle of near same magnitude stars. B is half delta mag and very close about 2". Very nice |
H5 108 |
A-BC |
5m.8 |
7m.7 |
42.7" |
66° |
2015 |
CMa |
06h50m23.34s / -31°42'21.80" |
Christopher Hay
Seeheim (Germany) |
10x56 |
Auf Stativ. A-BC weit getrennt. Nur 3° über meinem Horizont kurz nach Meridiandurchgang. A pulsiert geheimnisvoll in der flachen Luft, der 1° südlich stehende Kappa CMa, ganz dicht am südlichen Rand des Sternbildgebietes, pulsiert ebenso geheimnisvoll in leicht verschobenem Takt. Ein physikalischer Doppelstern in 650 Lichtjahren Abstand zu uns. |
WFC46 & PAL3 |
WFC46 |
AB |
11m.4 |
11m.7 |
9.2" |
297° |
2015 |
Gem |
06h51m02.45s / +19°14'40.00" |
PAL3 |
BC |
11m.7 |
13m.5 |
5.6" |
295° |
2015 |
Mark McCarthy
508mm (333x) |
WFC46 (AB): Wide bluish pair about half delta mag. I see a third star with averted vision pretty close to one of these stars, ~3-4" interesting [PAL 3 BC, 11.65/13.50 5.6"] |
Mark McCarthy
508mm (333x) |
PAL3 (BC): Third star seen with averted vision pretty close to WFC 46 B, ~3-4" |
POU2065 |
12m.1 |
12m.9 |
4.8" |
175° |
2015 |
Gem |
06h51m25.93s / +24°25'17.40" |
Mark McCarthy
508mm (333x) |
Pretty faint, pulled out with averted and held there, wide, about half delta mag. [not physical] |
POU2072 |
9m.5 |
11m.3 |
9.8" |
38° |
2015 |
Gem |
06h51m42.09s / +23°14'36.40" |
Mark McCarthy
508mm (333x) |
Easy, white and blue, ~1.5 delta mag, pretty wide |
HJ740 |
AB |
8m.2 |
9m.1 |
21.2" |
9° |
2015 |
Mon |
06h51m46.17s / +00°27'35.90" |
BC |
9m.1 |
11m.8 |
9.1" |
286° |
2015 |
René Merting
18x70 |
AB: Komponente B ist nördlich von A knapp getrennt erkennbar - Helligkeitsunterschied vielleicht eine Größenklasse |
René Merting
100mm (32x) |
AB: bei 32x ein ordentlich getrenntes Sternpaar - Komponente B wirkt halb so hell wie A |
J56 |
9m.4 |
9m.7 |
1.5" |
334° |
2015 |
Mon |
06h52m37.65s / +03°14'17.80" |
Mark McCarthy
178mm (205x) |
Very fine near equal pair, 1.5" separation, really good |
STF974, 59 Aur |
AB |
6m.1 |
10m.2 |
22.2" |
224° |
2015 |
Aur |
06h53m01.41s / +38°52'08.90" |
BC |
10m.2 |
12m.8 |
25.6" |
219° |
2015 |
Robert Zebahl
Leipzig (Germany) |
102mm (28x) |
AB: Einfach, moderater Abstand, große Helligkeitsdifferenz. A wirkte weiß-gelblich, B erschien nur als schwaches Sternchen. |
STF985 |
7m.8 |
8m.4 |
32.6" |
323° |
2017 |
Mon |
06h53m56.06s / -04°23'32.80" |
René Merting
18x70 |
leicht (bequem getrennt) und schön mit Farbkontrast - Komponente A im Südwesten ist leicht gelblich, B wirkt dagegen grau - ein paar schwächere Sterne im Umfeld sorgen dafür, dass der Doppelstern noch etwas mehr hervor gehoben erscheint |
René Merting
100mm (20x) |
bei 32x ein weite Trennung - ein schöner Farbkontrast, Komponente A südöstlich ist weißgelb, B im NW dagegen ist zartorange - zurück auf 20x ordentliche Trennung |
STF982, 38 Gem |
AB |
4m.8 |
7m.8 |
7.3" |
145° |
2018 |
Gem |
06h54m38.63s / +13°10'40.10" |
Robert Zebahl
Leipzig (Germany) |
55mm (27x) |
Bei 27x recht dicht zusammmen mit deutlich schwächerer Komponente. Bei 71x klar getrennt bei deutlicher Helligkeitsdifferenz. Hellere Komponente wirkte leicht gelblich, Schwächere leicht bläulich. |
Robert Zebahl
Leipzig (Germany) |
70mm (33x) |
Einfach zu trennen mit deutlichem Helligkeitsunterschied. Die schwächere Komponente wirkte leicht orange, die hellere eher weiß. |
Uwe Pilz
Leipzig (Germany) |
105mm (130x) |
recht attraktiv |
Mark McCarthy
203mm (333x) |
38 Gem. Light yellow A and blue B, quite wide, very pretty. AC much wider separation much fainter not noticed |
Mark McCarthy
317mm (553x) |
Bright orange and slightly red star, 2-3 delta mag. |
Mark McCarthy
317mm (553x) |
Pretty yellow and orange, 2 delta mag, wide separation |
STF986 |
8m.3 |
9m.0 |
5.5" |
163° |
2019 |
Mon |
06h54m54.08s / +09°29'56.50" |
Mark McCarthy
178mm (205x) |
Easy Struve, around 1 delta mag, wide, light blue-white stars. Physical |
H5 65, 17 CMa |
AB |
5m.8 |
8m.7 |
42.9" |
147° |
2015 |
CMa |
06h55m02.74s / -20°24'17.50" |
AC |
5m.8 |
9m.2 |
48.5" |
187° |
2015 |
AD |
5m.8 |
9m.7 |
128.8" |
187° |
2015 |
BC |
8m.7 |
9m.2 |
31.3" |
247° |
2015 |
CD |
9m.2 |
9m.7 |
80.4" |
187° |
2015 |
René Merting
18x70 |
AB: ein mehr als ordentlich getrenntes Pärchen - Komponente B im SO ist gut 2.5 Größenklassen schwächer, aber noch gut erkennbar - schöner Farbkontrast |
René Merting
100mm (107x) |
AB: bei 32x getrenntes Paar, Komponente B im Süden deutlich schwächer AC: bei 107x wird westlich von Komponente B ein noch schwächerer Stern sichtbar, Komponente C - dieser Stern steht minimal weiter weg von A als B |
J273 |
AB |
9m.9 |
10m.3 |
4.4" |
340° |
2017 |
Gem |
06h55m18.52s / +12°35'07.00" |
Mark McCarthy
203mm (333x) |
Near equal white, pretty wide |
STF981 |
8m.7 |
9m.0 |
0.9" |
119° |
2016 |
Gem |
06h55m28.54s / +30°09'42.30" |
Mark McCarthy
317mm (553x) |
Very close orange pair, equal magnitude. Clean split, ~1". |
Mark McCarthy
508mm (333x) |
Very finely split, white stars, nearly 1 delta mag. Appeared as a rod at 205x. Physical with a 1089.7-year period. Discovered in 1831 at 3.7", near apastron, it has narrowed considerably since |
HN 123, pi CMa, 19 CMa |
4m.7 |
9m.6 |
11.6" |
13° |
2015 |
CMa |
06h55m37.40s / -20°08'11.70" |
René Merting
100mm (107x) |
bis 107x vergrößert, aber mehr als eine kleine kaum wahrnehmbare Ausbeulung nach Norden war nicht drin - höher Vergrößern wegen schlechtem Seeing nicht ratsam in der Nacht - kurios, der Stern strahlte zweifarbig, bläulich im Norden und ein helloranger Rand im Süden - ob das ein Dispersionseffekt war oder hervorgerufen aufgrund der beiden eng stehenden Sterne, vermag ich nicht zu sagen |
HO27 |
AB |
9m.6 |
10m.1 |
3.7" |
127° |
2015 |
Gem |
06h56m03.65s / +20°05'03.20" |
Mark McCarthy
203mm (333x) |
Nice near equal, though mag difference is notable. Third slightly brighter a bit further out [this is AC, 9.64/9.71 23"] |
BU326 |
8m.0 |
9m.5 |
0.5" |
341° |
1987 |
Mon |
06h56m11.96s / +02°18'59.70" |
Mark McCarthy
178mm (333x) |
Seeing not great, so I only get a notched elongation at the highest mag the sky will support, only 333x. Needs a better night. Discovered at 1.2", so it has closed considerably, and I should not feel bad not seeing it with just 7-inch aperture |
STF983 |
AB |
8m.7 |
12m.7 |
10.7" |
36° |
2015 |
Gem |
06h56m13.67s / +34°27'32.70" |
Mark McCarthy
508mm (205x) |
B is very faint for a Struve pair, it's wide, with a light orange A star, approximately 3 delta mag. Not physical |
STF984 |
8m.7 |
10m.8 |
3.3" |
155° |
2017 |
Gem |
06h56m16.59s / +32°26'41.40" |
Mark McCarthy
508mm (205x) |
This is a typical Struve, light yellow A, slightly orange B, approximately one delta mag and 4". Not physical |
STF979 |
8m.5 |
9m.6 |
7.5" |
211° |
2017 |
Aur |
06h56m36.65s / +46°32'19.00" |
Mark McCarthy
178mm (148x) |
Classic Struve, 1.5 delta mag, white A and dull yellow B, wide |
STF991 |
AB |
8m.0 |
9m.2 |
3.8" |
165° |
2019 |
Gem |
06h57m01.26s / +24°57'27.90" |
Sarah Gebauer
Germany |
100mm (73x) |
haarscharf getrennt, nordwestliche Komponente ist etwas heller und größer und die südöstliche steht ganz schwach daneben |
Uwe Pilz
Leipzig (Germany) |
105mm (144x) |
bei 88x trennbar. Orange, Begleiter schwach |
Mark McCarthy
317mm (553x) |
White and orange, 2 delta mag, ~5", PA to S. |
Mark McCarthy
508mm (333x) |
Pretty off-yellow A and a little ruddy red B, nice |
STT159, 15 Lyn |
AB |
4m.5 |
5m.5 |
0.7" |
236° |
2017 |
Lyn |
06h57m16.60s / +58°25'23.00" |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
nicht getrennt im April 2020 |
Frederik Wanink
254mm (640x) |
relativ einfach |
A2459 |
AB |
9m.8 |
9m.8 |
0.4" |
274° |
2008 |
Gem |
06h57m39.64s / +19°35'04.10" |
Mark McCarthy
508mm (1067x) |
Notched near equal at best moments |
STTA80 |
AB |
7m.2 |
7m.4 |
124.1" |
53° |
2015 |
Gem |
06h58m06.59s / +14°13'43.40" |
AC |
7m.2 |
8m.4 |
81.2" |
112° |
2015 |
Christopher Hay
Seeheim (Germany) |
7x45 |
Handgehalten. AB gut getrennt, ein gleichhelles Paar. Sofort auffallend im Feld. |
Christopher Hay
Seeheim (Germany) |
15x45 |
Fernglas mit interner Stabilisierung, handgehalten. AB sind weit getrennt, hinzu gesellt sich ein dritter, schwächerer Lichtpunkt, das ist C, gut abgesetzt. Ein charmantes kleines Dreieck. Ein Teil des Sternmusters Monti 4 (oder dessen Gesamtheit?). |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Alle 3 Komponenten bilden ein auffälliges Dreieck und sind farblich leicht verschieden. A (westl. Komponente): weiß-bläulich; B (nördliche Komponente): weiß-gelblich; C (südliche Komponente): orange, teils leicht rötlich. |
STF1004 |
8m.1 |
9m.7 |
20.5" |
89° |
2015 |
Mon |
06h58m27.93s / -11°25'51.40" |
René Merting
100mm (20x) |
bei 32x ein schickes Pärchen, komfortabel getrennt - Komponente B im Osten ist deutlich schwächer, mindestens 1.5 Größenklassen - Farbkontrast, weil B so schwach ist - zurück auf 20x gelingt die Trennung weiterhin |
J278 |
9m.9 |
10m.3 |
2.4" |
147° |
2008 |
Mon |
06h58m36.18s / +06°41'10.90" |
Mark McCarthy
178mm (205x) |
Faint pair, just brightens enough to split with averted vision |
CPO7, eps CMa |
1m.5 |
7m.5 |
7.9" |
162° |
2008 |
CMa |
06h58m37.55s / -28°58'19.50" |
Mark McCarthy
203mm (113x) |
Adhara, epsilon Canis Majoris: Wow! Bright (+1.5 magnitude) and large A with small and much fainter close B (magnitude +7.5) to the south. Lovely double |
A1061 & STF1000 |
A1061 |
AB |
8m.9 |
9m.1 |
0.6" |
42° |
1999 |
Gem |
06h59m21.15s / +25°14'00.20" |
STF1000 |
AB-C |
8m.1 |
9m.0 |
22.1" |
67° |
2016 |
René Merting
100mm (32x) |
STF1000 (AB-C): bei 32x ein bequem getrenntes Pärchen - Komponente AB kühlweiß - Komponente C im Osten ist eine dreiviertel Größenklasse schwächer und grauweiß |
Sarah Gebauer
Germany |
100mm (73x) |
STF1000 (AB-C): sieht fast so aus, als hätte die westliche Komponente einen Gelbstich, bei 73x weit und deutlich getrennt |
STF994 |
AB |
7m.9 |
8m.1 |
26.4" |
55° |
2017 |
Aur |
06h59m27.19s / +37°05'53.50" |
Robert Zebahl
Leipzig (Germany) |
55mm (25x) |
Gut trennbar, recht großer Abstand, leichter Helligkeitsunterschied. |
STF996 |
AB |
8m.9 |
10m.8 |
9.8" |
168° |
2018 |
Aur |
07h00m13.77s / +42°59'04.20" |
Mark McCarthy
178mm (148x) |
A neat triple, appears as an elongated triangle with A at the apex, B is next brightest closest, C one delta farther out separated twice as far as B. nice |
STF1007 |
AB |
7m.4 |
11m.4 |
14.6" |
300° |
2015 |
Gem |
07h00m37.12s / +12°43'24.20" |
AC |
7m.4 |
10m.0 |
21.9" |
244° |
2015 |
AD |
7m.4 |
7m.7 |
67.7" |
28° |
2016 |
Christopher Hay
Seeheim (Germany) |
7x45 |
AD: Handgehalten. Sofort auffallend als Doppelstern mit eindeutigem Positionswinkel in einem Feld mit mehreren ähnlich hellen Sternen. Ungestützt verhindert Handzittern das Sehen der Einzelkomponenten, aber durch Abstützen der Arme im Liegestuhl ist das sehr gleichmäßig helle Paar klar getrennt. Ein physikalischer Doppelstern in 914 Lichtjahren Abstand zu uns. |
Christopher Hay
Seeheim (Germany) |
15x45 |
Fernglas mit interner Stabilisierung, handgehalten. AD gut getrennt. A ist deutlich heller und bläulich. Hübsch in 4.5° Gesichtsfeld zusammen mit STTA80 ABC. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
AD: Weit getrennt, geringer Helligkeitsunterschied. Farblich leicht verschieden, aber schwer zu benennen. Komponente A wirkte zumindest eher weiß. Südlich von STF1007 befindet sich noch der Doppelstern HJ3288 sowie der Stern HD52976, welcher in einem hellen Orange erscheint. Zusammen in einem Gesichtsfeld ein schöner Anblick. |
BU100 |
7m.3 |
11m.1 |
3.2" |
261° |
1978 |
Gem |
07h00m56.55s / +12°24'00.40" |
Mark McCarthy
317mm (553x) |
Pretty orange and blue. 4 delta mag, PA to west. Wide separation ~3" B is just seen, a very fine point. |
STT163 |
AB |
7m.2 |
8m.2 |
0.2" |
99° |
1997 |
Mon |
07h01m09.85s / +11°46'28.70" |
Mark McCarthy
317mm (553x) |
Not perfectly round AB, a faint bluish haze in the diffraction to the south. Marginal |
ARN66 |
AF |
6m.6 |
8m.3 |
172.0" |
301° |
2011 |
Gem |
07h01m17.01s / +32°24'52.40" |
Christopher Hay
Seeheim (Germany) |
7x45 |
Handgehalten. AF ist ein sofort auffallendes, weites Paar. Gut in 8.6° Gesichtsfeld zusammen mit dem sehr weiten Rho Gem anzuschauen, welcher ein weiteres physikalisches Paar ist. Arnold 66 AF ist ein physikalischer Doppelstern in 462 Lichtjahren Abstand zu uns. |
STF1010 |
AC |
7m.7 |
8m.8 |
22.3" |
7° |
2017 |
Mon |
07h01m27.05s / -03°07'03.30" |
René Merting
18x70 |
ein schönes enges Pärchen - Komponente B zeigt sich nicht zu knapp getrennt nördlich von A - Helligkeitsunterschied eine Größenklasse - zwei sehr schwache Sterne flankieren nahezu symmetrisch im SO und SW das Paar - netter Anblick |
BU573 |
7m.2 |
7m.8 |
0.8" |
311° |
2018 |
Mon |
07h01m49.89s / -10°52'56.30" |
Uwe Pilz
Leipzig (Germany) |
105mm (247x) |
schwach gekerbt |
HJ3288 |
7m.3 |
8m.7 |
38.5" |
247° |
2015 |
Gem |
07h02m18.43s / +12°34'54.20" |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Einfach zu trennen bei moderatem Abstand und deutlichem Helligkeitsunterschied. Leichter Farbunterschied: weiß-gelblich, leicht orange. Schöner Anblick zusammen mit dem Doppelstern STF1007 und HD52976, welcher in einem hellen Orange erscheint. Zeichnung zusammen mit STF1007. |
A2462 |
AB |
9m.2 |
9m.0 |
0.2" |
250° |
2019 |
Gem |
07h02m37.42s / +15°58'26.50" |
Mark McCarthy
508mm (1067x) |
Short period list. Notched, noticeable magnitude difference, B star pointed in direction of apex of right triangle it forms with two other eighth magnitude stars. Light orange stars |
HO342 |
8m.0 |
8m.7 |
1.2" |
89° |
2016 |
Gem |
07h02m50.54s / +13°05'21.70" |
Mark McCarthy
317mm (553x) |
Yellow-orange and blue stars, PA to the east, 1 delta mag, tight but well split ~1". |
A1575 |
8m.6 |
9m.3 |
0.8" |
283° |
2016 |
Lyn |
07h03m01.14s / +54°02'55.40" |
Robert Zebahl
Leipzig (Germany) |
102mm (160x) |
Nicht klar als Doppelstern erkennbar. |
Robert Zebahl
Leipzig (Germany) |
152mm (225x) |
23.03.2020: Bei 225x und 300x deutlich länglich, teils als '8' erkennbar. |
STF1001 |
AB |
7m.8 |
9m.4 |
9.1" |
66° |
2019 |
Lyn |
07h03m05.51s / +54°10'26.60" |
AC |
7m.8 |
9m.3 |
9.9" |
58° |
2019 |
BC |
9m.4 |
9m.3 |
1.6" |
5° |
2019 |
Robert Zebahl
Leipzig (Germany) |
102mm (160x) |
23.03.2020: Bei 28x ist das Paar A-BC einfach zu trennen. Bei 160x zeigt sich das sehr enge Paar BC getrennt. Die Komponente A erscheint leicht orangefarben. |
Uwe Pilz
Leipzig (Germany) |
105mm (88x) |
Robert Zebahl
Leipzig (Germany) |
152mm (129x) |
23.03.2020: Bei 22x zeigt sich das weite Paar A-BC bereits getrennt, aber noch sehr dicht zusammenstehend. Bei 69x erscheint A in einem dezenten Orange. Das Paar BC ist länglich und wirkt eher grün-bläulich. Bei 100x ist das Paar BC bereits als '8' und beinahe getrennt, bei 129x klar getrennt sichtbar. Die Komponenten B und C sind noch immer sehr dicht zusammen und gleich hell. Der Farbeindruck bleibt bestehen. Ein interessantes und lohnendes Dreifachsystem! |
Mark McCarthy
178mm (222x) |
BC: Wow excellent 2+1, with a brighter white A and BC is a near equal faint pair about 1" separation. Seen with 148x but better resolved with 222x |
SHJ77, zeta Gem, 43 Gem, Mekbuda |
AB |
4m.0 |
11m.5 |
87.4" |
85° |
2001 |
Gem |
07h04m06.54s / +20°34'13.10" |
AC |
4m.0 |
7m.7 |
100.2" |
347° |
2015 |
AD |
4m.0 |
12m.5 |
67.8" |
354° |
2008 |
Christopher Hay
Seeheim (Germany) |
15x45 |
AC: Fernglas mit interner Stabilisierung, handgehalten. AC sind weit auseinander und ein visuell starkes (allerdings nicht physikalisches) Paar. |
A2463 |
9m.8 |
10m.0 |
4.2" |
214° |
2017 |
Aur |
07h05m07.90s / +41°53'08.40" |
Mark McCarthy
178mm (148x) |
White stars, near equal, wide. Physical |
STF1009 |
AB |
6m.9 |
7m.0 |
4.4" |
148° |
2019 |
Lyn |
07h05m39.83s / +52°45'31.30" |
Robert Zebahl
Leipzig (Germany) |
70mm (33x) |
Sehr schöner Anblick. Gleich helle Komponenten, dicht beisammen. |
Mark McCarthy
178mm (148x) |
Bright blue-white stars, about 4" separated, about one delta |
STF1014 |
9m.9 |
9m.9 |
2.0" |
221° |
2017 |
Gem |
07h05m44.95s / +26°08'25.30" |
Mark McCarthy
Fremont (California/USA) |
203mm (205x) |
Faint pair, noticeable magnitude difference, white, well separated |
Mark McCarthy
317mm (553x) |
Very faint near equal brightness pair, ~3", PS to the SW. |
D12 & STF1019 & RST3491, V569 Mon |
D12 |
AB |
6m.5 |
10m.1 |
6.4" |
282° |
2003 |
Mon |
07h05m49.64s / -10°39'36.30" |
STF1019 |
AC |
6m.5 |
9m.6 |
38.2" |
292° |
2011 |
RST3491 |
CD |
9m.6 |
10m.4 |
0.9" |
302° |
1963 |
René Merting
12x42 |
AC: mit etwas Konzentration zeigt sich C extrem schwach nordwestlich von A - Abstand ordentlich |
STF1013 |
9m.9 |
10m.6 |
3.8" |
50° |
2015 |
Aur |
07h05m51.89s / +36°02'55.00" |
Mark McCarthy
178mm (148x) |
Fine pair, white A and orangish faint B 2 delta mag, fairly close about 4" |
J728 |
8m.8 |
10m.4 |
3.0" |
73° |
2015 |
Gem |
07h06m05.16s / +19°03'11.70" |
Mark McCarthy
178mm (205x) |
Dim pair, 1 delta mag, around 3". Physical |
BU328 & STF1026, FN CMa |
BU328 |
AB |
5m.7 |
6m.9 |
0.6" |
111° |
2003 |
Mon |
07h06m40.77s / -11°17'38.50" |
STF1026 |
AB-C |
5m.4 |
9m.0 |
17.8" |
350° |
2011 |
René Merting
12x42 |
AB-C: trotz 17,8" Abstand keine Chance, der Helligkeitsunterschied ist vermutlich zu groß |
STF1017 |
9m.3 |
10m.2 |
12.8" |
255° |
2018 |
Gem |
07h07m10.44s / +16°50'21.80" |
Mark McCarthy
178mm (205x) |
ENG28 |
AB |
7m.9 |
7m.7 |
171.9" |
99° |
2015 |
Gem |
07h08m00.24s / +15°31'42.90" |
Christopher Hay
Seeheim (Germany) |
7x45 |
Handgehalten. Leicht aufzufinden, da ein halbes Grad südlich von 45 Gem. Gut in 8,6° Gesichtsfeld zusammen mit STTA 80 AB und STF 1007 anzuschauen, alle drei Systeme gut bis weit getrennt, ein entzückendes Trio von Doppelsternen. Alternativ kann ENG 28 auch mit dem 5° nördlich stehenden Zeta Gem (Mekbuda) zusammen im Gesichtsfeld gefasst werden. Engelmann 28 ist ein physikalischer Doppelstern in 152 Lichtjahren Abstand zu uns. Zur Bezeichnung ENG gibt es eine interessante kleine Schickane, zu der Stelledoppie ausführt: Some time after publication of the IDS, the designation for Engelmann was changed from EN to ENG and that for Engelhardt from ENG to ENH. This has led to considerable confusion between the two. |
Mark McCarthy
80mm (13x) |
Pretty, wide equal finder split, white, nice field. |
STT165, 45 Gem |
AB |
5m.4 |
10m.9 |
16.0" |
6° |
2015 |
Gem |
07h08m22.04s / +15°55'51.30" |
Mark McCarthy
508mm (533x) |
45 Gem. With apodizing mask. Bright light orange and very wide eleventh mag B, 4-5 delta mag, ~15". [not physical] |
STF1027 |
AB |
8m.5 |
8m.7 |
6.9" |
356° |
2015 |
Gem |
07h08m46.74s / +16°54'31.80" |
Mark McCarthy
178mm (205x) |
Near equal, pale white stars, wide. Physical |
STF1022 |
6m.8 |
10m.1 |
5.5" |
128° |
2017 |
Aur |
07h09m25.72s / +36°33'47.80" |
Mark McCarthy
178mm (148x) |
White stars, >2 delta mag, well split about 5". Not physical |
STTA83 & HO519 |
HO519 |
AB |
7m.2 |
13m.0 |
32.5" |
73° |
2015 |
Gem |
07h09m35.47s / +25°43'44.70" |
STTA83 |
AC |
7m.2 |
7m.8 |
123.3" |
79° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
STTA83 (AC): Weites Paar, relativ hell, mäßiger Helligkeitsunterschied. A: leicht orange; C: grau-blau. Südöstlich des Paares in deutlich größerem Abstand befindet sich noch ein weiterer, schwächerer Stern, welcher orange, teils rötlich wirkt. Er gehört allerdings nicht zum System. Alle drei Sterne bilden ein schönes, rechtwinkliges Dreieck. |
STF1021 |
A-BC |
9m.5 |
9m.6 |
4.2" |
15° |
2019 |
Aur |
07h09m38.52s / +38°28'27.10" |
Mark McCarthy
178mm (148x) |
White stars, noticeable mag difference, wide. BC is COU 2064 10.3/10.5 0.3" not seen |
STF1024 |
AB |
9m.0 |
9m.2 |
1.4" |
315° |
2019 |
Aur |
07h10m12.99s / +38°07'50.20" |
Mark McCarthy
178mm (148x) |
Wow, superfine pair, about half delta mag, very close but split at low magnification small scale. The split is more obvious with more magnification, but actually the best images with 148x. Great pair, very light yellow-orange stars |
HO518 |
8m.3 |
10m.3 |
3.3" |
146° |
2001 |
Gem |
07h10m24.17s / +30°21'31.70" |
Mark McCarthy
508mm (205x) |
Bright white and pale white, 2 delta mag, 3" separation. A nice pair in a string of stars |
TDS4557 |
10m.7 |
10m.7 |
0.5" |
122° |
1991 |
Gem |
07h10m58.01s / +27°46'52.30" |
Mark McCarthy
508mm (533x) |
Very fine hairline split with seeing, dull white stars |
BU1009, tau Gem |
AB |
4m.4 |
11m.0 |
1.8" |
163° |
2004 |
Gem |
07h11m08.39s / +30°14'43.00" |
Mark McCarthy
508mm (205x) |
B is a very fine point on the edge of bright A' yellow-orange diffraction, subtle. Burnham writes: "This fine and difficult pair was discovered at Mt. Hamilton with the 12-inch in 1881….The measures are sufficient to show from the common proper motion that this is a physical pair." Discovered at 1.8" separation |
HJ3934 |
A-BC |
6m.9 |
8m.5 |
13.6" |
238° |
2017 |
CMa |
07h11m20.93s / -21°48'11.80" |
Uwe Pilz
Leipzig (Germany) |
105mm (180x) |
schwach |
STF1035 |
8m.1 |
8m.4 |
8.7" |
40° |
2018 |
Gem |
07h12m01.06s / +22°16'44.50" |
Robert Zebahl
Leipzig (Germany) |
16x70 |
22.02.2021: Getrennt, aber sehr dicht zusammenstehend. Geringer Helligkeitsunterschied erkennbar. |
Mark McCarthy
508mm (205x) |
Very easy bright white equal pair. Physical |
HDS999 |
6m.4 |
9m.1 |
0.3" |
7° |
2012 |
CMi |
07h12m07.50s / +05°28'27.70" |
Mark McCarthy
508mm (1067x) |
I detect a bluish bump on one side of the orange A star at best moments, and assume this is the B star, but I'm unsure. It is just a discoloration along the rim with a very slight bump out. Seeing is not good enough to resolve |
WEI14 |
7m.8 |
8m.9 |
2.1" |
160° |
2012 |
Gem |
07h12m48.16s / +15°10'41.90" |
Mark McCarthy
317mm (553x) |
A yellow-orange, blue B, 1 delta mag, PA to south. Nice! |
Mark McCarthy
508mm (205x) |
Very pretty white stars, 2 delta and about 3" separation, in a rich field |
STF1037 |
AB |
7m.2 |
7m.3 |
0.8" |
304° |
2019 |
Gem |
07h12m49.08s / +27°13'30.20" |
Uwe Pilz
Leipzig (Germany) |
105mm (260x) |
eingekerbt |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
bei 200x trennbar, beide gelb |
Mark McCarthy
178mm (205x) |
Hairline split at 205x but went to 533x to get clear view of it to drift through the field to tell PA. Slight magnitude difference. Really nice looking pair, masked down to 7-inches to get clean disks. Physical with a 118.35-year period, it will close rapidly and become undetectable during the 2030s, widening again in the 2040s |
Frederik Wanink
254mm (640x) |
leichter, gleich hell |
STF1025 |
AB |
8m.4 |
8m.7 |
27.0" |
130° |
2018 |
Lyn |
07h12m50.93s / +55°48'12.20" |
Mark McCarthy
178mm (148x) |
Lovely wide near equal, blue-green color stars. Not physcial |
J59 |
10m.2 |
10m.4 |
1.5" |
205° |
2015 |
CMi |
07h13m09.27s / +02°50'40.80" |
Mark McCarthy
508mm (533x) |
Faint pair, but seen nicely. Blue-white stars, near equal, ~1.5", nearly wide |
STT167 |
AB |
7m.4 |
10m.9 |
5.1" |
163° |
2017 |
Gem |
07h13m30.95s / +32°08'43.70" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
Zu schwach für eine Trennung. Hauptkomponente sichtbar, vom Begleiter keine Spur. Beobachtung aus der Stadt bei Mond (83%). |
Robert Zebahl
Leipzig (Germany) |
152mm (270x) |
Ich hatte bei einem Positionswinkel von etwa 180° manchmal das Gefühl, etwas vom schwachen Begleiter zu sehen, aber nicht sicher. |
STF1048 |
9m.1 |
10m.1 |
5.9" |
351° |
2018 |
CMi |
07h14m14.25s / +04°12'26.50" |
Mark McCarthy
508mm (533x) |
Pretty wide, >1 delta mag, light orange stars |
STF1033 |
AB |
7m.8 |
8m.4 |
1.5" |
278° |
2017 |
Lyn |
07h14m48.05s / +52°32'44.10" |
AC |
7m.8 |
10m.2 |
79.6" |
273° |
2015 |
Robert Zebahl
Leipzig (Germany) |
102mm (160x) |
Das Paar AB erscheint deutlich getrennt, aber noch recht dicht bei gut erkennbarem Helligkeitsunterschied. Die schwache C-Komponente liegt in ähnlichem Positionswinkel weit entfernt. |
BRT1227 |
9m.9 |
11m.7 |
8.1" |
321° |
2015 |
CMi |
07h15m03.14s / +10°51'25.60" |
Mark McCarthy
508mm (533x) |
Light yellow-orange A is easy to see, the B star is much fainter, can see with direct vision but sharpens with averted vision. Transparency is poor and the sky is bright with a waxing moon |
STF1056 |
8m.0 |
8m.9 |
3.9" |
299° |
2017 |
Mon |
07h15m34.34s / -01°51'36.80" |
Mark McCarthy
317mm (170x) |
Wide reddish pair. |
145 CMa, Winter Albireo |
HJ3945, Winter Albireo |
AB |
5m.0 |
5m.8 |
26.5" |
50° |
2020 |
CMa |
07h16m36.84s / -23°18'56.10" |
SHY508 |
BC |
5m.8 |
6m.8 |
999.9" |
165° |
1999 |
Christopher Hay
Seeheim (Germany) |
7x45 |
AB: Auf Stativ. Sehr knapp aber eindeutig getrennt. A geht in's Orangene. Nähe zu A verhindert Bestimmung der Farbe von B.. |
René Merting
Drachhausen (Germany) |
8x30 |
AB: Winter-Albireo - ein eng stehendes Pärchen, ganz knapp getrennt - Komponente A im SW knallig orange, bei B ist schwer eine Farbnuance erkennbar, eher weißlich und deutlich schwächer als A |
René Merting
10x50 |
AB: ein knapp getrenntes Paar (nicht besser als im 8x30) - Komponente A leicht gelblich, B ist kühler, weißlich |
Christopher Hay
Seeheim (Germany) |
10x56 |
BC: Auf Stativ. B-Komponente ist gut getrennt von der visuell störenden (weil nicht zum physikalischen System gehörenden) A-Komponente (welche ihrerseits der Hauptstern von HJ3945, dem Winter-Albireo, ist). C gut zu sehen und gut eingerahmt in 6,3° Gesichtfeld mit Tau CMa in Feldmitte. Shaya 508 BC ist ein physikalischer Doppelstern in einem Abstand zu uns von 303 Lichtjahren. Vorgestellt von E.J. Shaya, R. Olling, 2011: Very Wide Binaries and Other Comoving Stellar Companions: A Bayesian Analysis of the Hipparcos Catalogue. Die C-Komponente ist mehr als 3° südlich der B-Komponente. Die Koordinaten der C-Komponente (= HD 35578) sind RA 07h20m32.5s, DEC -26°42'01". |
Christopher Hay
Seeheim (Germany) |
10x56 |
AB: Auf Stativ. Sofort auffallendes, gut getrenntes Paar. A blitzend-orange. Die Szintillation von und Überstrahlung durch A verhindern einen bestimmten Farbeindruck von B. |
René Merting
18x70 |
AB: ein gut getrenntes Pärchen - Komponente A im Südwesten ist apfelsinenorange, B wirkt anfangs eisblau, bei längerer Betrachtung weißgrau |
Christopher Hay
Seeheim (Germany) |
42mm (12x) |
AB: Sauber getrennt. Orange und blau. |
René Merting
100mm (20x) |
AB: bei 32x leuchtet Komponente A goldgelb, B im NO wirkt weiß ohne den erwarteten Farbstich, auch nicht bei 107x und auch nicht, wenn ich die Sterne leicht unscharf stelle - trotzdem sehenswert - auch bei 20x zeigen sich beide Sterne ordentlich voneinander getrennt, A strahlt jetzt noch tiefgelber, fast orange |
Uwe Pilz
Leipzig (Germany) |
105mm (37x) |
AB: sofort auffallend, blau-orange |
Robert Zebahl
Leipzig (Germany) |
120mm (23x) |
AB: Sofort auffällig, einfach zu trennen bei großem Abstand. Hellere Komponente deutlich orangefarben, schwächere bläulich. |
STF1053 |
7m.3 |
10m.8 |
13.9" |
316° |
2015 |
Gem |
07h16m48.52s / +24°32'10.70" |
Mark McCarthy
178mm (205x) |
White A and very faint B, can barely see it direct, it brightens with averted, wide about 15". Not physical |
STT170 |
AB |
7m.4 |
7m.7 |
0.6" |
288° |
2018 |
CMi |
07h17m38.51s / +09°17'31.50" |
Mark McCarthy
203mm (333x) |
Notched, near equal at 333x. At 667x, hairline split very easy to see, near equal white stars |
STF1061, lam Gem |
AB |
3m.6 |
10m.7 |
9.3" |
36° |
2009 |
Gem |
07h18m05.61s / +16°32'25.70" |
Mark McCarthy
178mm (205x) |
Bright white A and very much fainter B which is a very fine wide point which sharpens with seeing |
HEI725 |
10m.5 |
10m.7 |
1.1" |
349° |
2016 |
CMi |
07h18m06.19s / +10°34'53.40" |
Mark McCarthy
508mm (533x) |
Faint pair but sharp with seeing, nicely split ~1", less than half magnitude difference but it is noticeable. Nice pair |
BRT1229 |
9m.9 |
11m.1 |
4.5" |
353° |
2015 |
CMi |
07h18m20.96s / +10°50'07.40" |
Mark McCarthy
508mm (533x) |
B star needs averted vision to appear, widely separated ~4", faint light yellow A but there's a significant magnitude difference. [not physical] |
BAL2265 |
AB |
10m.0 |
10m.4 |
14.0" |
93° |
2016 |
CMi |
07h18m30.00s / +03°27'37.00" |
Mark McCarthy
508mm (533x) |
Faint, B actually needs averted vision to see well, very wide pair. conditions bad [not physical] |
STF1068 |
AB |
9m.3 |
9m.8 |
4.1" |
350° |
2019 |
Gem |
07h19m49.31s / +13°22'22.40" |
Mark McCarthy
178mm (205x) |
A fine faint pair, noticable mag difference, wide about 5" |
Mark McCarthy
317mm (553x) |
Pumpkin orange pair, near equal magnitude, PA to north. Well separated ~4". Nice. |
STF1050 |
AB |
8m.1 |
8m.8 |
19.4" |
21° |
2020 |
Lyn |
07h19m51.29s / +54°55'18.40" |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Eher schwach, deutlich getrennt mit sichtbarem Helligkeitsunterschied. Eindruck ähnlich wie STF 1062. |
Robert Zebahl
Leipzig (Germany) |
102mm (28x) |
A2862 |
8m.4 |
9m.6 |
0.8" |
62° |
2017 |
CMi |
07h20m02.62s / +03°46'36.50" |
Mark McCarthy
203mm (333x) |
Very close, less than one disk width, 2 delta mag, light orange stars. Tough. Can't see B star at 667x |
STF1066, delta Gem, 55 Gem |
3m.5 |
8m.2 |
5.4" |
234° |
2017 |
Gem |
07h20m07.39s / +21°58'56.40" |
Robert Zebahl
Leipzig (Germany) |
55mm (71x) |
Sehr großer Helligkeitsunterschied. Die schwache Komponente war gut trennbar, aber nur als schwaches Sternchen sichtbar. |
Robert Zebahl
Leipzig (Germany) |
102mm (160x) |
Einfach zu trennen bei relativ großem Abstand. Der Begleiter erschien als feines, schwaches Sternchen. |
Winfried Kräling
Marburg (Germany) |
102mm (178x) |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
Nicht gesehen, wahrscheinlich ist der Begleiter zu schwach für leicht diesigen Himmel |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
erster Ring in SSW heller, zweiter nur an dieser Stelle sichtbar |
Mark McCarthy
178mm (205x) |
Bright light yellow A and much fainter light orange B, wide about 6". Physical |
Mark McCarthy
317mm (553x) |
Wasat = Delta Geminorum: Pretty white-yellow and red-orange pair, PA to west, ~4". |
A2863 |
9m.3 |
9m.5 |
1.2" |
288° |
2015 |
CMi |
07h20m09.95s / -00°01'11.50" |
Mark McCarthy
203mm (333x) |
White near equal, very fine pair in dense field |
STF1038 |
AB |
8m.2 |
10m.3 |
11.5" |
100° |
2017 |
Cam |
07h20m30.59s / +68°32'23.80" |
Robert Zebahl
Leipzig (Germany) |
70mm (57x) |
16.04.2020: Einfach zu trennen bei recht großem Helligkeitsunterschied. Der Begleiter erschien ziemlich schwach. |
STF1074 |
AB |
7m.4 |
7m.8 |
0.8" |
172° |
2015 |
CMi |
07h20m31.07s / +00°24'13.10" |
Mark McCarthy
203mm (333x) |
Very nice, touching disks to hairline. White, near equal. Great! [There are three other fainter BU pairs not noticed.] |
STF1073 |
7m.9 |
10m.2 |
9.0" |
67° |
2015 |
CMi |
07h21m00.62s / +10°11'44.20" |
Mark McCarthy
508mm (553x) |
Pretty pair, wide, ~3 delta mag, blue-white A and ruddy B |
STF1076 |
9m.5 |
9m.6 |
2.9" |
108° |
2015 |
CMi |
07h21m01.96s / +04°03'23.60" |
Mark McCarthy
203mm (333x) |
Very fine near equal white stars, well split |
STF1070 |
AB |
8m.7 |
9m.3 |
1.7" |
324° |
2019 |
Gem |
07h21m21.87s / +34°01'36.20" |
Mark McCarthy
178mm (205x) |
Seen at zenith, a fine white pair, 1 delta mag, about 3", nice |
Mark McCarthy
317mm (553x) |
Pretty close, 1.5", white, 1 delta mag, PA to NW. |
BU901, 65 Aur |
AB |
5m.1 |
11m.7 |
11.6" |
10° |
2015 |
Aur |
07h22m02.69s / +36°45'38.30" |
Mark McCarthy
178mm (148x) |
Light orange-yellow A, B appears widely separated with averted vision only, cant hold direct |
STF1065, 20 Lyn |
7m.5 |
7m.7 |
14.9" |
256° |
2017 |
Lyn |
07h22m15.11s / +50°08'55.70" |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Wunderschön getrennt, mäßiger Abstand, ähnlich hell. |
STF1062, 19 Lyn |
AB |
5m.8 |
6m.7 |
13.8" |
317° |
2019 |
Lyn |
07h22m52.06s / +55°16'53.30" |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Deutlich getrennt, moderater Abstand, erkennbarer Helligkeitsunterschied. Die Farben schienen verschieden, aber nicht genau definierbar. |
Robert Zebahl
Leipzig (Germany) |
102mm (28x) |
Uwe Pilz
Leipzig (Germany) |
105mm (21x) |
Robert Zebahl
Leipzig (Germany) |
152mm (22x) |
Einfach zu trennen, aber noch recht dicht zusammenstehend mit sichtbarem Helligkeitsunterschied. Farblich unauffällig. |
Mark McCarthy
178mm (148x) |
Bright, white, 1 delta mag, wide, parallax indicates physical |
J366 |
AB |
8m.9 |
10m.4 |
2.3" |
136° |
2015 |
CMi |
07h24m01.28s / +12°04'27.40" |
Mark McCarthy
508mm (533x) |
Pretty pairing, ~2.5", light yellow-orange A and a deepter yellow-orange B, 2 delta mag. Nice pair |
STF1081 |
AB |
7m.7 |
8m.5 |
1.9" |
234° |
2019 |
Gem |
07h24m08.94s / +21°27'28.00" |
AC |
7m.7 |
9m.9 |
107.0" |
63° |
2015 |
Robert Zebahl
Leipzig (Germany) |
102mm (28x) |
AC: Recht weit von der Komponente A entfernt mit deutlichem Helligkeitsunterschied. Eher unauffällig. |
Robert Zebahl
Leipzig (Germany) |
102mm (86x) |
AB: Bei 86x geradeso getrennt, sehr dicht zusammenstehend mit mäßigem Helligkeitsunterschied. In Bezug auf A stehen sich die Komponenten B & C fast gegenüber. Bei 125x sind A & B einfach zu trennen. |
Mark McCarthy
178mm (205x) |
AB: Very pretty blue-white A and slightly orange B, well separated about 2" |
A2865 |
10m.3 |
10m.6 |
0.6" |
107° |
1997 |
CMi |
07h24m40.32s / +05°16'51.00" |
Mark McCarthy
508mm (533x) |
At 533x i can tell is it not single, it's a bit smudgy, and with averted vision it clearly flashes an elongation. At 1067x I can't get a clean enough focus to resolve due to seeing |
J1063 |
10m.6 |
10m.9 |
2.6" |
56° |
2015 |
CMi |
07h25m19.23s / +03°12'10.70" |
Mark McCarthy
508mm (533x) |
B is on edge of direct vision, I can see some smudge there with direct vision but averted vision clears it up. ~2", 1.5 delta mag |
STF1083 |
7m.3 |
8m.1 |
6.9" |
226° |
2019 |
Gem |
07h25m35.30s / +20°29'42.60" |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Ungleiches Paar. Bei 22x sehr dicht zusammen, bei 44x wunderschön getrennt. Schwächere Komponente wirkte leicht orangefarben, hellere weiß-bläulich. |
Mark McCarthy
178mm (205x) |
White stars, wide, 1 delta mag. A nice, typical Struve |
HO346 |
AB |
7m.0 |
11m.7 |
13.2" |
59° |
2015 |
Gem |
07h25m54.13s / +18°08'51.00" |
Mark McCarthy
317mm (553x) |
Orange and much fainter blue B, ~10" 3 delta mag. Nice! |
STF1088 |
AB |
7m.4 |
9m.4 |
10.9" |
195° |
2015 |
Gem |
07h26m02.42s / +14°06'10.70" |
Mark McCarthy
178mm (205x) |
White A and two delta mag B, well separated |
STF1089 |
AB |
8m.9 |
8m.9 |
7.2" |
7° |
2015 |
Gem |
07h26m11.97s / +14°50'25.30" |
Mark McCarthy
178mm (205x) |
Near equal wide white, not physical |
STF1090 |
AB |
7m.3 |
8m.2 |
60.8" |
98° |
2017 |
Gem |
07h26m27.33s / +18°31'00.80" |
AC |
7m.3 |
9m.5 |
49.9" |
79° |
2015 |
BC |
8m.2 |
9m.5 |
20.9" |
328° |
2015 |
Christopher Hay
Seeheim (Germany) |
15x45 |
Fernglas mit interner Stabilisierung, handgehalten. AB sind gut getrennt. Erheblicher Helligkeitsunterschied. Ein physikalischer Doppelstern in 366 Lichtjahren Abstand zu uns. |
Mark McCarthy
317mm (553x) |
AC: Pretty finder split, equal white. Is a 2+1 with 2x fainter BC. |
Mark McCarthy
317mm (553x) |
BC: Is a 2+1 with AC, C is 2 delta mag than fainter B. |
A2866 |
9m.3 |
10m.0 |
0.6" |
138° |
1991 |
CMi |
07h26m39.08s / +04°23'34.10" |
Mark McCarthy
508mm (1067x) |
B seen only at the best moments, and very briefly as a very faint star ~0.5" sep and very much fainter than A star. Frustratingly tough since this should not be a problem usually except for tonight's poor transparency and average seeing |
STT171 |
7m.4 |
9m.2 |
1.0" |
138° |
2012 |
Gem |
07h26m39.61s / +31°37'11.90" |
Mark McCarthy
178mm (333x) |
! Exceptionally fine, with seeing, white A and bluish B, 2 delta mag, B appears as a very fine point at A's diffraction ring, less than 1". Suspected at 205x, best seen at 333x |
STF1095 |
8m.6 |
9m.3 |
10.3" |
78° |
2015 |
CMi |
07h27m22.75s / +08°45'14.00" |
Mark McCarthy
203mm (333x) |
White stars, wide, 1 delta mag |
STF1094 |
7m.6 |
8m.5 |
2.5" |
97° |
2019 |
Gem |
07h27m25.99s / +15°18'59.00" |
Robert Zebahl
Leipzig (Germany) |
70mm (57x) |
Bei 57x gerade noch trennbar mit deutlichem Helligkeitsunterschied. Bei 100x gut trennbar, aber noch immer recht dicht zusammen. |
Mark McCarthy
178mm (205x) |
White, 1.5 delta mag, about 2", nice and cleanly split |
S550 |
6m.9 |
7m.6 |
39.6" |
116° |
2019 |
CMa |
07h27m34.48s / -18°29'30.80" |
René Merting
12x42 |
ein bequem getrenntes Pärchen zweier fast gleich heller Sterne - B im Südosten ist eine viertel bis halbe Größenklasse schwächer und wirkt grauweiß, dadurch ein zarter Farbkontrast mit A |
ES2625 & S548 |
ES2625 |
AB |
7m.0 |
12m.4 |
11.9" |
24° |
2015 |
Gem |
07h27m40.54s / +22°08'29.30" |
S548 |
AC |
7m.0 |
8m.9 |
35.3" |
277° |
2019 |
Christopher Hay
Seeheim (Germany) |
15x45 |
S548 (AC): Fernglas mit interner Stabilisierung, handgehalten. Sauber getrennt. Begleiter sehr schwach. Hauptstern gelb-orange, ein Farbeindruck der (ohne Trennung) im handgehaltenen 7x45-Fernglas bestätigt wird. Zusammen mit Eskimo-Nebel (noch stellar) in 4,5° Gesichtsfeld. Ein physikalischer Doppelstern in 1199 Lichtjahren Abstand zu uns. |
René Merting
100mm (20x) |
S548 (AC): bei 32x ein weit getrenntes Paar - Komponente A strahlt schwach gelblich … eher dunkelgelb - Komponente C im Westen von A ist gut 1.5 Magnituden schwächer und dunkelgrau bis lachsorange - der Doppelstern steht isoliert, fällt aber nicht übermäßig auf - zurück auf 20x ist das Paar weiterhin gut getrennt erkennbar |
Uwe Pilz
Leipzig (Germany) |
105mm (88x) |
S548 (AC): bei 21x trennbar, orange und fahlblau |
Mark McCarthy
317mm (553x) |
S548 (AC): Orange with a 2x fainter white star, PA slightly SW. AB is 12th mag and not seen |
BU21, eta CMi |
5m.2 |
11m.1 |
4.3" |
28° |
2015 |
CMi |
07h28m02.08s / +06°56'31.50" |
Mark McCarthy
508mm (213x) |
Eta CMi: Easy bright yellowish star with a reddish much fainter B, wide |
BAL1098 |
9m.3 |
10m.8 |
6.6" |
122° |
2015 |
CMi |
07h28m12.83s / +00°35'16.90" |
Mark McCarthy
508mm (533x) |
Easy pair, creamy white A and 3 delta mag B, wide |
STF1086 |
8m.0 |
10m.1 |
12.2" |
104° |
2017 |
Aur |
07h28m31.32s / +42°45'09.00" |
Mark McCarthy
178mm (148x) |
Very light orange A and very light blue B, wide, 2 delta mag. Physical |
rho Gem, 62 Gem |
A2124 |
AB |
4m.2 |
12m.5 |
1.2" |
272° |
2006 |
Gem |
07h29m06.72s / +31°47'04.30" |
A2124 |
AC |
4m.2 |
11m.6 |
221.6" |
285° |
2001 |
ALC3 |
AE |
4m.2 |
7m.8 |
755.4" |
355° |
2001 |
A2124 |
CD |
11m.6 |
13m.4 |
102.1" |
271° |
2015 |
ALC7 |
EF |
7m.7 |
15m.4 |
2.8" |
-1° |
1991 |
Christopher Hay
Seeheim (Germany) |
7x45 |
AE: Komponente E ist ein feiner Lichtpunkt. Der Abstand zu A ist so groß, dass dieses Paar sich gar nicht wie ein Doppelstern ausnimmt. Umso interessanter ist es, sich vor Augen zu halten, dass dies ein physikalischer Doppelstern in unserer direkter galaktischer Umgebung in nur 59 Lichtjahren Abstand zu uns ist. ALC = Allen, C., im Jahr 2000 veröffentlicht. |
A2868 |
8m.6 |
9m.0 |
0.7" |
22° |
2015 |
Gem |
07h29m09.44s / +12°52'45.50" |
Mark McCarthy
178mm (333x) |
! Strongly notched to hairline at 205x, steady hairline split at 333x with seeing, very noticeable magnitude difference |
STF1102 |
AB |
7m.4 |
9m.2 |
7.7" |
45° |
2015 |
Gem |
07h30m26.25s / +13°51'54.00" |
AC |
7m.4 |
13m.2 |
21.8" |
77° |
2015 |
AD |
7m.4 |
8m.0 |
111.9" |
131° |
2015 |
BC |
9m.2 |
13m.2 |
15.9" |
91° |
2015 |
BE |
9m.2 |
12m.0 |
30.4" |
3° |
2015 |
Christopher Hay
Seeheim (Germany) |
7x45 |
AD: Handgehalten. Deutlich, fast schon weit, getrennt. Komponente A ist deutlich heller. Ein physikalischer Doppelstern in 148 Lichtjahren Abstand zu uns. |
Christopher Hay
Seeheim (Germany) |
15x45 |
AD: Fernglas mit interner Stabilisierung, handgehalten. Weit getrennt. Eine visuell starke Erscheinung bei dieser Vergrößerung. |
Mark McCarthy
178mm (205x) |
AB: Easy white A and ruddy B, wide, 1 delta. Physical |
STF1103 |
7m.1 |
8m.6 |
4.2" |
245° |
2020 |
CMi |
07h30m33.61s / +05°15'16.80" |
Uwe Pilz
Leipzig (Germany) |
105mm (137x) |
einfach, unscheinbar |
Mark McCarthy
317mm (170x) |
Pretty blue-white and orange-red stars, close but split. |
STF1106 |
9m.4 |
9m.5 |
10.7" |
35° |
2017 |
Gem |
07h31m21.02s / +16°18'38.60" |
Mark McCarthy
178mm (205x) |
Easy wide white pair, noticeable magnitude difference |
STF1108 |
6m.6 |
8m.2 |
11.7" |
179° |
2019 |
Gem |
07h32m50.63s / +22°53'15.40" |
Robert Zebahl
Leipzig (Germany) |
16x70 |
22.02.2021: Getrennt mit deutlich sichtbarem Helligkeitsunterschied. Die Hauptkomponente wirkte weißlich, der Begleiter erschien leicht abgesetzt nur als sehr schwaches Sternchen. |
René Merting
100mm (32x) |
bei 32x ein sehr ungleiches enges Paar, aber klar getrennt - Komponente B im Süden ist knapp zwei Größenklassen schwächer - Komponente A buttergelb - zurück auf 20x verschmilzt Komponente B förmlich mit A zu einer sehr ungleichen 8, in guten Momenten sind beide Sterne aber dennoch schon getrennt sichtbar |
Uwe Pilz
Leipzig (Germany) |
105mm (130x) |
einfach |
Mark McCarthy
178mm (205x) |
Very lightly yellow A and very light blue B, wide, 2 delta, a pretty pair |
BU22 |
AB |
8m.6 |
10m.9 |
6.3" |
151° |
2017 |
Gem |
07h33m14.80s / +32°51'42.60" |
Mark McCarthy
178mm (205x) |
Wide and uninteresting 2 delta mag |
STF1116 |
7m.8 |
8m.5 |
1.7" |
95° |
2019 |
Gem |
07h34m32.02s / +12°18'16.90" |
Mark McCarthy
317mm (553x) |
Pretty tight white, near equal magnitude, 2-3", PA to east. Nice pair. |
STF1110, alpha Gem, 66 Gem, Castor |
AB |
1m.9 |
3m.0 |
5.5" |
53° |
2019 |
Gem |
07h34m35.86s / +31°53'17.80" |
AC |
1m.9 |
9m.8 |
69.8" |
163° |
2017 |
AD |
1m.9 |
10m.1 |
179.8" |
221° |
2017 |
Christopher Hay
Seeheim (Germany) |
20x60 |
AB: Handgehalten im Liegestuhl, Fernglas mit interner Stabilisierung. 16. April 2022 (5,5" Distanz nach Datenbank): Deutlich gestreckt, wie ein längliches Rechteck an der Schwelle zu einer '8'. |
Christopher Hay
Seeheim (Germany) |
26x42 |
AB: 13. Mai 2022 (5.5" Distanz nach Datenbank). Mond vierfünftel-voll wenige Grad nördlich von Spica in der Jungfrau. 70mm-Fernglas auf 42mm Öffnung abgeblendet. Direkt nach Mondbeobachtung konnte ich Castor AB sicher trennen und die Trennung eine volle Minute halten, erst dann fing sie an, unsicher zu werden. Wiederholte die Beobachtung mehrfach, jedesmal mit sicherer Trennung. |
Christopher Hay
Seeheim (Germany) |
32x70 |
AB: 13. März 2022 (5.5" Distanz nach Datenbank): Mond nur 6° entfernt und zweidrittel-voll mitten in den Zwillingen. Nach konzentrierter Beobachtung des Mondes schwenkte ich schnell nach Castor um die kurzzeitig erhöhte Sehschärfe nach Betrachtung des hellen Mondes auszunutzen. Castor fein und klar getrennt mit schwarz zwischen A und B. Trennung wurde nach einer Weile schwieriger, konnte aber gehalten werden. Steckte zum Vergleich dasselbe Okular, welches ich im achromatischen 70/400 Fernglas verwendet hatte, in ein 71/400 Fluorit-Apo Teleskop, folglich wieder mit der Vergrößerung von 32x. Wieder konnte ich A und B direkt nach Mondbeobachtung trennen. Die Trennung war jedoch mit dem Mono-Apochromat schwieriger zu halten als zuvor mit dem Bino-Achromat. |
Christopher Hay
Seeheim (Germany) |
36mm (33x) |
AB: 16. April 2022 (5,5" Distanz nach Datenbank): Mit Polfilter des Typs Käsemann (KSM) bei 33x berühren sich die Beugungsscheibchen, scheinen in guten Momenten auseinander zu gehen, dies jedoch unsicher. Ohne Polfilter bei 33x nur eine gedrungene '8' weit von der Trennung entfernt. Mit Polfilter bei 40x eindeutig getrennt, hübscher erster Beugungsring der Komponente A. Ohne Filter eine gestreckte '8' ohne Trennung. Bei 50x klar und stabil getrennt mit und ohne Filter. Bei 66x bester Anblick, ein zartes Paar vor pechschwarzem Himmelshintergrund, die ersten Beugungsringe von A und B sich vereinigend, jener von B sehr schwach. Ähnliche Effekte im Vergleich zum KSM Polfilter bei 33x sowie 40x mit einem Baader Neodymium Filter, Klarheit der Trennung jedoch nicht ganz so gut wie mit dem Polfilter. |
Robert Zebahl
Leipzig (Germany) |
55mm (27x) |
AB: Bei 27x sichtbarer Helligkeitsunterschied. Doppelstern erscheint als '8'. Bei 38x klar getrennt, aber dicht zusammen. |
Robert Zebahl
Leipzig (Germany) |
70mm (44x) |
AB: Bei 44x als '8' sichtbar, bei 100x klar getrennt bei deutlichem Helligkeitsunterschied. Beide Komponenten wirkten weiß. |
Christopher Hay
Seeheim (Germany) |
76mm (50x) |
AB: 18. Februar 2021: Bei 23x oval-elongiert mit eindeutiger Position von A. Bei 50x fein getrennt. Bei 83x bester Anblick mit leichter Überlappung der ersten Beugungsringe. Bei 100x schönes Muster der Beugungsscheibchen und der überlappenden ersten und zweiten Beugungsringe beider Komponenten. |
René Merting
100mm (107x) |
AB: bei 32x wirkt der Stern leicht länglich - bei 107x stehen die beiden Sterne schön eng mit überlagernden Beugungsscheibchen, die Komponenten sind dennoch getrennt erkennbar - Komponente B im Osten ist eine halbe Magnitude schwächer - ganz schwacher Farbkontrast |
Uwe Pilz
Leipzig (Germany) |
105mm (144x) |
AB: blauweiß-weiß |
Winfried Kräling
Marburg (Germany) |
127mm (250x) |
AB: 13.03.2017: Beide Komponenten gelblich mit geringem Helligkeitsunterschied, bereits bei V=60x getrennt. |
Mark McCarthy
178mm (205x) |
AB: Castor. A is a very pale yellow and B is yellow-green, 2 delta mag, very bright, pretty wide, some fainter stars about. Physical with a 459.8-year period |
Christopher Hay
Seeheim (Germany) |
180mm (200x) |
AB: Zwei fette Scheinwerfer im All. Komponente B scheint auf den ersten Blick grünlich (farbreine Spiegeloptik), jedenfalls eine andere Tönung als Komponente A. Die zweiten Beugungsringe von A und B vereinigen sich. |
Frederik Wanink
Itterbeck (Germany) |
254mm |
AB |
HJ425 |
BC |
11m.1 |
11m.4 |
8.5" |
46° |
2015 |
Gem |
07h34m59.31s / +24°14'23.50" |
Mark McCarthy
178mm (205x) |
A component of STF1113 AB. A is light yellow-orange, BC is widely separated from A, itself a pretty wide pair of blue stars. Physical |
MAD3 |
9m.9 |
9m.9 |
3.7" |
120° |
2019 |
Lyn |
07h35m45.61s / +43°02'05.30" |
Mark McCarthy
178mm (333x) |
Very faint equal pair near STT 174, amazingly not physical |
STT174 |
6m.6 |
8m.3 |
1.9" |
92° |
2017 |
Lyn |
07h35m56.00s / +43°01'51.40" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
Die deutlich schwächere Komponente konnte im richtigen Positionswinkel dauerhaft als Aufhellung auf dem ersten Beugungsring gesehen werden. |
Mark McCarthy
178mm (333x) |
Lovely white and dull blue, 2 delta mag and 2" separation. Faint pair MAD 3 in same FOV making a double-double |
KU30 |
9m.3 |
10m.3 |
3.2" |
111° |
2015 |
Gem |
07h35m59.79s / +34°19'41.10" |
Mark McCarthy
203mm (205x) |
About one delta mag, well split, slightly orange stars |
STF1120 |
AC |
5m.6 |
9m.7 |
19.8" |
37° |
2015 |
Pup |
07h36m03.89s / -14°29'33.90" |
René Merting
12x42 |
trotz größter Konzentration schwierig - C scheint wie ein Spike an A zu kleben - eine Trennung ist trotz 19,8" Abstand nicht möglich, vermutlich weil der Helligkeitsunterschied zwischen beiden Sternen von 4.1 mag zu groß ist |
STF1121 |
AB |
6m.9 |
7m.3 |
7.4" |
306° |
2019 |
Pup |
07h36m36.06s / -14°29'03.70" |
Robert Zebahl
Leipzig (Germany) |
152mm (30x) |
Fantastischer Anblick des Doppelsterns inmitten des schönen Sternhaufens Messier 47! Hell, moderater Abstand mit geringem Helligkeitsunterschied. |
STF1119 |
8m.1 |
9m.3 |
3.3" |
353° |
2019 |
Gem |
07h38m30.23s / +33°42'41.40" |
Mark McCarthy
203mm (205x) |
V345 Gem, variable of the delta Scuti type. A is white with a pink tinge. B is light blue, about two delta mag, well split around 3" |
BRD2 |
AB |
9m.2 |
9m.5 |
0.9" |
188° |
2015 |
CMi |
07h39m46.65s / +05°16'25.50" |
Mark McCarthy
203mm (333x) |
Wow! Exceptionally fine pair, white, near equal, nicely split, just outside of Procyon's glare. Great! [AB,C 14th mag not seen] |
BGH3 |
AB |
7m.3 |
9m.0 |
57.9" |
113° |
2017 |
Mon |
07h39m59.33s / -03°35'51.00" |
René Merting
18x70 |
beide Komponenten sind mit ordentlichem Abstand getrennt sichtbar - Komponente B im SO ist gut 1.5 Magnituden schwächer und wirkt gegen die strahlend weiße Komponente A eher graubraun |
STF1126 |
AB |
6m.5 |
7m.0 |
0.9" |
176° |
2019 |
CMi |
07h40m06.99s / +05°13'51.90" |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
beide gelb. Es war schwierig, die hellere Komponente zu erkennen. Direkt neben Prokyon. |
Mark McCarthy
317mm (553x) |
Wow, very close <1" hair-split, near equal brightness |
AG143 |
9m.1 |
10m.1 |
5.7" |
98° |
2015 |
CMi |
07h41m10.49s / +01°08'18.10" |
Mark McCarthy
203mm (333x) |
Pretty orange and blue, light colors, wide, faint |
AG142 |
9m.8 |
10m.4 |
1.7" |
21° |
2000 |
Gem |
07h41m26.46s / +23°11'40.70" |
Mark McCarthy
178mm (205x) |
Very fine close pair, 1 delta mag, B brightens with averted vision but can see it direct |
STF1123 |
9m.2 |
9m.8 |
3.6" |
167° |
2019 |
Gem |
07h41m31.99s / +33°24'34.80" |
Mark McCarthy
203mm (205x) |
Pretty white pair, ~3", slightly less than two delta mag |
STF1132 |
8m.1 |
8m.5 |
20.1" |
235° |
2017 |
Mon |
07h42m12.50s / -03°31'10.40" |
René Merting
18x70 |
ein dicht stehendes Pärchen - Komponente B im SW ist nur leicht schwächer - leichter Farbunterschied - STF1132 fällt eher als Doppelstern auf als der ebenfalls weiter westlich im Gesichtsfeld stehende Doppelstern Bgh |
STT179, kappa Gem, 77 Gem |
3m.7 |
10m.0 |
7.2" |
243° |
2019 |
Gem |
07h44m26.87s / +24°23'53.30" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
Beobachtung bei nahezu Vollmond: Schwächere Komponente war einfach nicht sichtbar. |
René Merting
100mm (213x) |
bei 213x mit viel Geduld ist blickweise Komponente B südwestlich von A im Beugungsscheibchen erkennbar - kaum wie ein Stern, einfach nur eine schwache Aufhellung |
Robert Zebahl
Leipzig (Germany) |
120mm (200x) |
Obwohl die Optik noch nicht vollständig ausgekühlt war, konnte die schwächere Komponente etwas außerhalb des ersten Beugungsrings als kleines Sternchen in Momenten ruhiger Luft gesehen werden. |
Mark McCarthy
508mm (533x) |
Kappa Gem. A looks like a kaleidoscope with the mask, colorful. B is a nice fine 8th mag star, a white hard point. Well separated ~8" |
A674 |
8m.2 |
9m.8 |
1.1" |
125° |
2008 |
Gem |
07h44m38.11s / +31°06'50.10" |
Mark McCarthy
317mm (553x) |
Very close and faint, just split |
STF1107 |
8m.7 |
10m.1 |
1.2" |
213° |
1991 |
Cam |
07h45m14.87s / +75°47'51.40" |
Mark McCarthy
317mm (553x) |
Wide separation, 1 delta mag, PA to NW. |
STF1138, 2 Pup |
AB |
6m.0 |
6m.7 |
16.7" |
341° |
2019 |
Pup |
07h45m29.14s / -14°41'25.70" |
René Merting
12x42 |
ein sehr helles Pärchen - B steht im Norden und ist ganz knapp getrennt von A erkennbar - Helligkeitsunterschied eine halbe Magnitude |
HO246 |
7m.6 |
11m.6 |
2.6" |
227° |
1991 |
Gem |
07h45m32.14s / +25°59'19.20" |
Mark McCarthy
508mm (533x) |
A is an orange star, pretty bright, B only shows with averted vision and I can barely it hold direct. ~2". white |
STF1122 |
7m.8 |
7m.8 |
14.4" |
185° |
2017 |
Cam |
07h45m52.47s / +65°09'28.10" |
René Merting
18x70 |
ein genialer, heller Stern für 18x-Ferngläser - ein wunderschönes enges Sternpaar, wo drei Blatt Papier dazwischen passen |
Robert Zebahl
Leipzig (Germany) |
70mm (31x) |
15.04.2020: Bei 22x sofort auffällig bei schönem Abstand der gleich hellen Komponenten. Eine Komponente wirkte leicht bläulich, die andere hellorange. Bei 44x ist der dezente Farbunterschied noch etwas besser zu sehen. Der Doppelstern befindet sich in schönem Sternfeld zusammen mit 51 Cam. |
René Merting
320mm (45x) |
bei 72x ein gut getrenntes Pärchen zweier gleich heller Sterne - trotz vieler gleich heller Sterne im Gesichtsfeld wirkt das Doppel gut isoliert |
HO247 |
7m.7 |
9m.2 |
0.4" |
259° |
2010 |
Gem |
07h46m07.95s / +21°07'19.20" |
Mark McCarthy
508mm (533x) |
Clean split with seeing, 1 delta mag, fairly bright pair. I found the apodizing mask worked better than the 8-inch mask, gave more resolving power. The 8-inch was only snowman |
STF1137 |
8m.0 |
9m.1 |
2.9" |
133° |
2010 |
CMi |
07h46m35.35s / +04°07'50.10" |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
Der schwächere Stern ist nur indirekt sichtbar, deshalb schwierig |
Mark McCarthy
203mm (333x) |
Light orange and blue, pretty wide, 1.5 delta mag |
STF1127 |
AB |
7m.0 |
8m.4 |
5.6" |
340° |
2019 |
Cam |
07h47m00.43s / +64°03'07.30" |
AC |
7m.0 |
9m.7 |
11.6" |
178° |
2019 |
BC |
8m.4 |
9m.7 |
16.9" |
173° |
2019 |
René Merting
18x70 |
AC: von den Rahmendaten ist eine Trennung von A und C eigentlich möglich, aber vermutlich ist der Helligkeitsunterschied zwischen beiden Sternen von 2.7 mag zu groß - ich konnte C nicht entdecken |
Robert Zebahl
Leipzig (Germany) |
70mm (57x) |
15.04.2020: Bei 31x alle drei Komponenten sichtbar, wobei B noch sehr dicht an der Komponente A steht. Komponente C ist insgesamt recht schwach. Bei 57x wirkt A weiß-gelblich, B leicht orange. |
René Merting
320mm (45x) |
AB: bei 45x ist B ganz dicht nördlich an A angrenzend erkennbar (knapp getrennt), B etwas heller als C im Süden - bei 72x wird die Trennung einfacher und alle drei Sterne stehen fast auf einer Linie AC: bei 45x ist C ganz schwach südlich von A erkennbar - bei 72x schätze ich, etwas mehr als die doppelte Entfernung AB, C wirkt grau, während A und B weiß strahlen |
PTT11 |
9m.1 |
10m.4 |
4.6" |
6° |
2017 |
Lyn |
07h47m02.38s / +38°32'22.50" |
Mark McCarthy
178mm (205x) |
Faint pair white, B flashes brighter with averted vision. New designation, E. Pettit, active in the early 20th century |
STF1141 |
AB |
8m.4 |
9m.4 |
17.5" |
10° |
2017 |
CMi |
07h47m02.47s / +00°01'06.10" |
René Merting
18x70 |
AB: ganz dicht nördlich über Komponente A ist B knapp getrennt als schwaches Murmelchen sichtbar, Helligkeitsunterschied schätzungsweise 1.5 Magnituden AD: nordöstlich von A in vierfachem Abstand AB ist Komponente D als schwaches Lichtpünktchen D erkennbar AE: Komponente E zeigt sich westlich von Komponente A in drei- bis vierfacher Entfernung wie AB, schwach |
René Merting
100mm (32x) |
AB: Komponente B zeigt sich mehr als knapp getrennt nördlich von A - Komponente A ist doppelt so hell wie B AD: Komponente D ist mir nordöstlich in vierfachem Abstand AB auch noch aufgefallen und ich konnte drei bis vier weitere schwache Sterne erkennen, sicherlich alles weitere Komponenten dieses Mehrfachsystems |
COU772 |
9m.0 |
9m.2 |
0.3" |
75° |
2011 |
Gem |
07h47m07.07s / +18°47'19.20" |
Mark McCarthy
508mm (667x) |
A most excellent, barest hairline split of white stars with significant magnitude. Suspected with 333x, needed 667x for a clean view. Very nice |
HO36 |
9m.8 |
9m.9 |
0.6" |
306° |
2008 |
Gem |
07h47m34.74s / +25°28'08.90" |
Mark McCarthy
508mm (533x) |
Very finely split blue-white stars, very slight mag difference. Pretty tough |
AGC2 |
7m.8 |
9m.7 |
1.0" |
116° |
1991 |
Gem |
07h47m58.47s / +28°40'02.70" |
Mark McCarthy
508mm (533x) |
Light orange-yellow A, B is very fine, almost 3 delta mag, nearly 1", very nice pair |
STF1140 |
7m.0 |
8m.7 |
6.4" |
273° |
2015 |
Gem |
07h48m22.61s / +18°20'12.40" |
Robert Zebahl
Leipzig (Germany) |
70mm (44x) |
Einfach zu trennen bei recht deutlichem Helligkeitsunterschied. |
Mark McCarthy
508mm (205x) |
Easy pair, light orange A and light blue B, 1 delta mag, wide ~8" |
WRH15, 82 Gem |
AB |
6m.8 |
7m.3 |
0.3" |
28° |
2016 |
Gem |
07h48m33.65s / +23°08'27.50" |
Mark McCarthy
508mm (1067x) |
82 Gem. I see an elongated misshape, PA to the NNE, but not firm. Physical with a 580-year period. R.H. Wilson |
STTA88 |
AB |
7m.5 |
8m.9 |
57.1" |
6° |
2015 |
CMi |
07h48m58.22s / +00°39'42.90" |
AC |
7m.5 |
10m.8 |
95.8" |
51° |
2015 |
René Merting
18x70 |
AB: ein einfacher Fernglas-Doppelstern - beide Komponenten sind gut sichtbar, weit getrennt voneinander - Komponente B im Norden ist gut 1.5 Magnituden schwächer - leichter Farbkontrast |
René Merting
100mm (20x) |
AB: bei 32x ein mehr als bequem getrenntes Paar - Komponente B im Norden ist halb so hell wie A - zurück auf 20x weiterhin eine ordentliche Trennung |
STF1144 |
AB |
7m.9 |
10m.3 |
8.4" |
358° |
2018 |
Gem |
07h49m00.84s / +28°34'26.40" |
Mark McCarthy
203mm (205x) |
Fine pair, Bis a nice sharp hard point, very much fainter than yellowish A, widely separated ~8" |
STF1149 |
7m.8 |
9m.2 |
21.7" |
41° |
2017 |
CMi |
07h49m29.79s / +03°13'15.60" |
René Merting
100mm (32x) |
bei 32x zeigt sich Komponente B gut getrennt nordöstlich von A - Helligkeitsunterschied 1.5 Magnituden |
STF1147 |
9m.7 |
9m.7 |
2.2" |
175° |
2019 |
Gem |
07h50m19.69s / +24°31'55.80" |
Mark McCarthy
508mm (533x) |
Nice near equal blue-white stars, wide ~2.5" [not physical, surprisingly] |
COU926 |
9m.5 |
9m.7 |
0.3" |
254° |
2008 |
Gem |
07h50m38.16s / +19°44'04.20" |
Mark McCarthy
508mm (533x) |
Very tentative notched, noticable mag difference, only with seeing. Can't go to higher mag due to seeing |
STTA89 |
6m.8 |
7m.7 |
76.6" |
84° |
2017 |
Gem |
07h51m00.20s / +31°36'48.70" |
Christopher Hay
Seeheim (Germany) |
7x45 |
Handgehalten. Deutlich getrennt. Hauptkomponente ist deutlich heller. Schöner Anblick in 8,6° Gesichtsfeld mit Castor und Pollux, mit denen STTA89 ein fast gleichschenkliges Dreieck bildet. Ein physikalischer Doppelstern in 660 Lichtjahren Abstand zu uns. |
Christopher Hay
Seeheim (Germany) |
20x60 |
Handgehalten im Liegestuhl, Fernglas mit interner Stabilisierung. Ein sehr attraktives, weites Paar mit zartem Farbkontrast, blau-orange. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Bei 22x weit getrennt mit mäßigem Helligkeitsunterschied. Die Hauptkomponente erschien weißlich, bei 44x eher weiß-gelblich. Der Begleiter wirkte leicht orangefarben. |
BU101, 9 Pup |
5m.6 |
6m.5 |
0.4" |
307° |
2019 |
Pup |
07h51m46.31s / -13°53'52.80" |
Mark McCarthy
508mm (1067x) |
9 Pup. Elongated to notched, orientation correct, light orange. Very tough. [B is coming off it's furthest orbit and will be exceptionally difficult in 10 years, but easier in 15 years] |
AG144 |
AB |
9m.7 |
11m.1 |
11.6" |
334° |
2015 |
Gem |
07h51m54.12s / +22°15'26.50" |
Mark McCarthy
178mm (205x) |
Wide white stars, significant delta mag, B brightens with averted vision. Not physical |
COU928 |
9m.2 |
9m.7 |
5.6" |
99° |
2019 |
Gem |
07h52m40.85s / +20°02'37.70" |
Mark McCarthy
508mm (533x) |
A is a light yellow-orange, easily 1 delta mag brighter than blue B. Wide, ~10" |
STT182 |
7m.8 |
7m.9 |
0.9" |
9° |
2017 |
CMi |
07h52m42.12s / +03°23'02.20" |
Mark McCarthy
203mm (333x) |
Compact white pair, more near equal than Sky Tools says, white, easy split |
Mark McCarthy
317mm (553x) |
Very close, ~1", near equal brightness white. |
WEI17 |
9m.0 |
9m.3 |
7.0" |
96° |
2017 |
Gem |
07h54m02.88s / +14°56'54.10" |
Mark McCarthy
508mm (533x) |
Dual ninth mag pair, white, slight mag difference, very wide |
COU951 |
9m.9 |
10m.7 |
3.1" |
134° |
2017 |
Gem |
07h54m13.96s / +27°53'02.40" |
Mark McCarthy
203mm (205x) |
Difficult given poor seeing and transparency this night. A is considerably more bright about half delta than B, white stars, split |
A2536 |
10m.4 |
10m.6 |
0.9" |
309° |
2001 |
Gem |
07h54m36.67s / +25°12'48.40" |
Mark McCarthy
178mm (333x) |
Very significant delta mag, very close, it's an elongated haze until seeing settles then can I can resolve and split the faint B from white A |
ES422 |
8m.4 |
10m.8 |
14.9" |
182° |
2015 |
Gem |
07h55m27.26s / +29°09'30.70" |
Mark McCarthy
203mm (205x) |
B revealed with averted vision only, clearly seen with averted vision with yellowish A, pretty wide |
STF1158 |
AB |
9m.3 |
9m.3 |
7.6" |
334° |
2016 |
Gem |
07h56m31.40s / +21°52'28.60" |
Mark McCarthy
178mm (205x) |
Dim for a Struve, wide, one delta mag. Not physical |
STT185 |
7m.1 |
7m.3 |
0.4" |
21° |
2019 |
CMi |
07h57m16.39s / +01°07'37.30" |
Mark McCarthy
508mm (1067x) |
Without the apodizing mask I get a clean split with seeing but constant split with the mask. Light orange stars, noticeable mag difference |
STF1162 |
8m.0 |
10m.2 |
9.0" |
327° |
2015 |
Cnc |
07h57m22.66s / +13°12'24.70" |
Mark McCarthy
317mm (553x) |
Orange and blue, pretty wide. |
Karsten Kopp
Köln (Germany) |
600mm (135x) |
Einfacher Doppelstern mit klarem Helligkeitsunterschied, wobei Komponente A leicht gelblich leuchtet. |
STF1167 |
9m.8 |
11m.8 |
12.2" |
229° |
2015 |
Cnc |
07h58m34.29s / +16°28'09.30" |
Mark McCarthy
317mm (553x) |
Very faint pair, B seen with averted vision and seeing. 2 delta mag, near a bright star. |
Karsten Kopp
Köln (Germany) |
600mm (135x) |
Einfach zu trennder Doppelstern mit klarem Helligkeitsunterschied. |
STF1161 |
8m.2 |
9m.8 |
2.9" |
198° |
2019 |
Lyn |
07h59m40.77s / +46°37'12.20" |
Mark McCarthy
178mm (148x) |
White and light orange stars, 1 delta mag, well split |
STF1170 |
8m.7 |
9m.1 |
2.4" |
108° |
2019 |
Cnc |
07h59m45.52s / +13°41'19.90" |
Mark McCarthy
178mm (205x) |
Lovely close split, white stars, near equal |
Mark McCarthy
317mm (553x) |
Close near equal pair, 2". |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Noch gut zu trennender Doppelstern mit nur leichtem Helligkeitsunterschied. Der hellere Stern geht leicht ins gelbliche. |
A2954 |
AB |
8m.4 |
9m.0 |
0.6" |
338° |
2016 |
Cnc |
08h00m27.88s / +09°54'49.00" |
Mark McCarthy
178mm (205x) |
Hairline split with seeing, significant magnitude difference, white stars |
STF1171 |
6m.5 |
9m.9 |
2.0" |
326° |
2015 |
Cnc |
08h01m00.78s / +23°34'59.20" |
René Merting
100mm (213x) |
bei 142x schmiegt sich Komponente B an der Grenze zur Sichtbarkeit im Süden von Komponente A ganz dicht an den viel größeren Bruder, der ohne Beugungsringe auskommt - bei 213x zeigt sich B leicht abgesetzt von A |
Robert Zebahl
Leipzig (Germany) |
102mm (187x) |
Beobachtung aus der Stadt heraus bei Halbmond. Bei Vergrößerungen zwischen 187x und 280x konnte ich den sehr schwachen Begleiter nahezu dauerhaft nahe des ersten Beugungsrings sehen. Der Beugungsring selbst war allerdings kaum sichtbar. Hauptproblem hier war vermutlich die geringe Helligkeit des Begleiters. |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
schwierig. Zu ahnen bei 144x |
Mark McCarthy
178mm (205x) |
Very tough for a Struve. B is very faint and comes to view only with seeing as a very fine point, pretty well separated from A, but A needs to be a disk for B to resolve out of the diffraction. Seen fleetingly, somewhat better with averted vision but averted vision often misses moments of best seeing. Physical |
Mark McCarthy
317mm (553x) |
Yellow and orange, 4 delta mag! very faint and close B |
STF1173 |
AB |
8m.5 |
9m.9 |
10.4" |
51° |
2015 |
Cnc |
08h01m23.12s / +16°56'58.00" |
Mark McCarthy
178mm (148x) |
Wide and pretty faint for a Struve, white stars. Physical |
Mark McCarthy
317mm (553x) |
Wide, pretty faint |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Gut zu trennender Doppelstern. |
SHJ86 |
AB |
6m.2 |
7m.5 |
51.6" |
81° |
2019 |
Cam |
08h02m30.82s / +63°05'25.20" |
René Merting
320mm (45x) |
bei 45x weit getrennt - Komponente A ist samtgelb, B strahlt weiß - trotzdem beide Sterne weit auseinander stehen, sind sie als Sternpaar erkennbar, weil die Sterne im unmittelbaren Umfeld allesamt schwächer sind |
HO349 |
AB |
7m.7 |
12m.0 |
10.3" |
227° |
2015 |
Cnc |
08h02m32.77s / +12°27'08.10" |
Mark McCarthy
317mm (553x) |
Light orange star and extremely faint B star, a fuzz at the edge of visibility in the correct position angle, ~10" separation |
Karsten Kopp
Köln (Germany) |
600mm (257x) |
Doppelstern konnte gerade noch gut getrennt werden, wobei hier der Helligkeitsunterschied von 4,5 mag bzw. der schwächere Stern, welcher an der Wahrnehmungsgrenze liegt, die Herausforderung darstellen. |
ES291 |
8m.6 |
11m.8 |
6.4" |
348° |
2017 |
Gem |
08h02m44.02s / +32°11'09.10" |
Mark McCarthy
203mm (205x) |
B seen with averted vision only, but flashed out clearly. Wide, ~7" |
STT186 |
7m.7 |
7m.9 |
1.1" |
75° |
2019 |
Cnc |
08h03m18.52s / +26°16'03.50" |
Mark McCarthy
178mm (205x) |
Beautiful hairline split, white stars, around 1 delta mag and 1". Great pair |
Mark McCarthy
317mm (553x) |
Close, 1" but easy split, near equal dull white color. |
HO350 |
6m.8 |
10m.8 |
7.6" |
160° |
2015 |
Cnc |
08h03m28.73s / +12°10'52.60" |
Mark McCarthy
178mm (222x) |
B is pretty faint and wide |
BU581 |
AB |
8m.5 |
8m.8 |
0.4" |
226° |
2018 |
Cnc |
08h04m23.10s / +12°17'23.80" |
Mark McCarthy
317mm (553x) |
Light orange near equal, very small, elongated to notched. |
Mark McCarthy
508mm (1067x) |
With apodizing mask. Beautiful clean split, almost wide, light orange stars, slight mag difference. There is a third 2x fainter star further out, might be plus one. Wow. [3rd is AB-C, 8.46/11.78 5.5"] |
STF1172 |
7m.9 |
9m.6 |
1.7" |
244° |
2017 |
Lyn |
08h04m36.98s / +54°44'46.00" |
Mark McCarthy
178mm (148x) |
Very pretty, finely split white stars, 2 delta mag, about 2" separated |
AG337 |
9m.9 |
10m.2 |
2.7" |
104° |
2015 |
Gem |
08h05m05.60s / +28°27'22.50" |
Mark McCarthy
203mm (205x) |
Split, very close near equal orange-yellow stars |
STF1182 |
7m.5 |
8m.8 |
4.9" |
75° |
2019 |
CMi |
08h05m24.43s / +05°49'38.90" |
Mark McCarthy
203mm (333x) |
A white, B a little ruddy, wide, 2 delta mag |
Mark McCarthy
317mm (553x) |
White and reddish, 1 delta mag, PA due east. |
STF1181 |
8m.3 |
9m.3 |
5.2" |
141° |
2019 |
Cnc |
08h05m24.56s / +08°11'58.70" |
Mark McCarthy
317mm (553x) |
Orange and blue, 3 delta mag, wide separation. |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Gut zu trennender Doppelstern, mit gut erkennbaren Helligkeitsunterschied von über 1 mag. Der hellere Stern leuchtet gelblich orange und der schwächere leicht bläulich. |
STF1177, 17 Cnc |
6m.7 |
7m.4 |
3.5" |
350° |
2019 |
Cnc |
08h05m37.06s / +27°31'46.90" |
Robert Zebahl
Leipzig (Germany) |
70mm (57x) |
Einfach zu trennen, aber noch relativ dicht zusammenstehend. Gut sichtbarer Helligkeitsunterschied. Farbe der Komponenten war nicht erkennbar. Insgesamt schöner Anblick. |
René Merting
100mm (64x) |
bei 107x sehe ich ein knapp getrenntes schön eng stehendes Pärchen - Komponente B im Norden ist eine dreiviertel Größenklasse schwächer - das Weiß von A wirkt kühler - zurück auf 64x sehe ich eine Ameise mit dünnem Hals, in ruhigen Momenten zeigen sich beide Sterne sogar getrennt |
Uwe Pilz
Leipzig (Germany) |
105mm (144x) |
Uwe Pilz
Leipzig (Germany) |
105mm (180x) |
Blau und Orange - sehr schöner Farbkontrast, unterstützt durch die ähnliche Helligkeit |
Christopher Hay
Seeheim (Germany) |
125mm (160x) |
Gut getrennt trotz erheblicher Luftunruhe. Hauptstern cremig gelb-weiss, Begleiter zartblau. Ein sehr schöner Farbkontrast, der mindestens einen Bewertungs-Stern verdient. |
Mark McCarthy
178mm (205x) |
Excellent, around 1 delta mag and wide, blue-white stars, nicely resolved |
Frederik Wanink
254mm (640x) |
getrennt |
Mark McCarthy
317mm (553x) |
Yellowish, 1 delta mag, ~4" |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Gut zu trennender Doppelstern, mit gut erkennbaren Helligkeitsunterschied . Der hellere Stern leuchter weiß-gelblich, während der schwächere leicht bläulich schimmert. Schöner Farbkontrast |
WFC61 |
8m.4 |
9m.5 |
10.5" |
34° |
2015 |
Cnc |
08h06m07.62s / +14°15'01.60" |
Mark McCarthy
178mm (148x) |
Nice wide 1 delta mag white stars. Physical |
STF1186 |
7m.1 |
10m.1 |
3.3" |
212° |
2018 |
Cnc |
08h08m49.61s / +27°28'49.40" |
Mark McCarthy
178mm (205x) |
Really nice, very large delta mag of about 3, about 3", white stars, large round disk for the A star and tiny point for B |
Mark McCarthy
317mm (553x) |
11 Cnc: Orange with very faint B, ~3" |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Noch gut zu trennender Doppelstern, wobei hier der Helligkeitsunterschied von ca. 3 mag und der Abstand von 3,1" der hellere Stern den schwächeren fast zu überstrahlen droht. Komponente A leuchtet gelblich orange. |
STF1188 |
8m.7 |
9m.3 |
16.4" |
201° |
2020 |
Cnc |
08h09m23.95s / +30°20'49.30" |
Mark McCarthy
317mm (553x) |
Wide separation, near equal white. |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Leicht zu trennender Doppelstern mit leichtem Helligkeitsunterschied von vielleicht 0,5 mag. |
STF1187 |
AB |
7m.2 |
8m.0 |
3.1" |
20° |
2019 |
Cnc |
08h09m30.45s / +32°13'18.80" |
Robert Zebahl
Leipzig (Germany) |
70mm (57x) |
Getrennt. Komponenten sehr dicht zusammenstehend bei deutlichem Helligkeitsunterschied. |
Mark McCarthy
178mm (205x) |
White stars, a little more than 1 delta mag, wide about 4". Physical with a 1385.156-year period |
Mark McCarthy
317mm (553x) |
Yellow and orange, 1 delta mag, 5" |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Noch gut zu trennender Doppelstern mit leichtem Helligkeitsunterschied. Komponente A leuchtet gelblich weiß und Komponente B gelb. |
A1335 |
AB |
7m.6 |
10m.8 |
1.3" |
236° |
1996 |
Lyn |
08h10m12.57s / +55°48'15.50" |
Mark McCarthy
178mm (222x) |
Very delicate B next to bright A, 1". B is just a tiny fleck, best at lower powers so a glare doesn't overpower it. Physical |
BUP111 |
AB |
6m.6 |
9m.3 |
80.9" |
49° |
2016 |
Cnc |
08h10m13.10s / +25°50'40.10" |
Mark McCarthy
317mm (553x) |
13 Cnc. Wide separation, orange A. |
STF1191 |
10m.3 |
10m.8 |
3.6" |
77° |
2015 |
Cnc |
08h10m47.59s / +19°01'51.90" |
Mark McCarthy
317mm (553x) |
Very faint but well split, ~3", near equal pair |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Noch gut zu trennender Doppelstern, mit leichtem Helligkeitsunterschied. |
HJ777 |
AB |
9m.6 |
11m.7 |
10.6" |
349° |
2016 |
Cnc |
08h11m29.33s / +10°41'05.40" |
Mark McCarthy
317mm (553x) |
Very wide, faint |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Doppelstern einfach zu trennen, wobei der Helligkeistunterschied schon recht groß und Komponente B recht schwach ist. |
zeta Cnc, 16 Cnc |
STF1196 |
AC |
5m.3 |
5m.8 |
6.2" |
62° |
2020 |
Cnc |
08h12m12.79s / +17°38'51.20" |
STF1196 |
AB-C |
4m.9 |
5m.8 |
6.0" |
64° |
2020 |
STF1196 |
AB |
5m.3 |
6m.2 |
1.0" |
5° |
2020 |
HUT1 |
Ca-Cb |
6m.2 |
7m.1 |
0.3" |
32° |
2019 |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
Das weite Paar AB-C ist bereits bei 22x trennbar. Das Paar AB zeigt dagegen bei 133x zwei sich deutlich überlappende Beugungsscheibchen mit geringem Helligkeitsunterschied, allerdings ohne Einschnürung. |
Christopher Hay
Seeheim (Germany) |
71mm (32x) |
AB-C: Fein getrennt. AB gelblich. Erheblicher Helligkeitsunterschied. |
Robert Zebahl
Leipzig (Germany) |
102mm (86x) |
AB-C: Einfach trennbar. A: helles Grau, B: blasses Orange. |
Stefan Loibl
Rosenheim (Germany) |
102mm (164x) |
AB-C leicht trennbar, AB deutlich elongiert aber nicht getrennt |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
weißblau-gelb-gelb |
Robert Zebahl
Leipzig (Germany) |
120mm (67x) |
AB-C: Deutlicher Helligkeitsunterschied, einfach zu trennen. Farbe beider Komponenten ähnlich. |
Robert Zebahl
Leipzig (Germany) |
120mm (200x) |
AB: Sehr dicht zusammen. Die Beugungsscheibchen berührten sich noch. Leichter Helligkeitsunterschied erkennbar. Extrem schöner Dreifachstern! |
Winfried Kräling
Marburg (Germany) |
127mm (250x) |
08.04.2018: Sehr schön, 3-fach Stern, A = weißgelb, B = weißgelb, C = weißgelb |
Sarah Gebauer
Germany |
150mm (83x) |
AB-C: bei 83x sind AB-C sauber getrennt, laut Atlas 2020 6,1'' Abstand, die Komponenten A und B mit 1,1'' lassen sich nicht trennen, viele schöne Feldsterne dabei |
Christopher Hay
Seeheim (Germany) |
180mm (200x) |
AB: Haarfein getrennt. A und B gelblich-weiss. C weit von AB abgesetzt, blau-weiss, schöner Farbkontrast zu AB. |
Frederik Wanink
254mm (200x) |
AB-C: AB (1,1") nicht bemerkt |
Mark McCarthy
317mm (553x) |
Ca-Cb: not quite round, oval/olive shaped. It is the AB-C of STF 1196. |
Mark McCarthy
317mm (553x) |
AB: Triple, all near equal magnitude, yellow-white. AB ~0.8", hair split. |
Mark McCarthy
317mm (553x) |
AC: Triple, all near equal magnitude, yellow-white. AC ~6", wide split. |
Karsten Kopp
Köln (Germany) |
600mm (257x) |
AB: Die Komponenten AB-C bei etwas größerem Helligkeitsunterschied einfach zu trennen und auch schön anzusehen. Sterne erstrahlen weißlich gelb. Komponente AB war nicht zu trennen. |
STF1195 |
AB |
9m.3 |
11m.8 |
9.2" |
333° |
2015 |
Cnc |
08h12m38.45s / +30°27'33.30" |
Mark McCarthy
178mm (205x) |
Both stars are faint, B seen well because it's widely separated about 8", about 2 delta mag. Physical |
STF1197 |
9m.0 |
9m.7 |
1.8" |
101° |
2019 |
Cnc |
08h12m44.45s / +29°32'30.90" |
Mark McCarthy
178mm (205x) |
Fine pair of white stars, around 2" and 1 delta mag. |
Mark McCarthy
317mm (553x) |
Very faint pair, 1 delta mag, ~2". |
Karsten Kopp
Köln (Germany) |
600mm (257x) |
Doppelstern konnte mit nur 1,8" Abstand gerade so getrennt werden. Helligkeitsunterschied etwas mehr als 0,5 mag. |
STF1201 |
8m.1 |
9m.5 |
6.7" |
185° |
2015 |
Cnc |
08h12m52.51s / +09°34'40.00" |
Mark McCarthy
178mm (148x) |
Pretty pair, almost two delta mag. Physical |
Mark McCarthy
317mm (553x) |
Pretty wide, 5", 1 delta mag. |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Doppelstern einfach zu trennen, mit größerem Helligkeitsunterschied weit über 1,0 mag. Der hellere Stern leuchtet gelblich weiß. |
STF1202 |
7m.4 |
9m.6 |
2.7" |
305° |
2015 |
Cnc |
08h13m34.20s / +10°50'49.70" |
Mark McCarthy
317mm (553x) |
Nice yellow-orange and 3 delta mag, B, same color, ~5-7" |
Karsten Kopp
Köln (Germany) |
600mm (257x) |
Dieser Doppelstern war aufgrund des größeren Helligkeitsunterschieds und mit einem Abstand von 2,7" gar nicht mal so einfach zu beobachten. |
BU1243 |
AB |
6m.4 |
12m.3 |
1.7" |
328° |
2005 |
Cnc |
08h14m11.14s / +17°40'33.30" |
Mark McCarthy
178mm (410x) |
B appears as a tiny point just outside A's main diffraction ring, it clears with seeing but is still visible in shimmer during poorer moments |
STT189 |
6m.9 |
10m.7 |
4.4" |
293° |
2017 |
Lyn |
08h14m49.01s / +43°02'05.90" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
14.04.2020: Nicht einmal ansatzweise getrennt. |
LEP30 |
7m.7 |
9m.8 |
31.8" |
238° |
2015 |
Cnc |
08h15m33.20s / +11°25'51.50" |
Mark McCarthy
317mm (553x) |
Light orange with faint white star of ~11th magnitude, wide separation |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Einfacher Doppelstern mit größerem Helligkeitsunterschied. Komponente A leuchtet gelblich. |
STF1210 |
AB |
7m.2 |
9m.4 |
15.7" |
113° |
2019 |
Hya |
08h15m48.54s / +02°48'05.00" |
René Merting
18x70 |
mit etwas Konzentration ploppt südöstlich von A ein kleiner schwacher Lichtpunkt auf, der nicht richtig klar zu sehen ist - in ruhigen Momenten Trennung sichtbar - Komponente B ist mindestens 2 Größenklassen schwächer |
Mark McCarthy
317mm (553x) |
Pretty wide greenish yellow pair, wide separation, 2 delta mag. |
ES593 |
AB |
9m.3 |
10m.9 |
20.8" |
345° |
2017 |
Lyn |
08h16m42.64s / +40°53'13.90" |
AC |
9m.3 |
11m.3 |
17.8" |
334° |
2017 |
BC |
9m.9 |
10m.1 |
4.8" |
211° |
2017 |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
14.04.2020: Bei 100x und 133x ist das Paar AB einfach zu trennen, wobei B nur recht schwach erschien. Bei genauem Hinsehen wirkte das Paar BC leicht länglich. |
STF1212 |
8m.6 |
10m.1 |
5.5" |
241° |
2019 |
Cnc |
08h18m03.47s / +30°49'56.00" |
Mark McCarthy
178mm (205x) |
1 delta mag, fairly well split, nothing special but still a pretty pair. Not physical |
STF1193 |
AB |
6m.2 |
9m.7 |
42.4" |
90° |
2015 |
UMa |
08h20m40.32s / +72°24'26.00" |
BC |
9m.8 |
12m.7 |
58.8" |
6° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
AB: 21.04.2020: Wunderschön getrennt mit deutlich schwächerem Begleiter. Die Hauptkomponente strahlt in einem hellen, erfrischenden Gelb. Lohnend! |
René Merting
320mm (45x) |
AB: bei 45x … oh wow, was für eine Farbe bei Komponente A - so ein intensives Gelb habe ich noch nirgends gesehen, gleißendes Rapsgelb - die deutlich schwächere Komponente B im Osten in weitem Abstand ist bei der Farbe von A eher uninteressant, B ist ohnehin nur grau schimmernd |
STF1219 |
9m.2 |
9m.3 |
12.2" |
82° |
2020 |
Cnc |
08h22m58.53s / +07°37'49.60" |
Mark McCarthy
178mm (148x) |
Near equal wide white stars. Physical |
A2961, 21 Cnc |
6m.3 |
9m.4 |
1.3" |
267° |
2019 |
Cnc |
08h23m55.20s / +10°37'55.40" |
Mark McCarthy
178mm (205x) |
A is a light orange star, B is a very exceptionally fine point just a little more than 1" separation, sharp with seeing, 3 delta mag. |
A1746, 24 Cnc |
BC |
8m.5 |
8m.5 |
0.2" |
4° |
2007 |
Cnc |
08h26m39.82s / +24°32'03.70" |
Mark McCarthy
508mm (1067x) |
Component of STF1224. I see a very subtle notched elongation, PA SSW, noticeable mag difference. Physical with a 21.78-year period, it is a nearly circular orbit and near periastron, it's apastron will be in 2029 at 0.16" |
STF1224, 24 Cnc |
A-BC |
6m.9 |
7m.5 |
5.7" |
53° |
2019 |
Cnc |
Uwe Pilz
Leipzig (Germany) |
105mm (128x) |
fahlviolett und gelb |
STF1223, phi 2 Cnc |
6m.2 |
6m.2 |
5.2" |
219° |
2019 |
Cnc |
08h26m47.08s / +26°56'07.80" |
Christopher Hay
Seeheim (Germany) |
25x80 |
Haarfein aber eindeutig und konstant gehalten getrennt. Hübsch in 3.3° Gesichtsfeld mit Phi1 und Chi Cnc. Einfacher als ich bei nur 25x gedacht hätte. Die sehr ähnlichen Helligkeiten der Komponenten fördert diese Trennleistung sehr. Der 70% volle Mond in der Nähe in Leo hilft ebenfalls, da seine Helligkeit die Sehschärfe erhöht. Ich schaue bei der Beobachtung immer wieder mit Absicht voll in den Mond um diesen Effekt zu nutzen, eine Technik, die sich bei Grenzbeobachtungen mit Ferngläsern an Planeten ebenfalls bewährt hat. Hauptkomponente sichtlich etwas heller als Begleiter, auch dies überraschend die geringe Differenz von 0m05 bedenkend (6m16 zu 6m21 nach Stelledoppie). Leider kein physikalisches Paar, obwohl es so sehr danach aussieht im Okular. |
Christopher Hay
Seeheim (Germany) |
36mm (33x) |
Haarfein getrennt bei 33x, klarer bei 40x, ganz klar bei 50x. |
Uwe Pilz
Leipzig (Germany) |
105mm (28x) |
weiß und gelb |
Uwe Pilz
Leipzig (Germany) |
105mm (88x) |
sehr schön, blauweiß-gelbweiß |
Mark McCarthy
Fremont (California/USA) |
508mm (205x) |
Bright white, equal, wide -- dramatic but not much. Not physical |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Schöner und einfach zu trennender Doppelstern, wo beide Sterne dieselbe Helligkeit haben und weißlich strahlen. Wie ein Augenpaar im All |
HU714 |
Ba-Bb |
9m.8 |
10m.1 |
0.7" |
311° |
2009 |
Cnc |
08h26m56.47s / +32°11'47.30" |
Mark McCarthy
508mm (533x) |
Nicely split with seeing, 0.5-1.0 delta mag, 0.5" separation. Short period of 195.5 years, it is at apastron now and will remain there the rest of my lifetime |
STF1228 |
8m.9 |
9m.7 |
9.0" |
352° |
2015 |
Cnc |
08h27m39.04s / +27°33'42.50" |
Mark McCarthy
508mm (205x) |
Bright white, 1 delta, wide |
STF1230 |
9m.3 |
10m.6 |
34.2" |
186° |
2015 |
Cnc |
08h28m25.95s / +16°51'09.10" |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
Komponente B nur indirekt. bei 88x erahnbar. |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Einfacher Doppelstern mit größerem Helligkeitsunterschied. |
A551, LO Hya |
AB |
7m.0 |
7m.1 |
0.4" |
63° |
2018 |
Hya |
08h28m29.16s / -02°31'01.60" |
Mark McCarthy
508mm (1067x) |
LO Hya. With apodizing mask. Easy split, noticeable half delta mag. Another fainter star further out likely +1 [The +1 is STF 1233 AB-C, 6.42/10.49 18.3". AB at furthest extent of orbit, will tighten considerably the next 20 years] |
A2893 |
9m.8 |
9m.4 |
0.7" |
351° |
2015 |
Hya |
08h30m05.67s / +05°13'03.90" |
Mark McCarthy
508mm (533x) |
Closely split, noticeable ~1 delta mag, good pair |
HU717 |
9m.7 |
9m.5 |
0.5" |
52° |
2011 |
Cnc |
08h32m34.65s / +32°27'25.10" |
Mark McCarthy
508mm (533x) |
Exceptionally finely split with 333x, steady clean split with 533x, near equal white stars |
STF1243 |
7m.8 |
9m.4 |
1.7" |
233° |
2017 |
Hya |
08h33m53.79s / +01°35'07.50" |
Mark McCarthy
508mm (533x) |
Well split ~2", 2 delta mag, blue-white A and dull white B |
STF1245 |
AB |
6m.0 |
7m.2 |
10.0" |
25° |
2019 |
Cnc |
08h35m51.05s / +06°37'13.90" |
AC |
6m.0 |
10m.7 |
100.4" |
109° |
2017 |
AD |
6m.0 |
11m.9 |
110.3" |
292° |
2017 |
AE |
6m.0 |
9m.6 |
114.8" |
207° |
2017 |
Robert Zebahl
Leipzig (Germany) |
70mm (57x) |
AB bei 22x getrennt, aber sehr enges, ungleiches Paar. A wirkte weiß-gelblich, B orange, teils rötlich. Gegenüber in großem Abstand war noch die schwächere E-Komponente zu sehen. Bei 57x zeigte sich A weiß-gelblich, B orangefarben. |
René Merting
100mm (32x) |
AB: bei 32x ein sehr enges Pärchen, gerade so getrennt - das Sternpaar ist heller, als viele andere Sterne in der unmittelbaren Umgebung, dadurch ist es sehr auffällig - Komponente A strahlt reinweiß, B steht dem in nichts nach, auch wenn die Komponente gut eine Magnitude schwächer ist |
Sarah Gebauer
Germany |
100mm (45x) |
AB: schmal, aber deutlich getrennt, die südliche Komponente sichtbar heller, die nordöstliche schwächer |
Uwe Pilz
Leipzig (Germany) |
105mm (88x) |
AB |
Mark McCarthy
508mm (533x) |
AB: Wide and bright pair, light yellow and orange, easy, slight mag difference |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
AB: AB: Schöner und einfacher Doppelstern, wobei die Komponente A weißlich gelb und Komponente B gelblich orange leuchtet. Das Sternfeld in direkter Umgebung rundet den schönen Eindruck ab. |
STF1242 |
9m.9 |
10m.5 |
2.7" |
175° |
2015 |
UMa |
08h36m01.43s / +47°07'29.60" |
Mark McCarthy
178mm (205x) |
Dim pair for Struve, half delta mag, well split about 4" |
AG154 |
9m.6 |
9m.8 |
2.7" |
1° |
2019 |
Cnc |
08h36m55.78s / +23°14'49.10" |
Mark McCarthy
508mm (533x) |
HO Cnc. Near equal well separated, light orange stars |
J1008 |
10m.9 |
11m.1 |
3.1" |
20° |
2015 |
Hya |
08h39m23.43s / -00°16'32.00" |
Mark McCarthy
508mm (533x) |
Easy pair, not too faint, wide ~3", equal mag. [not physical] |
COU47 |
7m.9 |
9m.6 |
0.6" |
141° |
2008 |
Cnc |
08h39m42.78s / +20°05'10.40" |
Mark McCarthy
178mm (410x) |
Elongated at lower magnifications, strongly notched at 410x, noticeable magnitude difference. Same proper motions so likely physical |
STF1255 |
AB |
7m.3 |
8m.6 |
26.1" |
30° |
2020 |
Hya |
08h39m43.80s / +05°45'51.40" |
BC |
8m.6 |
13m.6 |
69.6" |
357° |
2015 |
BD |
8m.6 |
12m.6 |
71.5" |
22° |
2015 |
René Merting
100mm (20x) |
AB: bei 20x und 32x ein ordentlich getrenntes Sternpaar - Komponente B im NW strahlt nicht ganz so weiß wie A - Helligkeitsunterschied eine halbe Größenklasse (1.23 mag laut Stelle Doppie!) |
BU584 |
AB |
7m.3 |
12m.3 |
0.9" |
290° |
2006 |
Cnc |
08h39m56.49s / +19°33'10.70" |
Mark McCarthy
178mm (410x) |
I can't believe I got this, very faint B about 1" separation, can just see it direct vision, brightens with averted, very faint. This star the faintest of a prominent long triangle of stars. Component of S 571, which has several other widely separated pairs. In Praesepe, but I neglected to check my finderscope |
ENG37 & SLE335 & SLE685, 39/40 Cnc |
ENG37 |
AB |
6m.5 |
6m.6 |
151.8" |
150° |
2015 |
Cnc |
08h40m06.44s / +20°00'28.10" |
ENG37 |
AC |
6m.5 |
9m.0 |
134.0" |
309° |
2015 |
ENG37 |
AD |
6m.5 |
8m.8 |
134.9" |
111° |
2015 |
SLE685 |
AR |
6m.5 |
11m.6 |
290.3" |
150° |
2001 |
SLE335 |
AS |
6m.5 |
10m.1 |
261.7" |
325° |
2002 |
SLE335 |
CS |
9m.0 |
10m.1 |
137.1" |
340° |
2002 |
Christopher Hay
Seeheim (Germany) |
71mm (32x) |
Alle Mitglieder, A, B, C und D, klar gesehen und sehr weit getrennt. Eine kompakte Gruppe am Nordrand von M 44 (Praesepe). Komponente A ins Orangene gehend. Engelmann 37ABCD ist eine physikalische Gruppe in 608 Lichtjahren Abstand zu uns. Stelledoppie führt zur Bezeichnung ENG aus: Some time after publication of the IDS, the designation for Engelmann was changed from EN to ENG and that for Engelhardt from ENG to ENH. This has led to considerable confusion between the two. |
STN61 |
8m.4 |
9m.4 |
4.6" |
203° |
2015 |
Pyx |
08h40m17.61s / -32°09'54.90" |
Mark McCarthy
508mm (205x) |
Near planetary nebula M3-6. Pretty blue and orange pair, close but well split |
STF1254 |
AB |
6m.4 |
10m.4 |
20.8" |
55° |
2017 |
Cnc |
08h40m22.11s / +19°40'11.90" |
AC |
6m.5 |
7m.6 |
62.5" |
343° |
2018 |
AD |
6m.5 |
9m.2 |
83.5" |
44° |
2017 |
Stefan Loibl
102mm (164x) |
Septupel, visuelles Quintupel, Komponenten A, B, C und D getrennt, E nicht sichtbar, B nicht trennbar, kein Farbkontrast, am Nordrand von Messier 44 |
KU32 |
8m.1 |
10m.2 |
2.2" |
165° |
2017 |
Cnc |
08h41m18.40s / +19°15'39.60" |
Mark McCarthy
178mm (148x) |
Very fine, wow quite amazing, around 2", split nicely, 3 delta magnitude. The faint B star disappears with increased magnification |
STF1262 |
8m.5 |
10m.1 |
6.9" |
203° |
2017 |
Cnc |
08h41m58.04s / +23°47'56.00" |
Mark McCarthy
178mm (148x) |
Well split, a bit less than 2 delta mag, white stars |
J1110 |
9m.9 |
10m.2 |
3.4" |
42° |
2017 |
Cnc |
08h42m06.27s / +25°00'43.40" |
Mark McCarthy
178mm (148x) |
Well split white stars, about 1 delta. Physical |
BAL1852 |
11m.0 |
11m.0 |
14.3" |
6° |
2015 |
Hya |
08h42m37.69s / +02°14'25.30" |
Mark McCarthy
508mm (533x) |
Not likely to be physical. Wide, half delta mag white stars [not physical] |
STF1258 |
7m.7 |
7m.9 |
10.1" |
331° |
2019 |
UMa |
08h43m25.41s / +48°51'41.90" |
Robert Zebahl
Leipzig (Germany) |
16x70 |
05.07.2020: Sofort als Doppelstern erkennbar, getrennt, aber ziemlich dicht bei ähnlich hellen Komponenten. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Bei 22x einfach zu trennen, ähnlich helle Komponenten bei mäßigem Abstand. Bei 57x sehr geringer Helligkeitsunterschied wahrnehmbar. Die Komponenten wirkten leicht orangefarben und weiß-bläulich, wobei die Farbe zwischen den Komponenten immer wieder wechselte. Ein sehr merkwürdiger Effekt, den ich immer wieder beobachte. |
Mark McCarthy
178mm (205x) |
White stars, wide, near equal. Physical |
BAL2821 |
12m.6 |
13m.1 |
10.0" |
83° |
2016 |
Hya |
08h43m26.88s / +03°40'13.00" |
Mark McCarthy
508mm (533x) |
A bit faint pair, half delta mag, wide [not physical] |
STF1270 |
6m.9 |
7m.5 |
4.7" |
265° |
2020 |
Hya |
08h45m20.79s / -02°36'03.70" |
René Merting
Drachhausen (Germany) |
100mm (64x) |
bei 32x hatte ich schon den richtigen Verdacht, bei 64x ist es eindeutig, beide Sterne stehen knapp getrennt schön eng zusammen - Komponente A im Osten wirkt cremeweiß, B eher weißblau |
Mark McCarthy
508mm (533x) |
MX Hya. Wide, yellow-white, half delta mag. Nice |
CBL32 |
7m.4 |
10m.7 |
41.0" |
174° |
2015 |
Cnc |
08h46m14.32s / +27°35'41.30" |
Mark McCarthy
317mm (553x) |
Pretty yellow-orange 8th magnitude primary, with 3x fainter blue which can be seen direct vision but blinks like a planetary nebula, so must be 11-12th mag. Wide separation. |
STF1268, iota Cnc, 48 Cnc |
4m.1 |
6m.0 |
30.7" |
308° |
2018 |
Cnc |
08h46m41.82s / +28°45'35.60" |
Christopher Hay
Seeheim (Germany) |
10x42 |
Fernglas mit interner Stabilisierung, handgehalten. Begleiter ein feiner Punkt dicht neben dem gleißenden Hauptstern. Etwas unsicher, aber den gesehenen Positionswinkel nachträglich bestätigt gefunden. Im 15x45 Stabi-Fernglas deutlich getrennt, Hauptstern weiss mit einem Stich in's Gelbe, Begleiter wesentlich kälter. Ein physikalischer Doppelstern in 331 Lichtjahren Abstand zu uns. |
Christopher Hay
Seeheim (Germany) |
15x60 |
Auf Stativ. Deutlich getrennt. Hauptstern ein sehr helles Gelb, Begleiter ein sehr helles Blau. Aus ausserordentlich auffälliges Paar. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Auffällig, weit getrennt mit deutlichem Helligkeitsunterschied. Mäßiger, aber schöner Farbkontrast: weiß-gelblich und grau-bläulich. |
Christopher Hay
Seeheim (Germany) |
71mm (32x) |
Ein kompaktes Paar. Gelb, hellblau. Dominiert absolut das Gesichtsfeld von 2,2°. |
Robert Zebahl
Leipzig (Germany) |
102mm (28x) |
Sehr schön! Recht weit auseinander mit sichtbarem Helligkeitsunterschied. A: dezent orangefarben, B: sehr schönes Hellblau. |
Stefan Loibl
102mm (164x) |
weites Paar mit schönem Farbkontrast gelb/blau |
Uwe Pilz
Leipzig (Germany) |
105mm (28x) |
fahlblau und gelborange |
Uwe Pilz
Leipzig (Germany) |
105mm (144x) |
gelb-blaugrau |
Sarah Gebauer
Germany |
150mm (125x) |
bei 83x schon deutlich getrennt, der Farbkontrast ist gut zu sehen, er wird bei 125x noch stärker, ein zartes Blau und Gelb sind zu sehen |
Mark McCarthy
317mm (553x) |
Iot Cnc: Pretty orange and pale blue, showpiece object. |
11 Hya, epsilon Hya |
SP1 |
AB |
3m.5 |
5m.0 |
0.2" |
241° |
2018 |
Hya |
08h46m46.51s / +06°25'07.70" |
STF1273 |
AB-C |
3m.5 |
6m.7 |
2.9" |
311° |
2020 |
STF1273 |
AB-D |
3m.5 |
12m.5 |
18.1" |
201° |
2017 |
STF1273 |
AB-E |
3m.5 |
10m.8 |
340.5" |
2° |
2015 |
STF1273 |
AB-F |
3m.5 |
10m.4 |
406.5" |
265° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
AB-C: Nicht getrennt. Es war zwar eine leichte Aufhellung im ersten Beugungsring sichtbar, könnte aber auch von der leichten Koma des Refraktors kommen. |
Sarah Gebauer
Germany |
100mm (200x) |
AB-C: ist ein heller Stern vom Hydra-Kopf, nicht zu trennen, vermutlich, weil die Komponente AB zu hell strahlt |
Robert Zebahl
Leipzig (Germany) |
102mm (160x) |
AB-C: 27.03.2020: Der deutlich schwächere Begleiter ist gut als beinahe runder Knoten direkt am Beugungsring der Hauptkomponente zu sehen. Sehr schöner Anblick. Die Luft war mäßig ruhig (3/5). |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
AB-C: bei 144x schwierig |
Robert Zebahl
Leipzig (Germany) |
152mm (150x) |
AB-C: 27.03.2020: Der Begleiter ist sofort als kleines Sternchen dicht an der Hauptkomponente zu sehen. Durch den Farbfehler des Achromaten kommt es zu einer leichten Überstrahlung. Dennoch ein schöner Anblick. Die Luft war mäßig ruhig (3/5). |
Mark McCarthy
508mm (533x) |
AB-C: Epsilon Hya A is bright orange-yellow, B is much fainter and a little blue, ~3". [SP 1 AB is 3.49/5.00 0.2" not seen] |
KR30 |
10m.3 |
10m.3 |
1.9" |
305° |
2015 |
UMa |
08h46m49.82s / +57°41'55.70" |
Mark McCarthy
178mm (205x) |
Finely split equal white stars, need to wait for seeing to settle for the elongation to resolve to points, about 2", small scale |
STF1276 |
AB |
8m.3 |
8m.6 |
12.7" |
353° |
2017 |
Cnc |
08h47m10.99s / +11°09'34.20" |
Sarah Gebauer
Germany |
100mm (45x) |
das enge Pärchen bei 45x ist deutlich getrennt, die dritte Komponente landete unwissenderweise sogar auch auf der Zeichnung |
Mark McCarthy
178mm (148x) |
Wide, white, near equal stars, nice |
STF1281 |
AB |
7m.8 |
9m.0 |
53.1" |
310° |
2017 |
Hya |
08h47m36.90s / +00°01'04.30" |
René Merting
100mm (20x) |
bei 32x ein weit auseinander stehendes Paar - Komponente B im NW ist halb so hell und wirkt gräulich gegenüber der buttergelben Komponente A - zurück auf 20x ist B noch nicht zu schwach und immernoch gut getrennt von A erkennbar |
ES596 |
9m.6 |
11m.0 |
3.1" |
207° |
2015 |
Lyn |
08h47m55.32s / +45°31'39.00" |
Mark McCarthy
178mm (148x) |
Faint pair, nicely split, white A and dull B. Physical |
BAL2347 |
AB |
9m.3 |
10m.8 |
4.0" |
204° |
2015 |
Hya |
08h47m58.80s / +03°07'39.50" |
Mark McCarthy
508mm (533x) |
B star considerably fainter needed averted vision to flash it out, but then hold it direct. Both stars a little blue, wide separation, half delta mag |
BU335 |
7m.5 |
9m.4 |
2.6" |
265° |
2017 |
Hya |
08h48m12.24s / +02°34'48.40" |
Sarah Gebauer
Germany |
100mm (200x) |
auch bei 200x nicht zu trennen |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
schwierig |
Mark McCarthy
508mm (533x) |
3 delta mag, well split ~3", very pleasing pair, white A and slightly red B |
STT194 |
7m.4 |
10m.5 |
12.6" |
57° |
2015 |
Hya |
08h48m18.30s / +00°33'18.10" |
Mark McCarthy
508mm (533x) |
Orange A and blue B, 3 delta mag, very wide [not physical] |
AGC3, rho Hya |
4m.4 |
11m.9 |
12.1" |
146° |
2015 |
Hya |
08h48m25.98s / +05°50'16.40" |
Mark McCarthy
508mm (533x) |
Rho Hya Bright white A star and much fainter B star, but it's still a hard bluish point very fine. Nice one |
A2550 |
9m.5 |
9m.8 |
0.4" |
204° |
1996 |
Hya |
08h48m35.67s / +03°04'05.20" |
Mark McCarthy
508mm (533x) |
Wow exceptionally fine pair. B is very faint but can hold direct vision after flashing it out using averted vision. Very close, hairline split, amazing pair. At 1067x the stars dim a little can still see B but need averted vision all the time |
A2552 |
9m.1 |
8m.5 |
0.3" |
208° |
2018 |
Hya |
08h48m40.30s / +00°56'31.00" |
Mark McCarthy
508mm (533x) |
Wow fine split. Pale yellow A and blue B, about one delta mag. Nice split, amazing [82.4 year period] |
STF1271 |
9m.5 |
10m.3 |
0.9" |
81° |
2015 |
UMa |
08h50m07.39s / +56°12'23.70" |
Mark McCarthy
178mm (205x) |
Very close, barely split, around 1", more than 1 delta magnitude |
J74 |
11m.2 |
11m.3 |
9.3" |
126° |
2017 |
Hya |
08h50m23.22s / +01°24'47.20" |
Mark McCarthy
508mm (533x) |
Faint near equal, bluish, pretty wide. Forms part of a triangle with similar magnitude stars [not physical] |
BAL2351 |
9m.3 |
10m.6 |
14.2" |
110° |
2016 |
Hya |
08h50m30.10s / +03°32'34.30" |
Mark McCarthy
508mm (533x) |
Easy wide pair, B star is very blue. One delta mag. [not physical] |
VDK3 |
9m.9 |
10m.1 |
1.1" |
190° |
2018 |
Cnc |
08h50m42.33s / +07°51'52.40" |
Mark McCarthy
508mm (410x) |
With apodising mask. A surprise short period find. Light orange stars -- they are carbon, HP Cnc. About 1 delta mag, more than 1" separation. Seeing is bloating the stars a bit, but can recorded the PA by drift, it follows a S-N line. J. Vanderdonck, who has three discoveries to his name in the WDS. Physical with a 223.9709-year period, it will make a quarter turn by 2040 |
STF1278 |
AB |
8m.5 |
10m.5 |
8.5" |
128° |
2019 |
UMa |
08h50m42.68s / +49°20'49.00" |
Mark McCarthy
178mm (205x) |
White A star and two delta mag, very wide B |
STF1282 |
AB |
7m.6 |
7m.8 |
3.5" |
279° |
2019 |
Lyn |
08h50m44.28s / +35°04'15.40" |
Robert Zebahl
Leipzig (Germany) |
70mm (57x) |
Klar getrennt, aber dicht zusammenstehend mit sehr geringem Helligkeitsunterschied. Der Doppelstern bildet zusammen mit zwei weiteren Sternen ein spitzwinkliges Dreieck. |
PER1 |
8m.3 |
9m.6 |
0.8" |
350° |
2017 |
Cnc |
08h51m13.71s / +08°20'18.60" |
Mark McCarthy
508mm (410x) |
Quite a beautiful pair, light yellow stars, >1 delta mag, about 1", emerges to view with seeing, quite good. One of two J. Perrotin discoveries. Same proper motions so will likely prove to be physical |
STF1275 |
AB |
8m.7 |
8m.9 |
1.9" |
198° |
2019 |
UMa |
08h51m26.19s / +57°31'38.10" |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
Bei 100x und 150x nicht dauerhaft trennbar. Die Komponenten standen sehr dicht zusammen. |
Mark McCarthy
178mm (205x) |
Neat near equal, nice split about 2", white |
BAL2354 |
9m.9 |
11m.7 |
8.5" |
40° |
2015 |
Hya |
08h51m27.36s / +02°55'49.80" |
Mark McCarthy
508mm (533x) |
B is quite faint, need averted vision to notice it, but then can hold direct, 3 delta mag, pretty wide, ~8" [not physical] |
STF1290 |
7m.4 |
9m.2 |
2.8" |
325° |
2017 |
Hya |
08h52m03.40s / +04°27'58.00" |
Sarah Gebauer
Germany |
100mm (200x) |
blickweise, aber nicht zuverlässig getrennt |
Mark McCarthy
508mm (533x) |
White stars, wide, 2 delta mag |
A2900 |
6m.4 |
9m.5 |
0.7" |
310° |
2004 |
Hya |
08h52m24.18s / +05°20'25.20" |
Mark McCarthy
508mm (533x) |
Elongated or olive shape, not quite notched, certainly a double but difficult, in poor conditions |
HJ460, 53 Cnc |
AB |
6m.5 |
11m.7 |
43.7" |
335° |
2003 |
Cnc |
08h52m28.60s / +28°15'33.00" |
AC |
6m.5 |
6m.0 |
276.8" |
20° |
2011 |
Christopher Hay
Seeheim (Germany) |
7x45 |
AC: Sehr weit. C ist kaltblau, A wärmer und schwächer. AC ist Rho1 Cnc. C ist 55 Cnc, auch Copernicus AB genannt, Heimat von fünf Exoplaneten, recht nah zu uns in nur 41 Lichtjahren Entfernung. |
Christopher Hay
Seeheim (Germany) |
10x42 |
AC: Fernglas mit interner Stabilisierung, handgehalten. C ist hellblau, A braun-orange. Attraktiv in 6.5° Gesichtsfeld mit 57 und 61 Cnc sowie Iota Cnc knapp 2° westlich, welcher getrennt ist. |
Christopher Hay
Seeheim (Germany) |
15x60 |
AC: Auf Stativ. Ein weites, gleichmäßiges Paar. Komponente A (53 Cnc) erscheint rötlich. Hübsch in 3.3° Gesichtsfeld zusammen mit gut getrenntem Iota Cnc. |
Mark McCarthy
317mm (553x) |
AB: 53 Cnc: Orange primary and 2x fainter blue, wide separation (this is AB). There is a second orange-yellow star of about the same magnitude very wide separation (this is AC). |
A1584 |
9m.0 |
7m.7 |
0.7" |
93° |
2017 |
UMa |
08h53m08.05s / +54°57'11.00" |
Mark McCarthy
508mm (333x) |
Tight white stars, seeing is not very good but can still split it. It has a noticable magnitude difference, however I need to guess which one is A. I am able to estimate PA by drifting it across the field. [My PA is in the correct line but my A and B are reversed.] 70.89-year period, it is now at apastron and will make a very small turn in its arc by 2040 |
A2752 |
9m.0 |
11m.0 |
5.1" |
231° |
2016 |
Hya |
08h53m26.66s / +05°12'47.20" |
Mark McCarthy
508mm (533x) |
Easy wide pair, B is 1.5 delta mag and very blue |
STF1292 |
AB |
9m.3 |
9m.5 |
6.1" |
188° |
2020 |
Hya |
08h53m46.02s / -00°34'41.60" |
Mark McCarthy
508mm (533x) |
Near equal, wide, ~6". Very faint star ~20" may be plus one [it is, UC 1728 AC, 9.32/13.42 27.8"] |
STT195 |
AB |
7m.7 |
8m.3 |
9.8" |
138° |
2020 |
Cnc |
08h53m57.80s / +08°25'17.70" |
Robert Zebahl
Leipzig (Germany) |
70mm (80x) |
Bei 22x sehr schön getrennt mit geringem Helligkeitsunterschied. Die Komponenten stehen noch recht dicht zusammen. Insgesamt ein eher schwacher Doppelstern. Bei 80x ist der Farbunterschied gut sichtbar: Hauptkomponente erscheint leicht orangefarben, der Begleiter hellblau. |
Mark McCarthy
508mm (148x) |
White stars, wide, one delta |
STF1291, 57 Cnc |
AB |
6m.1 |
6m.4 |
1.5" |
310° |
2019 |
Cnc |
08h54m14.65s / +30°34'45.80" |
AB-C |
5m.5 |
9m.2 |
54.6" |
204° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
AB: Sofort als Doppelstern erkennbar. Beugungsscheibchen überlappen sich leicht ('8'). Helligkeitsunterschied erkennbar. |
Uwe Pilz
Leipzig (Germany) |
105mm (144x) |
gelb |
Sarah Gebauer
Germany |
150mm (125x) |
AB: sowohl bei 83x als auch bei 125x knapp vorm Trennen |
Mark McCarthy
203mm (205x) |
AB: 57 Cnc. Very nice pair, strong orange yellow colors, ~1 delta mag, bright, nice close split |
BAL1430 |
10m.1 |
11m.0 |
11.5" |
110° |
2015 |
Hya |
08h54m37.08s / +01°27'00.30" |
Mark McCarthy
508mm (533x) |
Faint, wide, noticeable not-quite-half magnitude difference [not physical] |
ARG71 |
10m.2 |
10m.4 |
5.3" |
339° |
2019 |
UMa |
08h54m39.34s / +49°54'09.90" |
Mark McCarthy
508mm (205x) |
White and wide near equal |
AG338 |
AB |
9m.0 |
9m.2 |
2.1" |
164° |
2019 |
Cnc |
08h54m41.52s / +16°36'39.70" |
Mark McCarthy
508mm (148x) |
IK Cnc. White stars, near equal, well split. Physical with a 1790-year period. A is TOK 196 0.2", not attempted, with just a 15-year period, need to go back! |
STF1289 |
8m.2 |
8m.9 |
3.6" |
6° |
2019 |
Lyn |
08h54m44.33s / +43°35'04.70" |
Robert Zebahl
Leipzig (Germany) |
70mm (57x) |
Recht schwacher Doppelstern, aber gut trennbar bei auffälligem Helligkeitsunterschied und dicht zusammenstehenden Komponenten. |
Mark McCarthy
178mm (148x) |
White stars, 1 delta mag, pretty wide |
STF1280 |
AB |
8m.8 |
9m.1 |
3.4" |
357° |
2019 |
UMa |
08h55m24.82s / +70°47'39.20" |
AC |
8m.8 |
12m.4 |
398.4" |
88° |
2015 |
BC |
9m.1 |
12m.4 |
398.5" |
88° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (67x) |
AB: 03.04.2021: Eher schwacher Doppelstern mit noch recht dicht zusammenstehenden Komponenten und geringem Helligkeitsunterschied. |
René Merting
100mm (72x) |
AB: ein knapp getrenntes Sternpaar - beide Sterne sind annähernd gleich hell und strahlen rein weiß - bei 144x eine ordentlichere Trennung, Komponente A im Süden strahlt in einem wärmeren Weiß |
ARG21, AC UMa |
AB |
10m.0 |
10m.4 |
21.4" |
106° |
2015 |
UMa |
08h55m51.01s / +64°58'21.60" |
Mark McCarthy
317mm (553x) |
Two very faint stars, wide separation, ~0.5 delta mag, to south of an orange star. |
STF3120 |
AB |
8m.4 |
9m.0 |
1.4" |
1° |
2017 |
Lyn |
08h56m07.21s / +43°40'39.30" |
Mark McCarthy
178mm (222x) |
Lovely pair, barely split with 148x, better seen with 222x. A nice well split pair, more than 1 delta mag, white stars |
A2968 |
9m.1 |
9m.4 |
1.2" |
132° |
2017 |
Cnc |
08h57m06.22s / +10°45'29.10" |
Mark McCarthy
508mm (222x) |
Very fine pair of white stars, <1", split with 410x but then backed off magnification and could still split with lower |
SHY204, 62/63 Cnc, omicron Cnc, omicron 1/2 Cnc |
5m.2 |
5m.7 |
975.6" |
17° |
2015 |
Cnc |
08h57m14.95s / +15°19'21.90" |
Christopher Hay
Seeheim (Germany) |
2x54 |
Weit auseinander, Omicron deutlich heller wie 63 Cnc. Hübsch zusammen mit Praesepe (M 44) und dem Kopf-der-Hydra Sternmuster in 25° Gesichtsfeld. Shaya 204, aus Omi Cnc und 63 Cnc bestehend, ist ein physikalischer Doppelstern in 149 Lichtjahren Abstand zu uns. Vermutlich mit blossem Auge trennbar wenn Himmelshelligkeit es zulässt, der begrenzender Faktor ist die 5m7 von 63 Cnc. |
Christopher Hay
Seeheim (Germany) |
7x45 |
Superweit, dennoch als Paar gut zusammen bleibend. Beide blau-weiss. |
Christopher Hay
Seeheim (Germany) |
15x60 |
Auf Stativ. Kein besonderer Gewinn erwartet gegenüber Anblick mit 7x45, aber im engeren 3.3° Gesichtsfeld des 15x60 ist das Paar entzückend, das Feld mit vielen schwachen Sternen gesprenkelt. Beide Komponenten (d.h. Omi Cnc und 63 Cnc) haben eine identisch blau-weisse Tönung, sehr hübsch. |
STF1294 & SIN41 |
STF1294 |
AB |
9m.0 |
10m.8 |
15.6" |
340° |
2015 |
Cnc |
08h57m17.08s / +32°53'57.90" |
SIN41 |
AC |
9m.0 |
12m.6 |
191.3" |
285° |
2015 |
Robert Zebahl
Leipzig (Germany) |
102mm (28x) |
STF1294 (AB): Bei 28x relativ weit getrennt und eher weniger auffällig nahe dem hellen Stern sigma 2 Cnc. Die Komponente A erschien leicht orangefarben, der Begleiter nur als schwaches Sternchen. Ähnlicher Anblick bei 86x. |
BU408 |
7m.3 |
9m.6 |
2.8" |
345° |
2018 |
UMa |
08h59m00.62s / +63°25'42.80" |
René Merting
100mm (142x) |
bei 107x ist nordöstlich von A ein Helligkeitspeak erkennbar, aber nicht richtig greifbar - bei 142x dann zeigt sich in ruhigen Momenten die schwächere Komponente knapp abgesetzt von A - großer Helligkeitsunterschied, mindestens 2.5 Größenklassen |
Mark McCarthy
178mm (205x) |
A fine pair, white bright A and faint B about 3", 3 delta mag |
Mark McCarthy
317mm (553x) |
BU 408 is the fainter star in a pair pair of near equal stars in finder view, red-orange color. In the scope the B is a blue star 3" out from the orange star. |
iota UMa, 9 UMa, Talitha |
HJ2477 |
A-BC |
3m.1 |
9m.2 |
2.4" |
90° |
2017 |
UMa |
08h59m12.45s / +48°02'30.60" |
HU628 |
BC |
9m.9 |
10m.1 |
0.9" |
206° |
2017 |
Robert Zebahl
Leipzig (Germany) |
152mm (300x) |
A-BC: 24.04.2020: Das Seeing (3/5) war nicht ausreichend gut für eine Trennung. |
Mark McCarthy
508mm (213x) |
A-BC: Iota UMa = Talitha. Using 25mm occulting bars with barlow, no mask, putting the bright star's diffraction spikes under the bars, I can see the hard point of the B star, brighter & closer than Procyon B outside of A's glare. One other field star. [HJ 2477's period is 2735 years. The short period is BC is HU 628 9.90/10.10 0.9" 39 year period -- how in the world did he see that?] |
STF1296 |
9m.1 |
9m.9 |
1.9" |
76° |
2019 |
Lyn |
08h59m16.74s / +34°56'46.90" |
Robert Zebahl
Leipzig (Germany) |
102mm (160x) |
Insgesamt recht schwacher Doppelstern, aber deutlich getrennt mit moderatem Helligkeitsunterschied. Beide Komponenten stehen noch ziemlich dicht beieinander. |
ALD115 |
10m.6 |
11m.2 |
1.6" |
270° |
2006 |
Cnc |
09h00m12.88s / +15°49'30.80" |
Mark McCarthy
508mm (222x) |
Fine pair, light orange stars, with seeing |
HO360 |
8m.4 |
12m.1 |
3.9" |
156° |
2015 |
Cnc |
09h00m29.99s / +22°28'08.00" |
Mark McCarthy
508mm (222x) |
Faint B easily seen, widely separated from bright white A |
STF1297 |
AB |
8m.9 |
10m.0 |
5.1" |
159° |
2019 |
Cnc |
09h00m32.70s / +22°43'36.70" |
Mark McCarthy
508mm (148x) |
Nice easy wide Struve, 1 delta mag, physical |
STF1302 |
AB |
9m.3 |
9m.5 |
2.7" |
233° |
2017 |
Hya |
09h01m12.87s / +02°44'44.40" |
Mark McCarthy
508mm (533x) |
Near equal easy pair, ~2.5" |
STF1300 |
AB |
9m.5 |
9m.7 |
5.1" |
179° |
2019 |
Cnc |
09h01m17.48s / +15°15'56.80" |
Mark McCarthy
508mm (148x) |
Very light orange stars, one more white than the other, well separated, near equal. Physical with 878-year period |
STF1298, 66 Cnc |
AB |
6m.0 |
8m.6 |
4.4" |
137° |
2017 |
Cnc |
09h01m24.13s / +32°15'08.30" |
AC |
6m.0 |
12m.0 |
187.6" |
318° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (80x) |
AB: Bei 67x und 80x ist der Begleiter als sehr schwaches Sternchen dicht an der Hauptkomponente sichtbar. Bei 133x ist er nur als leicht verwaschenes Sternchen knapp außerhalb des ersten Beugungsrings der Hauptkomponente erkennbar. |
Robert Zebahl
Leipzig (Germany) |
102mm (62x) |
AB: Bei 62x klar getrennt, deutlicher Helligkeitsunterschied. Der Begleiter ist gut als schwaches, von der Hauptkomponente abgesetztes Sternchen zu sehen. Bei 125x einfach zu trennen. Die Komponente A wirkte eher weiß. |
Mark McCarthy
203mm (205x) |
AB: 66 Cnc. Excellent pair. A is a pure white, B is much fainter and seems red to purple color, nicely separated |
SHJ101, 67 Cnc |
6m.1 |
9m.2 |
103.9" |
329° |
2015 |
Cnc |
09h01m48.84s / +27°54'09.30" |
Mark McCarthy
317mm (553x) |
67 Cnc. White pair, 2 delta mag, wide. |
HU720 |
8m.6 |
9m.3 |
0.8" |
136° |
2017 |
UMa |
09h03m16.01s / +47°40'18.10" |
Mark McCarthy
178mm (333x) |
Suspected at 205x, it is the finest hairline split at 333x, slight magnitude difference, with seeing |
A1585, kap UMa |
4m.2 |
4m.5 |
0.3" |
278° |
2019 |
UMa |
09h03m37.56s / +47°09'24.00" |
Mark McCarthy
508mm (1067x) |
Kappa UMa = Talitha australis: With apodizing mask. Much glare but snowman seen steadily inside the mess. Looks like Eta Carina nebula, with a larger bulge toward us and the smaller bulge pointed up and away. No field stars at this magnification, went down to 533x to notice one for the sketch |
STF1308 |
8m.1 |
9m.2 |
10.9" |
85° |
2020 |
Hya |
09h04m59.50s / -03°59'15.10" |
René Merting
100mm (32x) |
bei 32x zeigt sich ein enges Sternpärchen, Komponente B im Osten ist eine knappe Größenklasse schwächer |
AG161 |
10m.1 |
10m.6 |
4.3" |
224° |
2019 |
Cnc |
09h05m39.99s / +32°26'35.80" |
Mark McCarthy
203mm (205x) |
Very fine white pair, nicely split in the scene, near equal. [sadly it is not physical] |
STF1309 |
8m.5 |
8m.4 |
11.7" |
273° |
2016 |
Hya |
09h06m38.25s / +02°49'06.30" |
René Merting
100mm (32x) |
bei 32x ein Musterdoppelstern, wie er im Buche steht - zwei gleich helle Sterne eng aneinander geschmiegt, knapp getrennt - ganz leichter Farbkontrast, aber nicht definierbar |
HU722 |
9m.2 |
9m.1 |
0.5" |
244° |
2017 |
UMa |
09h06m39.07s / +50°37'36.50" |
Mark McCarthy
178mm (445x) |
Notched elongation best I can see |
AG162 |
9m.8 |
10m.1 |
4.1" |
107° |
2018 |
Cnc |
09h07m10.98s / +30°38'30.10" |
Mark McCarthy
203mm (205x) |
Pretty, near equal off white stars, ~4" [not physical] |
STF1311 |
AB |
6m.9 |
7m.1 |
7.5" |
199° |
2019 |
Cnc |
09h07m27.01s / +22°58'51.10" |
Christopher Hay
Seeheim (Germany) |
100mm (44x) |
Deutlich getrennt, ein sehr auffälliges Paar welches das Gesichtsfeld von 1,9° dominiert wenn es in die Mitte des Feldes gestellt wird. Ein Common Proper Motion Pair in 190 Lichtjahre Abstand von uns. |
Mark McCarthy
203mm (205x) |
Milk white A and off-white, yellowish B, ~1 delta mag, well separated |
POU3029 |
10m.1 |
10m.4 |
8.1" |
315° |
2018 |
Cnc |
09h08m09.79s / +23°52'42.90" |
Mark McCarthy
203mm (205x) |
Wide separation, white stars, about half delta mag |
STTA97 |
8m.3 |
8m.3 |
51.5" |
274° |
2018 |
Cnc |
09h08m27.16s / +27°32'35.30" |
Christopher Hay
Seeheim (Germany) |
15x45 |
Fernglas mit interner Stabilisierung, handgehalten. Gut getrennt. Sehr gleichmäßige Helligkeiten. Ein physikalischer Doppelstern in 139 Lichtjahren Abstand zu uns. |
Mark McCarthy
80mm (13x) |
Finder split, near equal white. |
Mark McCarthy
317mm (553x) |
80mm finder view shows an arc of three stars. westernmost star is a wide equal pair in the telescope. |
STF1317 |
8m.5 |
9m.9 |
7.8" |
63° |
2016 |
Cnc |
09h09m14.41s / +15°14'27.80" |
Mark McCarthy
178mm (148x) |
Easy wide pair, 2 delta mag white stars, part of a large triangle of stars |
WRH16, xi Cnc |
5m.7 |
6m.2 |
0.2" |
108° |
1944 |
Cnc |
09h09m21.53s / +22°02'43.60" |
Frederik Wanink
Itterbeck (Germany) |
254mm (640x) |
nicht als DS gesehen |
STF1312 |
8m.3 |
8m.8 |
4.7" |
147° |
2019 |
UMa |
09h10m18.19s / +52°23'05.70" |
Robert Zebahl
Leipzig (Germany) |
70mm (44x) |
19.04.2020: Bei 22x klar länglich, bei 31x sofort als '8' sichtbar, teils knapp getrennt. Bei 44x deutlich getrennt mit geringem Helligkeitsunterschied. Für die Wahrnehmung von Farben ist der Doppelstern zu schwach gewesen. Zusammen mit STF 1321 in einem Gesichtsfeld sichtbar. |
Mark McCarthy
178mm (205x) |
White stars, wide, 1 delta mag. Not physical |
STF1306, sigma 2 UMa, 13 UMa |
AB |
4m.9 |
8m.8 |
4.3" |
348° |
2016 |
UMa |
09h10m23.53s / +67°08'03.30" |
AC |
4m.9 |
10m.3 |
197.8" |
148° |
2003 |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
AB: Begleiter nahezu dauerhaft als längliche, nicht kondensierte Aufhellung des ersten Beugungsrings der Hauptkomponente im richtigen Positionswinkel sichtbar. |
Christopher Hay
Seeheim (Germany) |
76mm (20x) |
AB, April 2021: Kein Glück mit AB bei allen Vergrößerungen von 83x bis 167x. AC: Komponente C sehr schwach und recht weit entfernt, wirkt nicht visuell wie ein Doppelstern. |
Mark McCarthy
80mm (150x) |
AB: Suspected very close unequal white stars. 920-year period, slowly widening |
Uwe Pilz
Leipzig (Germany) |
105mm (144x) |
AB: sehr schwierig bei 88x |
STF1322 |
8m.3 |
8m.7 |
1.7" |
53° |
2017 |
Cnc |
09h12m40.15s / +16°31'30.20" |
Mark McCarthy
203mm (333x) |
Fine white pair, well split ~2", 1 delta mag |
STF1315 |
7m.3 |
7m.7 |
25.1" |
28° |
2019 |
UMa |
09h12m45.94s / +61°40'32.70" |
René Merting
18x70 |
ja, der ist schick - ein gut getrenntes Sternpaar - zwei fast gleich helle Sterne - B im Nordosten ist vielleicht eine viertel Größenklasse schwächer und wirkt warmweiß gegen die kühlweißen A |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Mittelheller Doppelstern, einfach zu trennen mit schönem Abstand und leichtem Helligkeitsunterschied. Zusammen mit 16 UMa in einem Gesichtsfeld. Die hellere Komponente wirkte leicht orangefarben, die schwächere zeigte einen Hauch von Blau. Die Farben der Komponenten wechselten allerdings über die Zeit. Bei 57x ähnlicher Anblick. |
Mark McCarthy
80mm (92x) |
White, wide, near equal |
René Merting
100mm (20x) |
bei 32x gibt es nix zu meckern, ein bequem getrenntes Pärchen - Komponente B im NO ist maximal eine halbe Größenklasse schwächer - leichter Farbkontrast - noch schöner bei 20x, auffällig im Umfeld |
BRT155 |
AB |
9m.8 |
10m.6 |
4.6" |
270° |
2018 |
Cnc |
09h12m51.05s / +24°20'29.60" |
Mark McCarthy
203mm (333x) |
Almost need averted vision to hold the B star but can manage it direct after a bit of effort. Pretty wide ~4", 2 delta mag. [Not physical. However A is Aa,Ab, 10.45/10.45 0.5", not seen.] |
STF1320 |
9m.5 |
10m.5 |
12.0" |
216° |
2015 |
Lyn |
09h13m21.20s / +42°19'45.90" |
Mark McCarthy
508mm (333x) |
Easy, wide, yellow-white A and blueish B. [not physical] |
AG163 |
10m.2 |
10m.7 |
5.1" |
320° |
2015 |
Cnc |
09h13m34.97s / +24°03'25.30" |
Mark McCarthy
203mm (333x) |
A fine near equal wide pair, ~5", 10th mag. [surprisingly not physical] |
STF1318 |
7m.8 |
9m.5 |
2.4" |
228° |
2018 |
UMa |
09h13m38.79s / +46°59'25.30" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
Getrennt mit deutlichem Helligkeitsunterschied. Der schwache Begleiter liegt etwas außerhalb des ersten Beugungsrings der Hauptkomponente. |
Mark McCarthy
178mm (205x) |
Very pretty and delicate pair, 2 delta mag and about 2" separation, white stars |
STF1321 |
AB |
7m.8 |
7m.9 |
16.9" |
99° |
2019 |
UMa |
09h14m22.79s / +52°41'11.80" |
AC |
7m.8 |
14m.5 |
145.7" |
64° |
2010 |
AD |
7m.8 |
11m.9 |
136.4" |
129° |
2015 |
Robert Zebahl
Leipzig (Germany) |
16x70 |
AB: 05.07.2020: Sehr schöner Anblick, auffällig, einfach trennbar. Ein leichter Helligkeitsunterschied ist erkennbar. Auf den ersten Blick erschien der Doppelstern im Vergleich zu den umliegenden Sternen auffällig orange, bei genauem Hinsehen war ein Farbunterschied der beiden Komponenten sichtbar: orange & eher weiß. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
AB: 11.04.2020: Bei 22x recht weites Paar mit gleich hellen Komponenten. Farblich auffällig: leicht orange & weiß-bläulich, wobei die Zuordnung der Farben zu den Komponenten etwas schwierig war. Bei 44x etwas bessere Farbwahrnehmung. |
Robert Zebahl
Leipzig (Germany) |
70mm (31x) |
AB: 19.04.2020: Zusammen mit STF1312 in einem Gesichtsfeld. Bei 22x sehr schöner Anblick, einfach trennbar, schöner Abstand. Sofort auffällig. Ein Farbunterschied ist erkennbar: dunkelgelb, orange. Auch bei 44x schön anzuschauen. Bester Anblick bei 31x. |
Christopher Hay
Seeheim (Germany) |
71mm (32x) |
AB: April 2021: Gut getrenntes, gleichmäßiges Paar. Beide ins Orangene gehend. Mit 180mm bei 200x ein weites, gleichmäßiges, visuell starkes Paar. Komponente A merklich heller als B. Beide zeigen eine zarte mandarinorangene Färbung, sehr ansprechend. |
STF1327 |
AB |
8m.8 |
10m.3 |
5.3" |
32° |
2015 |
Cnc |
09h15m32.67s / +27°54'53.40" |
Mark McCarthy
508mm (148x) |
White A star and much fainter B, with another further out wide (AC). Not physical |
TDS6428 |
10m.4 |
10m.5 |
0.4" |
299° |
1991 |
Lyn |
09h15m38.21s / +39°42'50.40" |
Mark McCarthy
508mm (533x) |
B flashes with averted vision only, extremely close split |
STF1332 |
7m.9 |
8m.1 |
5.9" |
29° |
2015 |
Cnc |
09h17m19.21s / +23°39'09.80" |
Christopher Hay
Seeheim (Germany) |
100mm (44x) |
Klar getrennt, etwas enger und visuell viel weniger mächtig als STF 1311 zwei Grad nach Nord-Südwesten. STF 1332 ist 233 Lichtjahre von uns entfernt und hat den Vorzug einer dokumentierten Umlaufbahn, während STF 1311, in 190 Lichtjahre Abstand von uns, ein Common Proper Motion Pair ist. Folglich sehen wir hier zwei physikalische Paare, die sowohl an unserem Himmelszelt als auch tatsächlich im Raum recht nahe beieinander stehen. |
Mark McCarthy
203mm (333x) |
Near equal wide pair, ~5", maybe half delta mag |
STF1336 |
7m.0 |
11m.1 |
40.1" |
180° |
2015 |
Hya |
09h17m32.92s / +00°33'17.80" |
Uwe Pilz
Leipzig (Germany) |
105mm (144x) |
sehr weit, kein Doppelstern-Eindruck |
STF3121 |
AB |
7m.9 |
8m.0 |
0.5" |
205° |
2017 |
Cnc |
09h17m53.45s / +28°33'37.70" |
Mark McCarthy
508mm (533x) |
IP Cnc Split at 533x, used 1067x to recheck orientation. With apodizing mask. Light yellow-orange stars, nice and clean split, very slight mag difference. Real nice |
Mark McCarthy
508mm (533x) |
IP Cnc. Light yellow-orange stars, 1 delta mag, clean well split. 34.17-year period, it's coming off apastron and will make a quarter turn by 2030. PA to the NE |
STF1333 |
6m.6 |
6m.7 |
1.8" |
50° |
2018 |
Lyn |
09h18m25.97s / +35°21'51.30" |
Robert Zebahl
Leipzig (Germany) |
63mm (120x) |
Bei 93x als '8' erkennbar, bei 120x getrennt, aber sehr dicht zusammenstehend, kein Helligkeitsunterschied sichtbar. |
Christopher Hay
Seeheim (Germany) |
71mm (32x) |
Gestreckt mit eindeutigem Positionswinkel. |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
fast gleich hell, beide gelblich, bei 66x schwierig |
Christopher Hay
Seeheim (Germany) |
180mm (113x) |
Hauchfein getrennt, ein gleichmäßiges Paar, recht ansprechend. Keine besondere Färbung. |
Mark McCarthy
508mm (333x) |
Brilliant white pair, near equal, ~2" separation |
HO43 |
9m.3 |
9m.5 |
0.6" |
98° |
2017 |
Cnc |
09h18m36.25s / +20°48'49.40" |
Mark McCarthy
508mm (410x) |
Fine white stars, not quite 1 delta mag, very nice clean split. Wow. Physical with 358.6-year period, it will widen a couple tenths in the next 20 years |
STF1334, 38 Lyn |
AB |
3m.9 |
6m.1 |
2.6" |
224° |
2019 |
Lyn |
09h18m50.64s / +36°48'09.30" |
Uwe Pilz
Leipzig (Germany) |
60mm (198x) |
Aufhellung im ersten Ring |
Robert Zebahl
Leipzig (Germany) |
63mm (140x) |
Schwächere Komponente nur als dauerhafte Aufhellung auf dem ersten Beugungsring erkennbar. |
Christopher Hay
Seeheim (Germany) |
71mm (32x) |
Eine "8" mit eindeutigen Positionen und relativen Helligkeiten der Komponenten. Blau-weiss. |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
gelb, trennbar bei 66x |
Mark McCarthy
178mm (205x) |
Very bright light blue A and 3 delta magnitude greenish B, close, about 3" separation. Physical with 2782 year period |
Christopher Hay
Seeheim (Germany) |
180mm (113x) |
Sauber getrennt, grosser Helligkeitsunterschied. Winkelabstand ungefähr 1.5mal so gross wie beim nahen STF1333. |
27 Hya |
SHJ105 |
AB |
4m.9 |
7m.0 |
229.1" |
211° |
2015 |
Hya |
09h20m29.03s / -09°33'20.30" |
DOO49 |
BC |
7m.0 |
11m.0 |
9.2" |
199° |
2015 |
GUI13 |
AD |
4m.9 |
16m.9 |
122.3" |
227° |
2015 |
Christopher Hay
Seeheim (Germany) |
7x45 |
AB: Handgehalten. AB weit auseinander, Helligkeitsdifferenz als sehr gross empfunden. Komponente B geht in's Blaue. Ein physikalischer Doppelstern in 222 Lichtjahren Abstand zu uns. |
STT199 |
AB |
6m.2 |
10m.0 |
5.6" |
142° |
2017 |
UMa |
09h20m43.76s / +51°15'57.80" |
Mark McCarthy
178mm (205x) |
An excellent pair, B is a very fine four delta point well separated from bright white A |
STF1331 |
AB |
8m.5 |
8m.7 |
0.9" |
153° |
2017 |
UMa |
09h20m46.02s / +61°20'58.40" |
AC |
8m.5 |
11m.6 |
13.5" |
186° |
2015 |
AD |
8m.5 |
14m.5 |
19.4" |
117° |
2015 |
AE |
8m.5 |
9m.8 |
139.1" |
223° |
2015 |
Robert Zebahl
Leipzig (Germany) |
152mm (180x) |
13.04.2020: Das weite Paar AE ist bereits bei 22x mit deutlichem Helligkeitsunterschied sichtbar, aber recht unauffällig. A wirkte weiß-gelblich, E eher orangefarben. Das enge Paar AB erschien bei 129x sofort länglich, teils als '8' erkennbar. Bei 180x war AB knapp getrennt mit haarfeinem, schwarzem Zwischenraum. Die schwache C-Komponente war nur indirekt sichtbar. Bester Anblick bei 180x. Die noch schwächere D-Komponente lag außerhalb der Reichweite. |
Mark McCarthy
178mm (205x) |
AB: Fine hairline split with seeing at 205x, better split at 333x, almost 1 delta mag, a very fine pair. Three other faint stars appear with averted vision, and can then barely hold them direct, all nearby and arranged in a right angle to A with two of them on one side. These are C, D, and E |
STF1339 |
9m.2 |
9m.9 |
1.5" |
65° |
2017 |
Lyn |
09h20m58.39s / +36°43'09.60" |
Mark McCarthy
508mm (333x) |
Faint B but still easily seen, resolves nicely with seeing, almost 2 delta mag, ~1.5" |
STF1338 |
AB |
6m.7 |
7m.1 |
1.1" |
313° |
2018 |
Lyn |
09h20m59.40s / +38°11'17.90" |
Mark McCarthy
508mm (333x) |
Wonderful light yellow stars, near equal, ~1" separation |
ES1541 |
10m.4 |
11m.2 |
8.2" |
23° |
2015 |
Lyn |
09h22m05.95s / +39°58'00.70" |
Mark McCarthy
508mm (333x) |
White and dull white pair, ~1 delta mag, wide ~8" |
STF1340 |
AB |
7m.1 |
9m.0 |
6.3" |
319° |
2018 |
UMa |
09h22m32.22s / +49°32'41.40" |
Mark McCarthy
178mm (205x) |
Very nice, 2 delta mag white stars, wide, makes an attractive scene |
STF1347 |
7m.3 |
8m.3 |
21.1" |
312° |
2016 |
Hya |
09h23m15.76s / +03°30'05.00" |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
10.04.2020: Bei 22x wunderschön getrennt zu sehen bei moderatem Abstand und Helligkeitsunterschied. Hauptkomponente wirkte weiß-bläulich, Begleiter leicht orange. Bei 44x wirkte die Hauptkomponente eher weiß-gelblich, der Begleiter zeigte eine klare Tendenz zu Orange. |
René Merting
100mm (20x) |
bei 32x ein auffälliges Sternpaar - Komponente B im Nordwesten ist gut abgesetzt erkennbar und ca. ein 3/4 Größenklasse schwächer - bei 20x rücken die beiden Sterne richtig schön zusammen und sind noch knapp getrennt erkennbar |
Uwe Pilz
Leipzig (Germany) |
105mm (88x) |
sehr schöner Farbkontrast |
AG165 |
9m.9 |
10m.1 |
1.4" |
16° |
2017 |
Leo |
09h23m19.01s / +22°10'45.30" |
Mark McCarthy
203mm (333x) |
A is white and hazy (in poor conditions) and B flashes into view with averted vision |
STF1344 |
9m.0 |
9m.5 |
3.8" |
102° |
2019 |
LMi |
09h23m28.35s / +39°08'05.10" |
Robert Zebahl
Leipzig (Germany) |
120mm (75x) |
Bei 50x und 75x getrennt, aber dicht beieinander mit geringem Helligkeitsunterschied. |
Mark McCarthy
317mm (553x) |
Faint near equal par, ~5". Nice. |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Doppelstern ist gut zu trennen, mit leichtem Helligkeitsunterschied. |
STT201 |
AB |
8m.5 |
9m.5 |
1.4" |
206° |
2017 |
Leo |
09h23m54.55s / +27°53'54.90" |
Mark McCarthy
203mm (205x) |
Extremely fine split, with seeing only, finest of the night, significant mag difference, just above 1" separation |
STF1348 |
AB |
7m.5 |
7m.6 |
2.0" |
314° |
2018 |
Hya |
09h24m28.48s / +06°21'01.80" |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
10.04.2020: Bei 67x deutlich länglich, bei 80x klar als '8' erkennbar. Bei 100x war ein sehr geringer Helligkeitsunterschied erahnbar, bei 133x sichtbar. Nahe dem Doppelstern STF 1355. |
Uwe Pilz
Leipzig (Germany) |
105mm (144x) |
Im selben Aufsuchfeld wie stf1355, ähnliche Erscheinung |
Mark McCarthy
203mm (333x) |
Very pretty half delta mag, ~2" pair, white. Sharp despite low declination |
A2477 |
7m.5 |
9m.2 |
0.5" |
5° |
2016 |
Leo |
09h24m31.21s / +18°08'29.10" |
Mark McCarthy
178mm (410x) |
Notched elongation, slight magnitude difference, light yellow stars. Physical with a 250 year period in a nearly circular orbit (we see it face-on) |
BU105, kappa Leo, 1 Leo |
AB |
4m.6 |
9m.7 |
2.0" |
209° |
2015 |
Leo |
09h24m39.28s / +26°10'56.80" |
AC |
4m.6 |
11m.1 |
147.7" |
212° |
2015 |
Uwe Pilz
Leipzig (Germany) |
105mm (180x) |
AB: Begleiter sitzt im ersten Ring |
Robert Zebahl
Leipzig (Germany) |
152mm (300x) |
AB: 22.04.2020: Das Seeing (2-3/5) war nicht ausreichend gut. Das Beugungsscheibchen war halbwegs gut sichtbar, die Beugungsringe verschmierten dagegen. Keine Trennung. |
Robert Zebahl
Leipzig (Germany) |
152mm (300x) |
AB: 24.04.2020: Durchschnittliche Luftruhe (3/5). Der schwache Begleiter war teils als deutliche Aufhellung im ersten Beugungsring der Hauptkomponente zu sehen. Keineswegs einfach. Ruhige Luft nötig. |
Mark McCarthy
178mm (148x) |
AB: Very tough, B is a very tiny point or fleck very closely split, need low power to reduce flaring from bright light yellow-orange A. Burnham discovered with his 6-inch and says: "A fine pair even with a small aperture." |
Mark McCarthy
317mm (553x) |
AB: Kappa Leonis: Very tough but palpable split. Seeing needed to settle to perfection for primary to resolve to just an airy disk without diffraction or flaring, and for a couple of seconds could see the much fainter ~10th magnitude B star as a pin-point, ~2" separation. Fleeting view. |
STT200 |
6m.5 |
8m.6 |
1.2" |
336° |
2019 |
UMa |
09h24m55.67s / +51°34'26.10" |
Mark McCarthy
317mm (553x) |
Light orange A, B a deeper orange, maybe because it's 2-3x fainter. B resolves from within A's diffraction when seeing settles, ~1". Wow! |
STF1346 |
AB |
7m.7 |
8m.6 |
5.8" |
314° |
2017 |
UMa |
09h25m37.88s / +54°00'57.50" |
BC |
8m.6 |
11m.8 |
93.9" |
188° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (44x) |
AB: 19.04.2020: Bei 31x sehr dicht klar sichtbarem Helligkeitsunterschied. Bei 44x sehr fein getrennt. Die Komponente A wirkte cremeweiß, B teils leicht orangefarben. |
Mark McCarthy
178mm (205x) |
AB: Easy 1 delta mag pair, pretty wide. Physical |
A222 |
9m.1 |
9m.4 |
0.4" |
5° |
2017 |
Leo |
09h26m02.33s / +28°39'01.50" |
Mark McCarthy
508mm (667x) |
Suspect it at all powers up to 667x, where I get a persistent clean split through the seeing. Light orange stars, 1 delta, PA just east of north. 155.08-year period, it will only cross the north line to head west by 2030 |
AG166 |
9m.1 |
11m.1 |
3.6" |
74° |
2018 |
Hya |
09h26m45.80s / +01°04'57.40" |
Mark McCarthy
203mm (333x) |
B balrey seen with direct vision, brighted with averted vision. Pretty. ~1-2 delta mag, ~4" |
A128 |
9m.6 |
10m.0 |
1.3" |
262° |
2017 |
Hya |
09h26m52.30s / -03°14'42.00" |
Mark McCarthy
203mm (333x) |
Fine pair, but need to wait for seeing for split. ~1" and half delta mag, white stars |
STF1355 |
7m.7 |
7m.8 |
1.8" |
357° |
2018 |
Hya |
09h27m16.69s / +06°13'59.00" |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
10.04.2020: Bei 67x deutlich länglich, gleich hell. Bei 80x ist eine Einkerbung wahrnehmbar. Bei 100x und 133x deutlich als '8' erkennbar. Nahe dem Doppelstern STF 1348. |
Uwe Pilz
Leipzig (Germany) |
105mm (144x) |
Im selben Aufsuchfeld wie stf1348, ähnliche Erscheinung |
Mark McCarthy
203mm (333x) |
Light yellow pair, near equal, very nice, ~2" |
STF1353 |
9m.9 |
10m.0 |
3.3" |
125° |
2017 |
Leo |
09h27m39.28s / +15°44'32.00" |
Mark McCarthy
203mm (205x) |
Faint & hazy in poor conditions. Elongated haze split with seeing, near equal |
Mark McCarthy
317mm (553x) |
Well separated near equal 9th magnitude white stars, ~4" |
TDS6583 |
10m.8 |
10m.9 |
0.5" |
71° |
1991 |
Lyn |
09h28m23.15s / +39°54'56.70" |
Mark McCarthy
508mm (533x) |
Just split with seeing, very tight, noticeable mag difference ~0.5-1, orange stars |
STF1356, ome Leo |
5m.7 |
7m.3 |
0.9" |
115° |
2019 |
Leo |
09h28m27.41s / +09°03'24.40" |
Mark McCarthy
178mm (445x) |
Ome Leo. Elongated at 205x, but nice clear disks with diffraction rings at 445x, plenty of room in the split, <1", slight magnitude difference, white stars. Physical with a 117.97-year period, it is nearing apastron where it will sit for the next two decades |
Mark McCarthy
203mm (205x) |
Omega Leo. Elongated & notched, similar magnitude, yellow-orange stars |
Mark McCarthy
317mm (553x) |
Very close but clean split, in each other's diffraction, half delta mag, white. |
41 Lyn, S598 |
AB |
5m.5 |
7m.8 |
69.7" |
160° |
2017 |
UMa |
09h28m39.99s / +45°36'06.50" |
Robert Zebahl
Leipzig (Germany) |
8x40 |
Relativ gut trennbar mit schwächerer Komponente. |
HJ1167, tau 1 Hya, 31 Hya |
4m.6 |
7m.3 |
67.5" |
4° |
2012 |
Hya |
09h29m08.84s / -02°46'08.20" |
Christopher Hay
Seeheim (Germany) |
15x45 |
Fernglas mit interner Stabilisierung, handgehalten. Weit getrennt, fast genau Nord-Süd orientiert. Hauptkomponente leicht gelblich. Ein physikalischer Doppelstern in nur 57 Lichtjahren Abstand zu uns. |
BAL2364 |
10m.0 |
10m.5 |
8.7" |
140° |
2015 |
Hya |
09h29m16.38s / +03°05'44.00" |
Mark McCarthy
203mm (333x) |
A bit more than half delta mag, wide stars. B is faint, nearly needs averted vision |
BU591 |
7m.8 |
8m.9 |
1.0" |
29° |
2017 |
Hya |
09h29m36.43s / -03°07'20.40" |
Mark McCarthy
203mm (333x) |
Very nice pair. Split with seeing, noticable mag difference, hairline only |
STF1360 |
AB |
8m.9 |
8m.9 |
13.8" |
242° |
2017 |
Leo |
09h30m35.95s / +10°36'06.40" |
Mark McCarthy
203mm (205x) |
GS Leo. Wide, light orange-yellow, near equal |
Mark McCarthy
317mm (553x) |
Unremarkable wide separation 8th mag stars. |
STF1349 |
7m.5 |
9m.0 |
19.2" |
166° |
2015 |
UMa |
09h31m09.89s / +67°32'28.40" |
René Merting
18x70 |
einfacher als der benachbarte Doppelstern STF 1350 - ordentlich getrennt - Komponente B ist 1 bis 1.5 Größenklassen schwächer |
Christopher Hay
Seeheim (Germany) |
60mm (25x) |
Bei 25x weit getrennt, deutlicher Helligkeitsunterschied, B ein feiner Lichtpunkt. B erscheint beim ersten Hinsehen hellblau, jener Farbeindruck verschwindet beim Schauen dann schnell – ein interessanter, mehrfach wiederholter Effekt. Laut Stelledoppie ein echtes physikalisches Paar. Sehr schön zusammen mit Struve 1350 im selben Gesichtsfeld. Ein wunderbares Doppel-Doppel für sehr kleine Öffnungen. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
19.04.2020: Bei 22x einfach zu trennen bei deutlichem Helligkeitsunterschied. Die Hauptkomponente wirkt weißlich, der Begleiter dunkler. Bei 44x erscheint die Hauptkomponente eher weiß-gelblich, der Begleiter gräulich. |
René Merting
100mm (32x) |
bei 32x stehen beide Sterne bequem getrennt auseinander - Komponente B im Süden ist eine knappe Größenklasse schwächer und kupfergrau - ein schönes Doppel-Doppel zusammen mit STF1350 gut 47' weiter südsüdöstlich |
Uwe Pilz
Leipzig (Germany) |
105mm (88x) |
sichtbar bei 21x |
René Merting
320mm (45x) |
bei 45x steht das Pärchen gut auseinander - Komponente B ist eine dreiviertel Größenklasse schwächer und wirkt grauweiß - A ist weiß mit einem zarten Stich ins Gelbe |
STF1365 |
7m.4 |
8m.0 |
3.5" |
156° |
2017 |
Hya |
09h31m31.26s / +01°27'55.10" |
René Merting
100mm (64x) |
bei 64x ist eine 8 erkennbar - in guten Momenten präsentieren sich beide Sterne knapp getrennt - Komponente B im SO ist eine halbe Größenklasse schwächer |
Mark McCarthy
203mm (333x) |
Wide off-yellow pair, ~4", ~1.5 delta mag |
STF1351, 23 UMa |
AB |
3m.6 |
9m.2 |
22.7" |
267° |
2015 |
UMa |
09h31m31.57s / +63°03'42.50" |
AC |
3m.7 |
11m.8 |
107.4" |
232° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
AB: 07.04.2020: Gut trennbar mit großem Helligkeitsunterschied, wobei der Begleiter nur als schwaches Sternchen dicht an der Hauptkomponente steht. Die Hauptkomponente selbst erschien hell und eher weißlich. |
Mark McCarthy
80mm (92x) |
AB: 23 UMa. Light yellow and much fainter wide B |
René Merting
100mm (32x) |
AB: bei 32x ist A gleißend, B im Westen extrem schwacher Lichtpunkt, gut 4-5 Größenklassen schwächer - bei 64x kann ich A ein wenig gebändigt erkennen und hat einen leichten Stich ins Gelbliche, B ist ordentlich abgesetzt |
Mark McCarthy
317mm (270x) |
AB: 23 UMa. Lovely yellow-white and 3x fainter wide B, white. |
René Merting
320mm (45x) |
AB: bei 45x ist Komponente B schwach sichtbar neben dem gelblich strahlenden 23 UMa - großer nicht abschätzbarer Helligkeitsunterschied |
SHJ107, 6 Leo |
5m.2 |
9m.3 |
37.1" |
77° |
2018 |
Leo |
09h31m57.58s / +09°42'56.80" |
Mark McCarthy
317mm (553x) |
A star is light orange & 3 delta mag to B star which is a white, well separated point |
STF1364 |
AB |
8m.6 |
9m.7 |
16.4" |
155° |
2015 |
Leo |
09h32m01.52s / +20°02'49.30" |
Mark McCarthy
317mm (553x) |
Unremarkable wide separation faint stars |
STF1359 |
AB |
9m.8 |
10m.8 |
7.5" |
54° |
2019 |
UMa |
09h32m58.20s / +56°14'59.10" |
Mark McCarthy
178mm (205x) |
Dim for a Struve, 1 delta mag, pretty wide, white stars. Not physical |
HN 29 |
6m.5 |
12m.1 |
27.8" |
263° |
2015 |
Leo |
09h33m18.32s / +28°22'04.90" |
Mark McCarthy
317mm (553x) |
Very wide, very faint B star. Not very exciting. |
HJ467 |
10m.0 |
11m.0 |
8.8" |
277° |
2015 |
Leo |
09h33m47.51s / +26°21'27.30" |
Robert Zebahl
Leipzig (Germany) |
152mm (129x) |
23.04.2020: Getrennt mit sichtbarem Helligkeitsunterschied. Unspektakulär. |
STF1350 |
AB |
8m.3 |
8m.3 |
10.2" |
249° |
2015 |
UMa |
09h34m19.56s / +66°47'42.30" |
AC |
8m.3 |
9m.2 |
131.0" |
216° |
2015 |
René Merting
18x70 |
AB: ein sehr enger Doppelstern, äußerst knapp getrennt … und das auch nur in guten Momenten, ansonsten wirkt das Paar wie eine Ameise - beide Sterne sind gleich hell - ein FG-Tester für 18x |
Christopher Hay
Seeheim (Germany) |
60mm (25x) |
AB: Bei 25x angenehm getrennt. Keinerlei Färbung gesehen. A erscheint heller als B, obwohl die Daten das nicht hergeben – vielleicht ein Produkt eigentlich unterschiedlicher Farbigkeit? Laut Stelledoppie kein physikalisches Paar. Struve 1349 schön zusammen im selben Gesichtsfeld. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
19.04.2020: Bei 22x A & B gleich hell und noch recht dicht zusammen. Die Komponente C ist in vielfachem Abstand sichtbar. Bei 44x zeigt sich bei A & B ein Farbunterschied: orange, weiß-bläulich. |
René Merting
100mm (32x) |
AB: bei 32x ein schönes enges Paar zweier gleich heller Sterne, knapp getrennt - STF1350 AB bildet mit vier ähnlich hellen Sternen westlich ein Muster, ähnlich einer Sense AC: bei 32x bildet STF1350 AB mit vier ähnlich hellen Sternen westlich ein Muster, ähnlich einer Sense - der erste der vier Sterne bzw. der nächststehende Stern südsüdwestlich mit mehr als zehnfachem Abstand AB ist Komponente C, er ist schätzungsweise eine halbe Größenklasse schwächer |
Uwe Pilz
Leipzig (Germany) |
105mm (88x) |
AB: trennbar bei 21x. Fast gleichell, aber deutlicher Farbkontrast, lohnend. |
Robert Zebahl
Leipzig (Germany) |
152mm (100x) |
Bei 22x sind bereits alle drei Komponenten zu sehen, wobei A & B noch recht eng beieinander stehen. Die Komponente C fällt weniger auf. Bei 69x und 100x zeigt das Paar AB einen schönen Farbkontrast: Die östliche Komponente erschien meist in einem leicht glänzenden Orange, während die andere Komponente eher weiß-bläulich wirkte. Während der Beobachtung wechselten die Farben allerdings zwischen beiden Komponenten. Zum Zeitpunkt der Beobachtung stand auch der recht helle Komet C/2019 Y4 Atlas im gleichen Gesichtsfeld - ein toller Anblick! Hinweis zur Zeichnung: Die Positionen der Sterne zueinander passen nicht ganz, so auch die Ausrichtung von dem Paar AB zu C. |
Christopher Hay
Seeheim (Germany) |
180mm (113x) |
AB: Sofort auffallend im 32x71 Supersucher beim Herumschwenken in der Gegend, ein sehr gleichmäßiges Paar gut bei dieser Vergrößerung getrennt. Genauere Betrachtung im 7-Zöller bei 113x offenbart einen zarten blau-orange Farbkontrast zwischen den Komponenten A und B. |
René Merting
320mm (45x) |
AB: bei 45x ein schönes enges Paar zweier gleich heller Sterne, beide strahlen weiß |
STF1369, DI Lyn |
AB |
7m.0 |
8m.0 |
25.1" |
150° |
2019 |
Lyn |
09h35m22.50s / +39°57'47.70" |
AC |
7m.0 |
8m.4 |
116.3" |
323° |
2017 |
BC |
8m.0 |
8m.4 |
141.6" |
324° |
2017 |
Christopher Hay
Seeheim (Germany) |
15x45 |
AB: Fernglas mit interner Stabilisierung, handgehalten. Klar getrennt, ein kompaktes Paar. Sitzt in einem hübschen Dreieck hellerer Sterne bestehend aus 42 und 43 Lyn nach Osten und einem leicht orangenen Stern nach Süden. AB ist ein physikalischer Doppelstern in 278 Lichtjahren Abstand zu uns. |
Mark McCarthy
508mm (333x) |
AB: DI Lyn Very wide and bright light yellow stars, ~1 delta mag. [did not notice COU 2084 Aa,Ab, 6.98/8.79 0.2"] |
STF1371 |
AB |
7m.9 |
10m.2 |
8.2" |
275° |
2015 |
Hya |
09h35m25.26s / +03°54'19.40" |
Mark McCarthy
203mm (333x) |
Nice yellowish A, widely separated from nealry three delta mag B |
HU1128, 11 LMi |
4m.8 |
12m.5 |
6.7" |
61° |
2012 |
LMi |
09h35m39.50s / +35°48'36.40" |
Mark McCarthy
317mm (553x) |
11 LMi: Very faint A & extremely faint B, wide separation. From the orbital chart this is approaching maximum elongation now (May 2017), by 2143 it will be 1". Only 39 light years away. |
STF1366 |
8m.4 |
10m.1 |
7.8" |
321° |
2019 |
UMa |
09h35m42.47s / +53°17'40.40" |
Mark McCarthy
178mm (205x) |
This one is a 2 delta magnitude pair, about 8", pretty wide. Physical. There is another wide near equal pair to the east about 30" away |
ES428 |
9m.3 |
11m.2 |
13.2" |
203° |
2015 |
Leo |
09h36m31.37s / +28°20'23.20" |
Mark McCarthy
203mm (205x) |
B pops out with averted vision, widely separated. A is white, and I can barely hold b direct. At the end of an attractive curve of four stars of similar magnitude |
STF1372 |
AB |
8m.5 |
8m.6 |
0.4" |
253° |
2020 |
Leo |
09h37m07.57s / +16°13'33.30" |
Mark McCarthy
508mm (445x) |
With apodising mask. All I have is an elongation with PA WSE, which seems to be where B is. A is canary yellow at low power, light yellow-orange with high power, and there is definite elongation. Physical with a 371-year period, it is slowly coming off apastron. Current separation 0.321" |
STF1362 |
7m.0 |
7m.2 |
4.9" |
125° |
2017 |
Dra |
09h37m56.18s / +73°04'49.50" |
Robert Zebahl
Leipzig (Germany) |
70mm (31x) |
21.04.2020: Bei 22x noch extrem dicht beisammen, aber trennbar. Bei 31x sehr feine Trennung. Beide Komponenten wirkten weiß. Sehr schöner Anblick! Bei 57x gut getrennt, ähnlich hell. Eine Komponente erschien weiß-gelblich mit einem Hauch von Orange, die andere eher weiß. |
STT204 |
AB |
6m.7 |
10m.7 |
8.3" |
99° |
2015 |
Leo |
09h38m45.69s / +10°46'39.80" |
Mark McCarthy
317mm (553x) |
Hard white A with B a haze, sharpened to point with averted vision. Well separated, 3 delta mag. |
STF1374 |
AB |
7m.3 |
8m.7 |
2.8" |
311° |
2017 |
LMi |
09h41m21.88s / +38°57'01.90" |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
01.04.2020: Bei 67x trennbar, aber schwierig wegen Überstrahlung durch die Hauptkomponente. Ab 80x klar trennbar mit deutlichem Helligkeitsunterschied. Der Begleiter steht dicht an der Hauptkomponente und erscheint als kleines Sternchen. Schöner Anblick. |
Robert Zebahl
Leipzig (Germany) |
120mm (168x) |
Bei 50x länglich, bei 75x als '8' erkennbar. Bei 168x klar getrennt mit deutlich schwächerer Komponente. |
Mark McCarthy
508mm (333x) |
Pretty orange-yellow stars, ~2 delta mag, ~3 separation |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Doppelstern ist gut zu trennen, mit klarem Helligkeitsunterschied. Beide Sterne erstrahlen weißlich. |
STT206 |
8m.3 |
11m.4 |
17.9" |
224° |
2015 |
Leo |
09h42m18.84s / +17°04'55.60" |
Mark McCarthy
317mm (277x) |
AB is the widely separated ~1 delta mag. star, about 40". There's fainter star popping out with averted vision in between them, which is the AD pair, 11th mag. |
Mark McCarthy
317mm (277x) |
STT205 |
8m.0 |
12m.6 |
12.0" |
202° |
2018 |
Lyn |
09h42m29.17s / +40°58'25.20" |
Mark McCarthy
317mm (277x) |
Yellow and orange pair ~1 delta mag. |
ES301 |
9m.8 |
11m.8 |
5.0" |
242° |
2019 |
Lyn |
09h42m42.81s / +40°17'30.90" |
Mark McCarthy
508mm (333x) |
B appears fine and clear with averted vision, blue color, and can then barely hold it with direct vision. Light yellow A. Very nice |
A2761 |
9m.0 |
9m.2 |
1.0" |
252° |
2017 |
Sex |
09h43m29.38s / +06°12'27.70" |
Mark McCarthy
508mm (333x) |
Attractive yellow-orange A and bluish B, well separated, about three delta mag |
STF1376 |
AB |
9m.1 |
9m.1 |
5.4" |
309° |
2017 |
UMa |
09h45m01.10s / +43°13'39.80" |
Mark McCarthy
178mm (205x) |
Clean white pair, near equal, wide about 5". Physical. 14th mag BC not seen |
HU630 |
9m.4 |
9m.6 |
2.2" |
74° |
2017 |
UMa |
09h47m36.09s / +50°57'17.30" |
Mark McCarthy
178mm (205x) |
Very fine pair, difficult in poor seeing and transparency, slight magnitude difference, about 2". Physcial |
STF1384 |
9m.8 |
10m.0 |
11.8" |
182° |
2015 |
Leo |
09h49m56.91s / +16°19'55.80" |
Mark McCarthy
178mm (205x) |
Faint pair, near equal, wide |
A2560 |
8m.8 |
9m.8 |
1.1" |
18° |
2017 |
Sex |
09h50m02.86s / +01°47'37.20" |
Mark McCarthy
508mm (533x) |
Challenging faint close companion suspected with 333x, but seen well with 533x. With seeing, light orange A and blue B, ~2 delta mag, ~1" separation |
HO369 |
AB |
8m.0 |
9m.8 |
0.4" |
99° |
2011 |
LMi |
09h51m09.34s / +36°29'20.80" |
Mark McCarthy
Fremont (California/USA) |
508mm (1067x) |
With 533x I can tell this is not single, but the elongation is too tentative. At 1067x the best I can manage is elongated notched, with seeing. Seeing and transparency are not good enough |
STF1381 |
8m.9 |
9m.2 |
0.8" |
187° |
2017 |
UMa |
09h51m15.22s / +60°37'00.10" |
Mark McCarthy
178mm (205x) |
Finest split with seeing, very small scale at this magnification, light orange star, very significant magnitude difference. Physical with a 1787.6479-year period, this is actually one to watch because it is rapidly nearing periastron and will tighten over the next couple of decades |
STT208, phi UMa |
5m.3 |
5m.4 |
0.4" |
310° |
2019 |
UMa |
09h52m06.36s / +54°03'51.40" |
Uwe Pilz
Leipzig (Germany) |
105mm (260x) |
länglich, schwierig |
Mark McCarthy
178mm (333x) |
Tough in poor seeing and transparency. Bright white A, significant delta magnitude, B's PA a little north of west. There are three stars in a wide triangle in the field, B points to base line. Physical with 104.6-year period, it will widen slightly and will reach apastron by 2040 |
Christopher Hay
Seeheim (Germany) |
180mm (290x) |
4. April 2021 (0,43" Distanz nach Datenbank zum Zeitpunkt der Beobachtung): Bei 200x oval. Bei 290x deutlich elongiert mit klarem Positionswinkel. Mein persönlicher Rekord für Doppelstern-Erkennung und Positionswinkel-Wahrnehmung mit dem 7-Zöller. |
A2139 |
8m.0 |
10m.7 |
2.0" |
292° |
2015 |
LMi |
09h52m15.53s / +40°58'13.40" |
Mark McCarthy
508mm (333x) |
White A and blue B, ~2" separation, >2 delta mag. [not physical] |
STF1389 |
9m.1 |
9m.5 |
2.4" |
290° |
2017 |
Leo |
09h52m26.17s / +26°58'53.80" |
Mark McCarthy
178mm (205x) |
White stars, around 1 delta mag, well separated. Physical with a 1454-year period |
AC5, gam Sex |
AB |
5m.4 |
6m.4 |
0.5" |
39° |
2019 |
Sex |
09h52m30.47s / -08°06'17.70" |
Mark McCarthy
508mm (533x) |
Gamma Sex: I get a split with seeing of nearly equal orange yellow stars, only momentarily |
STT209 |
7m.4 |
10m.3 |
4.9" |
310° |
2017 |
UMa |
09h53m17.23s / +50°37'16.30" |
Mark McCarthy
178mm (205x) |
Light yellow-orange A, B is very much fainter about 3 delta mag, wide about 5". Physical |
Mark McCarthy
317mm (553x) |
Light orange-yellow disk with faint diffraction ring. Extremely faint blue B ~4" can see it direct vision but it flashes forth with averted. |
S605, 9 Sex |
6m.9 |
8m.4 |
53.5" |
287° |
2019 |
Sex |
09h54m06.70s / +04°56'43.50" |
René Merting
100mm (20x) |
bei 32x ein weit auseinander stehendes Pärchen, das trotzdem schön anzusehen ist - Komponente B im Nordwesten ist gut 1.5 Magnituden schwächer - A samtgelb, B kupfergrau - zurück auf 20x sind beide Sterne auch noch komfortabel getrennt - die Farbe von A ist noch intensiver, jetzt eher rapsgelb |
STF1399 |
7m.7 |
8m.4 |
30.2" |
176° |
2017 |
Leo |
09h57m02.21s / +19°45'44.60" |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
Einfach bei schönem Abstand und deutlichem Helligkeitsunterschied. In der Nähe befindet sich eine auffällige Gruppe schwächerer Sterne. Die Hauptkomponente erschien warm-weiß, die schwächere Komponente irgendwie dunkler (teils bläulich, teils leicht orange). |
Uwe Pilz
Leipzig (Germany) |
105mm (53x) |
wie ein Schlangenbiß |
Mark McCarthy
317mm (553x) |
Faint pair, tough find dense with stars. 1 delta magnitude, wide separation. |
Berthold Fuchs
Wiesbaden (Germany) |
130mm |
einfacher DS |
STF1394 |
8m.9 |
9m.8 |
4.5" |
250° |
2019 |
UMa |
09h57m14.57s / +45°54'10.10" |
Mark McCarthy
178mm (205x) |
White stars, >1 delta mag, wide about 5". Physical |
TOK668 |
6m.1 |
7m.4 |
5.3" |
259° |
2015 |
Dra |
09h57m52.09s / +76°36'46.70" |
Robert Zebahl
Leipzig (Germany) |
70mm (57x) |
21.04.2020: An der Position war kein vergleichbar heller Stern sichtbar. |
STF1398 |
8m.1 |
11m.4 |
4.1" |
102° |
2017 |
UMa |
10h01m32.06s / +68°43'05.10" |
Mark McCarthy
317mm (553x) |
Near M81 & M82! Did not see the 11th mag, 3" B star, tried really hard. To the south is a tight = red pair. |
STT210 |
8m.5 |
9m.1 |
1.3" |
257° |
2016 |
UMa |
10h02m35.64s / +46°21'42.50" |
Mark McCarthy
178mm (205x) |
Excellent fine pair, with seeing, light yellow-orange, 1 delta mag, split but very close |
Mark McCarthy
317mm (553x) |
Yellow A and white B, very tight. Faint, seeing needs to be perfect to see B in the diffraction. |
STF1403 |
9m.6 |
9m.9 |
3.1" |
334° |
2019 |
Leo |
10h02m51.33s / +07°42'20.20" |
Mark McCarthy
178mm (205x) |
White stars, with seeing in poor conditions, well split, 2 delta mag |
HU631 |
8m.0 |
9m.3 |
0.8" |
258° |
2017 |
LMi |
10h03m59.08s / +32°38'48.80" |
Mark McCarthy
508mm (533x) |
Bright orange-yellow A star, B is a very small, faint blue point, ~1" separation, very much fainter ~3 delta mag |
TDS6998 |
11m.1 |
11m.4 |
0.8" |
297° |
1991 |
Leo |
10h04m05.09s / +27°26'54.30" |
Mark McCarthy
508mm (533x) |
Elongation flashing with averted vision, but its hazy, not clear |
STF1406 |
8m.4 |
9m.4 |
0.7" |
219° |
2017 |
LMi |
10h05m38.57s / +31°05'13.00" |
Mark McCarthy
317mm (553x) |
Very tight, kissing when seeing stills, 1 delta mag. white |
A2142 |
8m.0 |
8m.8 |
1.1" |
295° |
2016 |
LMi |
10h05m43.55s / +41°02'42.70" |
Mark McCarthy
317mm (553x) |
Very fine, split, ~1-1.5". 8th magnitude and 1.5 delta mag B, close split, very nice pair. In the 80mm finder this is one of a triangle of equal magnitude stars. |
STF1405 |
7m.3 |
11m.8 |
22.0" |
252° |
2015 |
LMi |
10h05m55.92s / +39°34'55.70" |
Mark McCarthy
317mm (553x) |
8th and 10th magnitudes. B is blurry with direct vision and flashes with averted. Wide split. A is white with a little yellow. |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Doppelstern ist sehr einfach zu trennen, aber hier liegt die Herausforderung beim großen Helligkeitsunterschied von über 4 mag. |
TDS569 |
10m.9 |
11m.1 |
2.3" |
89° |
2017 |
Leo |
10h06m33.24s / +26°01'34.50" |
Mark McCarthy
508mm (333x) |
Easy, near equal blue-white stars, >2" separation [not physical] |
COU166 |
10m.5 |
10m.5 |
2.4" |
159° |
2015 |
Leo |
10h07m15.20s / +22°15'17.20" |
Mark McCarthy
508mm (333x) |
B flashes into view with averted vision. Close pair ~2" separation |
GAN5, 31 Leo |
4m.4 |
13m.6 |
8.0" |
41° |
2008 |
Leo |
10h07m54.32s / +09°59'51.60" |
Mark McCarthy
178mm (205x) |
Light orange star, I did not see B. New designation, George Anderson, Born: Scotland, 1839. He was the observing assistant to Asaph Hall, and was at the Observatory from 1870 to 1900. Six discoveries to his name |
A2564 |
9m.8 |
10m.0 |
0.7" |
285° |
2017 |
Leo |
10h08m16.54s / +08°01'55.90" |
Mark McCarthy
178mm (333x) |
Tough, with seeing, faint and hazy white stars, hairline split when they sharpen with seeing. Suspected with 205x, 445x is too much power for the conditions |
alpha Leo, 32 Leo, Regulus |
STFB6 |
AB |
1m.4 |
8m.2 |
179.2" |
304° |
2019 |
Leo |
10h08m22.31s / +11°58'01.90" |
HDO127 |
AD |
1m.4 |
12m.1 |
195.3" |
274° |
2015 |
HDO127 |
BC |
8m.2 |
13m.2 |
2.2" |
94° |
2019 |
Christopher Hay
Seeheim (Germany) |
10x56 |
AB: Auf Stativ. Dank seines erheblichen Winkelabstands ist B weit genug vom überhellen A weg und sofort sichtbar. B erscheint lebhaft blau. Ermutigt von der unerwarteten Leichtigkeit der Sichtung im 10x56, schnalle ich das 7x50 auf das Stativ. Kein Erfolg, die Trennung wird durch viele Lichtstrahlen verhindert, welche im Bild von A ausgehen. Zu viel Austrittspupille? AB ist ein physikalischer Doppelstern in nur 79 Lichtjahren Abstand zu uns. |
Christopher Hay
Seeheim (Germany) |
15x60 |
AB: Auf Stativ. B ist ein feiner Lichtpunkt der etwas ins Blaue zu gehen scheint. Ein attraktives ungleiches Paar. |
René Merting
100mm (32x) |
AB: bei 32x ist B weit abgesetzt von A erkennbar - Regulus präsentiert sich strahlend weiß - B ist nur schwach weiß - kein echtes Doppelsternfeeling |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
AB: sehr weit; einfach |
Sarah Gebauer
Germany |
150mm (30x) |
AB: relativ dicht beieinander, ein Stern sehr hell und groß, der zweite schwach und klein |
Gerd Kohler
Langenzenn (Germany) |
254mm (76x) |
AB: Bläulich-weiß - leicht rötlich. Großer Helligkeitsunterschied. |
Gerd Kohler
254mm (76x) |
AD: Beim Begleiter von Regulus steht im fast gleichen Abstand, etwas nach Westen versetzt, ein sehr schwacher Stern. |
René Merting
Drachhausen (Germany) |
320mm (72x) |
AD: Komponente D ist südwestlich von B (STFB6) erkennbar, etwas weiter von A entfernt als B, klein und unscheinbar |
René Merting
320mm (72x) |
AB: bei 72x extrem weit getrennt erkennbar - Komponente A ist weißblau, die wesentlich schwächere Komponente B strahlt weißgrau |
STF1407 |
10m.2 |
10m.6 |
4.9" |
51° |
2018 |
UMa |
10h09m01.98s / +64°26'40.60" |
Mark McCarthy
317mm (553x) |
Near equal faint 10th-11th mag white stars, 4" |
A1988 |
10m.0 |
9m.8 |
0.4" |
223° |
2008 |
Leo |
10h09m04.77s / +25°31'03.20" |
Mark McCarthy
508mm (533x) |
Clean split with seeing, light orange stars, fairly equal but noticeable magnitude difference |
A2144 |
AB |
9m.8 |
11m.6 |
2.7" |
287° |
2015 |
Leo |
10h09m09.51s / +21°15'29.90" |
Mark McCarthy
508mm (205x) |
Light yellow-white A and B is easily seen, ~2" separation, yellow, almost two delta mag |
A2565 |
8m.8 |
10m.3 |
1.3" |
260° |
2015 |
Leo |
10h10m54.49s / +07°41'40.50" |
Mark McCarthy
178mm (205x) |
Amazingly I'm able to split it at 205x, 2 delta mag white stars, little more than 1" separation, very small scale |
COU287 |
10m.5 |
10m.8 |
1.4" |
95° |
2017 |
Leo |
10h10m58.48s / +18°33'58.60" |
Mark McCarthy
508mm (205x) |
Near equal, light orange, split about 1" |
HU874 |
6m.9 |
7m.9 |
0.2" |
288° |
2019 |
Leo |
10h11m38.19s / +13°21'18.70" |
Mark McCarthy
508mm (1067x) |
34 Leo. A notched elongation is the best I could see, not resolved well. Slight mag difference but really too hard to tell A from B. My PA estimate is off 90-degrees. This is rapidly closing and will be at periastron by the middle of 2022, opening again and should be better detectable again by 2029 when it will be 0.208". 17.962-year period |
STF1413 |
9m.8 |
9m.8 |
1.8" |
270° |
2019 |
Leo |
10h12m18.72s / +16°20'54.30" |
Mark McCarthy
317mm (553x) |
Very close ~2", very faint equal pair. |
Mark McCarthy
508mm (333x) |
Very pretty equal pair, white, close ~1.5" |
STT213 |
AB |
8m.6 |
9m.8 |
1.1" |
121° |
2017 |
Leo |
10h13m08.88s / +27°25'10.50" |
Mark McCarthy
178mm (333x) |
Very tough at this aperture, I suspected it at 205x but can more consistently see it with 333x. A is a light orange star and B splits but is very tight, needed averted vision at first but it brightens and holds with foveal coaxing, but it s very faint indeed. Physical with a 192-year period, it's now at apastron and will stay there a while |
Mark McCarthy
317mm (277x) |
Bright yellow A, ~2 magnitudes fainter B, very wide separation. |
L10 |
10m.0 |
10m.5 |
1.1" |
352° |
2017 |
Leo |
10h14m33.75s / +17°53'24.40" |
Mark McCarthy
178mm (205x) |
Unbelievably fine split with 205x! Very small scale, the dim stars are small disks so the separation is clean. Very slight magnitude difference, white stars, really fine. Higher magnification hazes the image too much. T. Lewis of Greenwich Observatory |
STF1417 |
9m.2 |
9m.3 |
2.4" |
78° |
2019 |
Leo |
10h15m08.60s / +19°07'27.30" |
Mark McCarthy
317mm (553x) |
Faint, close, but well split pair, 3", B resolves better with averted vision. |
Mark McCarthy
508mm (333x) |
Equal yellow-white pair, ~2" |
HU1254 |
AB |
10m.1 |
10m.4 |
0.6" |
15° |
2016 |
Leo |
10h15m10.48s / +11°52'43.50" |
Mark McCarthy
508mm (333x) |
Elongated to hairline split. Noticeable magnitude difference |
STT215 |
7m.2 |
7m.5 |
1.5" |
176° |
2019 |
Leo |
10h16m16.05s / +17°44'24.60" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
Teils getrennt wirkend, teils als '8' sichtbar. Kein Helligkeitsunterschied erkennbar. |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
trennbar bei 120x |
Mark McCarthy
317mm (277x) |
very close split (1.7" separation) near equal bright white stars |
Mark McCarthy
508mm (333x) |
Near equal light yellow stars, ~1.5" |
SHY552 |
7m.4 |
8m.8 |
107.2" |
6° |
2015 |
LMi |
10h16m38.13s / +41°16'33.00" |
Mark McCarthy
317mm (277x) |
Pair of stars in a perfect triangle of widely separated stars looking like Leo's rump. ~8th, 8.5, and 9th mag. |
STFA18, zeta Leo, 36 Leo, Adhafera |
3m.5 |
6m.0 |
331.3" |
337° |
2015 |
Leo |
10h16m41.41s / +23°25'02.40" |
René Merting
100mm (32x) |
ein helles extrem weit getrenntes Paar - zwischen A im SO und B im NW sind etwas versetzt noch zwei schwache Sterne zu erkennen, aber beide ohne Bezug zu STFA18 |
BVD81 |
5m.8 |
10m.0 |
79.6" |
28° |
2015 |
Leo |
10h16m41.83s / +25°22'14.50" |
Mark McCarthy
317mm (553x) |
Very wide 2-3 delta mag yellow-orange & whitish-yellow. |
STF1419 |
8m.9 |
9m.9 |
4.5" |
225° |
2019 |
Leo |
10h17m02.94s / +10°06'51.70" |
Mark McCarthy
317mm (553x) |
Very faint pair, 1 delta mag, PA west ~4-5" |
Mark McCarthy
508mm (333x) |
Light yellow-white A and slightly blue B, wide ~4", ~1 delta mag |
Berthold Fuchs
130mm |
schwieriger DS |
STT523, 39 Leo |
5m.8 |
11m.3 |
7.9" |
300° |
2017 |
Leo |
10h17m14.53s / +23°06'22.30" |
René Merting
100mm (213x) |
bei 142x habe ich das Gefühl, Komponente B ab und an westlich von A ganz schwach im ersten Beugungsring ausmachen zu können, aber noch unsicher - bei 213x dann zeigt B sich eindeutig und kann ab und an auch mal länger gesehen werden |
Mark McCarthy
508mm (333x) |
39 Leo. ! Nice bright light yellow-orange A star. B is very small, very faint, ~8" separation, a single little point, barely has its own light |
STF1415 |
AB |
6m.7 |
7m.3 |
16.5" |
168° |
2019 |
UMa |
10h17m50.61s / +71°03'38.90" |
AC |
6m.7 |
10m.8 |
153.3" |
13° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
AB: 07.04.2020: Bei 22x sofort als Doppelstern auffällig, mittelhell mit eher geringem Helligkeitsunterschied. A wirkte weißlich, B leicht orange, teils bräunlich. Bei 44x ähnlicher Farbeindruck: A weiß-bläulich, B leicht orange. |
Robert Zebahl
Leipzig (Germany) |
70mm (44x) |
AB: 03.04.2021: Bei 12x einfach getrennt, moderater Helligkeitsunterschied, unspektakulär. Bei 44x wirkte A zart gelblich, B erschien in sehr hellem Blau. Der Farbkontrast war sehr dezent. |
René Merting
320mm (45x) |
AB: bei 45x ein eng stehendes ordentlich getrenntes Paar - Komponente B im Süden wirkt weißgrau gegen die gut eine halbe Größenklasse hellere A-Komponente - das Paar sieht schick aus, es wird von drei schwächeren Sternen umrahmt |
A2369 |
8m.5 |
9m.7 |
1.0" |
296° |
2017 |
Leo |
10h17m59.92s / +17°11'11.90" |
Mark McCarthy
508mm (533x) |
Needed higher magnification to get it. Orange star with a faint but nice star in first diffraction ring, much fainter, ~1". Nice |
STF1421 |
8m.2 |
9m.1 |
4.5" |
330° |
2019 |
Leo |
10h18m05.54s / +27°31'27.90" |
René Merting
100mm (64x) |
bei 64x ein schönes enges knapp getrenntes Pärchen - Komponente B im NW ist gut eine Größenklasse schwächer und wirkt dadurch dumpfer |
Mark McCarthy
317mm (553x) |
Not difficult, 1 delta mag, 5" or so. Bluish. |
Mark McCarthy
508mm (333x) |
Wide pair, >1 delta mag, white tinged with yellow, ~5" |
Berthold Fuchs
130mm |
schwieriger DS |
STF1420 |
9m.1 |
10m.6 |
2.2" |
318° |
2015 |
LMi |
10h18m33.30s / +39°06'37.90" |
Mark McCarthy
317mm (553x) |
Faint orange and 2 delta mag B ~2". |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Doppelstern ist noch gerade so dauerhaft sicher zu trennen, bei einem recht sichtbaren Helligkeitsunterschied von über 1,5 mag. |
COU170 |
11m.1 |
11m.8 |
0.7" |
122° |
1985 |
Leo |
10h18m41.27s / +21°55'22.80" |
Mark McCarthy
508mm (333x) |
Can't see the pair but there seems to be two galaxies in the field. [NGC 3189 & 3187] |
STF1423 |
9m.4 |
10m.1 |
0.7" |
308° |
2018 |
Leo |
10h19m10.64s / +20°33'48.10" |
Mark McCarthy
317mm (553x) |
Tough! Elongated to hairline split. |
Mark McCarthy
508mm (533x) |
Split with seeing, light orange A and very faint, ~3 delta mag B, very close, within diffraction ring <1" |
STF1424, gamma Leo, 41 Leo, Algieba |
AB |
2m.4 |
3m.6 |
4.7" |
127° |
2020 |
Leo |
10h19m58.35s / +19°50'29.40" |
Christopher Hay
Seeheim (Germany) |
20x60 |
Handgehalten im Liegestuhl, Fernglas mit interner Stabilisierung. 14 May 2022 (4,7" Distanz nach Datenbank): Birnenförmig. Ein starkes orange-zitroniges Gelb, eine fruchtige Sache. Positionswinkel ohne vorherige Kenntnis auf 140° geschätzt, passt gut genug, zumal bei dieser niedrigen Vergrößerung, zum Datenbank-Wert von 127°. |
Christopher Hay
Seeheim (Germany) |
44x100 |
21. Mai 2022 (4,7" Distanz nach Datenbank): Haarfein getrennt, etwas schwierig wegen der mit diesem achromatischen (nicht apochromatischen) Fernglas aufgeblähten Sterne. Beide Komponenten orange, der Begleiter ins Gelbe gehend. Dünne durchziehende Wolken machen die Sternabbildung kompakter und die Trennung wesentlich deutlicher. Am Deutlichsten kurz bevor die Wolken so dicht werden, dass sie das Sternpaar verschlucken. |
Christopher Hay
Seeheim (Germany) |
36mm (50x) |
21. Mai 2022 (4,7" Distanz nach Datenbank): Bei 40x tief eingekerbt, bei 50x mit etwas Mühe getrennt, bei 66x klar und deutlich getrennt. |
Robert Zebahl
Leipzig (Germany) |
55mm (38x) |
Bei 38x trennbar, aber sehr dicht zusammen bei deutlichem Helligkeitsunterschied. Ab 56x wunderschöner Anblick beider Komponenten, deren Farbe ähnlich war. |
Robert Zebahl
Leipzig (Germany) |
55mm (59x) |
Sehr schön getrenntes, ungleiches Paar. A wirkte gelb-orange, B weiß-bläulich. |
Christopher Hay
Seeheim (Germany) |
60mm (58x) |
Bei 25x ist Algieba schon sehr gestreckt. Bei 58x hauchfein getrennt mit deutlichem Helligkeitsunterschied. Bei 70x zwar stabiler getrennt, aber nicht so ansprechend wie bei 58x. Beide Komponenten erscheinen fett orange. |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
Bei 67x noch relativ enges Paar, aber gut getrennt bei recht deutlichem Helligkeitsunterschied. Bei 100x einfach zu trennen und sichtbarem Farbunterschied: A gelblich bis leicht orange, B weiß-gelblich. |
Robert Zebahl
Leipzig (Germany) |
102mm (125x) |
Sehr schön getrennt bei wunderbarem Helligkeits- und Farbkontrast. Hauptkomponente leicht orange, Begleiter gelblich. |
Stefan Loibl
Rosenheim (Germany) |
102mm (164x) |
sehr heller Doppelstern, mit leichtem Farbunterschied |
Uwe Pilz
Leipzig (Germany) |
105mm (120x) |
schon bei 37x sehenswert; trennbar bei 55x; orange-blauweiß |
Robert Zebahl
Leipzig (Germany) |
120mm (66x) |
Bei 48x als Doppelstern einfach zu erkennen. Erscheint als '8'. Bei 66x knapp, aber sicher getrennt bei sichtbarem Helligkeitsunterschied. |
Winfried Kräling
Marburg (Germany) |
127mm (250x) |
08.04.2018: merklicher Helligkeitsunterschied, A = gelb-orange, B = gelb-orange |
Sarah Gebauer
Germany |
150mm (83x) |
bei 83x sauber getrennt, ein leichter Farbunterschied (Weiß und helles Gelb) sichtbar |
Mark McCarthy
317mm (277x) |
Algieba: Bright yellow and yellow-orange pair, 1 delta mag, 4-6" |
René Merting
320mm (240x) |
bei 240x sehe ich zwei ordentlich getrennte Sterne (naja, nicht wirklich Sterne, sondern wild zappelnde Glitzerbällchen) - Komponente A strahlt in einem zarten Gelb, B ist weiß - zurück auf 144x sehe ich nur ein Stäbchen mit leichter Einschnürung, so wild tanzen die Sterne |
Mark McCarthy
508mm (333x) |
Algieba. Very bright, A is yellow-orange and B is a blazing white orange, like a fire |
HJL1057 |
8m.0 |
8m.8 |
205.6" |
167° |
2015 |
LMi |
10h20m02.46s / +33°33'17.30" |
Christopher Hay
Seeheim (Germany) |
7x45 |
Handgehalten. Weit getrennt, Begleiter jedoch sehr schwach bei dieser geringen Vergrößerung und beim vorstädtischen FST 5m1 im Zielgebiet. STTA104 ein Grad nordöstlich hat einen praktisch identischen Winkelabstand, ist jedoch viel stärker. Der Charme dieses Paares liegt weniger im visuellen Anblick als in der Überlegung, dass dies ein physikalischer Doppelstern in 287 Lichtjahren Abstand zu uns ist. |
STF1426 |
AB-C |
7m.3 |
9m.4 |
7.6" |
9° |
2018 |
Leo |
10h20m32.32s / +06°25'47.60" |
AB |
8m.0 |
8m.3 |
0.9" |
313° |
2018 |
René Merting
100mm (107x) |
AB: bei 213x in guten Momenten als Stäbchen erkennbar AB-C: bei 107x ist nördlich vom Hauptstern AB eine gut 2 Größenklassen schwächere Komponente erkennbar - AB ist weiß, C ist grau |
Robert Zebahl
Leipzig (Germany) |
102mm (160x) |
AB-C: Recht großer Abstand und damit einfach zu trennen. Die C-Komponente war allerdings ziemlich schwach. |
Robert Zebahl
Leipzig (Germany) |
102mm (160x) |
AB: Auf den ersten Blick länglich, bei genauem Hinsehen als '8' erkennbar. |
Stefan Loibl
102mm (164x) |
AB-C leicht trennbar, A-B nicht trennbar |
Uwe Pilz
Leipzig (Germany) |
105mm (288x) |
A-B länglich, C weit |
Mark McCarthy
203mm (333x) |
AB: Split with seeing, white, very close, near equal. Part of plus one, a two delta mag not far away |
STF1425 |
9m.9 |
10m.7 |
4.8" |
358° |
2017 |
UMa |
10h21m34.14s / +46°09'07.60" |
Mark McCarthy
178mm (205x) |
Faint pair, about 1 delta, wide about 5". Physical |
Mark McCarthy
317mm (553x) |
Very faint pair, ~4-5" orange and blue, 0.5 delta mag. |
STF1427 |
8m.2 |
8m.5 |
9.3" |
215° |
2018 |
UMa |
10h22m00.53s / +43°54'19.30" |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
19.04.2020: Bei 22x sehr fein getrennt, aber noch dicht beieinander. Ein sehr geringer Helligkeitsunterschied war sichtbar. Bei 44x ebenfalls schöner Anblick. In beiden Vergrößerungen konnte ich Farbunterschiede erkennen: blassorange, grau-blau. |
Mark McCarthy
178mm (205x) |
White stars, typical Struve, not quite 1 delta mag, wide |
Mark McCarthy
317mm (277x) |
8th magnitude orange star and a very wide 1 delta mag B. |
BU1321 |
9m.6 |
12m.5 |
1.8" |
130° |
2002 |
Leo |
10h22m03.20s / +12°25'42.00" |
Mark McCarthy
508mm (205x) |
White A and very faint B which I can just hold with direct vision, ~3", it brightens with averted vision |
STT216 |
7m.4 |
10m.3 |
2.3" |
231° |
2016 |
Leo |
10h22m43.81s / +15°20'39.70" |
Mark McCarthy
317mm (277x) |
A white and bright (7.3), B red & much fainter (10.3), a close split (2"). |
Mark McCarthy
508mm (333x) |
Yellow and very much fainter orange B, 1 delta mag, ~4" separated |
A1990 |
9m.5 |
9m.6 |
1.5" |
290° |
2017 |
Leo |
10h23m25.93s / +26°29'38.70" |
Mark McCarthy
508mm (333x) |
Near equal, elongated in a haze but does resolve to two stars with seeing, a bit more than 1" separation |
A1991 |
10m.1 |
10m.4 |
1.5" |
191° |
2019 |
Leo |
10h23m34.87s / +26°17'26.10" |
Mark McCarthy
508mm (333x) |
Near equal, split with seeing, ~1" separation |
HJ2530 |
AC |
6m.4 |
6m.7 |
201.6" |
63° |
2015 |
Sex |
10h24m13.15s / +02°22'05.10" |
Christopher Hay
Seeheim (Germany) |
7x45 |
Handgehalten. Ein weites, visuell starkes, gleichmäßig helles Paar. Komponente A leicht orange, C farblich kälter. Hübsch in 8,6° Gesichtsfeld mit Alpha und Beta Sextantis. |
Christopher Hay
Seeheim (Germany) |
12x36 |
Fernglas mit interner Stabilisierung, handgehalten. Ein weites, sehr gleichmäßig helles Paar, visuell starke Erscheinung bei dieser Vergrößerung in 5.6° Gesichtsfeld. Komponente A leicht orange, C leicht blau. |
STTA104 |
7m.2 |
7m.3 |
209.0" |
287° |
2013 |
LMi |
10h24m22.19s / +34°10'35.00" |
Christopher Hay
Seeheim (Germany) |
7x45 |
Handgehalten. Ein weites, auffälliges und gleichmäßiges Paar. Hübsch zusammen mit dem Dreieck aus 27/28/30 LMi, und dadurch auch leicht aufzufinden. HJL1057 ebenfalls im Gesichtsfeld südwestlich. Ein zarter Farbkontrast im Dreieck macht das Feld sehr attraktiv: 30 LMi ist gelblich-weiss, 28 rötlich-weiss, 27 LMi kälter. Im 15x45 Fernglas wird STTA104 fast zu weit um als Doppelstern empfunden zu werden, die Farbnuancen im Dreick werden jedoch deutlicher. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
11.04.2020: Sehr weites Paar ähnlich heller Komponenten, farblich unauffällig. Der Doppelstern steht nahe der Sterne 27, 28 & 30 LMi und ist wohl eher geeignet für kleinere Ferngläser. |
STF1429 |
9m.1 |
9m.3 |
0.8" |
155° |
2017 |
Leo |
10h25m01.79s / +24°36'44.10" |
Mark McCarthy
317mm (553x) |
Very tough. Faint, need averted vision to brighten and sharpen. Elongated to clean split in the best moments with seeing, near equal magnitude |
Mark McCarthy
508mm (533x) |
Elongated to hairline at 333x, split at 533x. Light orange stars, near equal |
POU3080 |
9m.7 |
10m.9 |
5.7" |
102° |
2015 |
Leo |
10h25m29.14s / +23°21'38.60" |
Mark McCarthy
508mm (333x) |
Light orange-yellow A and ~1.5 delta mag B, white, well separated |
HU877 |
9m.1 |
10m.5 |
1.7" |
250° |
2015 |
LMi |
10h25m32.60s / +36°46'59.00" |
Mark McCarthy
508mm (333x) |
Very fine white pair, ~2 delta mag, ~2" separation, very nice |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Doppelstern ist nur phasenweise klar zu trennen, bei einem Helligkeitsunterschied von ca. 1,5 mag. |
STF1431 |
7m.8 |
9m.1 |
3.6" |
76° |
2019 |
Leo |
10h25m35.12s / +08°46'35.40" |
Robert Zebahl
Leipzig (Germany) |
70mm (67x) |
Bei 67x trennbar, aber sehr dicht zusammen mit deutlichem Helligkeitsunterschied. Bei 100x einfach zu trennen. Daneben strahlt der Stern 44 Leo in einem auffälligen, hellen Orange. |
René Merting
100mm (104x) |
bei 64x ist B nordöstlich von A erkennbar, beide bilden eine 8, wobei so schwach ist, dass die 8 gewöhnungsbedürftig ist - bei 107x ist B dann knapp getrennt erkennbar - Helligkeitsunterschied eine Größenklasse - verschönert wird die Szenerie durch den unmittelbar westlich stehenden orange strahlenden Stern 44 Leo |
Uwe Pilz
Leipzig (Germany) |
105mm (88x) |
nahe 44 Leo |
Mark McCarthy
178mm (205x) |
Delicate light blue pair, >1 delta mag, 3" separation, not far from a bright light orange star 44 Leo. Very pretty view |
STF1428 |
8m.0 |
8m.4 |
2.8" |
89° |
2018 |
UMa |
10h25m59.00s / +52°37'18.30" |
Mark McCarthy
178mm (205x) |
An attractive pair, clean white stars about 1 delta mag and 3". Physical |
STT217 |
7m.8 |
8m.6 |
0.8" |
151° |
2019 |
Leo |
10h26m53.01s / +17°13'09.90" |
Mark McCarthy
508mm (333x) |
Just split cleanly, ~1 delta mag, yellow-tinged white stars. Nice close pair |
STF1434 |
9m.5 |
9m.7 |
6.4" |
282° |
2018 |
Leo |
10h27m08.41s / +18°03'44.60" |
Mark McCarthy
508mm (333x) |
Near equal white, wide |
HJ832, 45 Leo |
6m.0 |
12m.4 |
37.8" |
132° |
2019 |
Leo |
10h27m38.99s / +09°45'44.70" |
Uwe Pilz
Leipzig (Germany) |
105mm (260x) |
nicht schwierig |
HU879, bet LMi |
4m.6 |
6m.0 |
0.5" |
228° |
2017 |
LMi |
10h27m53.09s / +36°42'26.90" |
Mark McCarthy
508mm (533x) |
Beta LMi. With apodizing mask I see an out of roundness / olive shape, too much glare to tell orientation, no other field stars |
STF1435 |
10m.3 |
10m.7 |
8.5" |
203° |
2015 |
Leo |
10h27m57.15s / +19°49'44.70" |
Mark McCarthy
508mm (205x) |
Faint for a Struve, but easy white stars, wide, about half a delta mag. Physical |
A2152 |
AB |
9m.6 |
9m.1 |
0.4" |
57° |
2008 |
LMi |
10h28m58.56s / +34°51'48.00" |
Mark McCarthy
508mm (1067x) |
Marginal. Momentary glimpses of a fine point very nearly a hairline split. Pretty orange star, slightly fainter |
STF1438 |
9m.6 |
11m.1 |
2.5" |
276° |
2016 |
Leo |
10h29m13.82s / +13°08'59.50" |
Mark McCarthy
178mm (205x) |
Faint pair, B is wide and seen with averted vision only. Not physical |
HEI762 |
10m.5 |
11m.4 |
2.6" |
145° |
2017 |
Sex |
10h29m59.21s / +05°42'37.30" |
Mark McCarthy
508mm (333x) |
B just hangs in there with direct vision, flashes brighter with averted vision. ~2.5" ~1 delta mag |
STF1439 |
8m.3 |
8m.9 |
1.4" |
73° |
2019 |
Leo |
10h30m06.42s / +20°48'04.30" |
Mark McCarthy
508mm (333x) |
Very clean images, light yellow-orange stars, ~1 delta mag, well split, very pretty |
ES1905 |
AB |
8m.6 |
12m.6 |
41.6" |
68° |
2015 |
UMa |
10h30m16.09s / +63°20'55.40" |
Mark McCarthy
317mm (553x) |
White with 3x fainter, 11th mag, B. Very wide. |
STF1436 |
8m.8 |
10m.4 |
10.5" |
254° |
2016 |
UMa |
10h30m22.86s / +56°21'20.00" |
Mark McCarthy
178mm (205x) |
Slightly dimmer than a typical Struve, about 2 delta mag, very wide |
STF1441 |
AB |
6m.5 |
8m.8 |
2.8" |
167° |
2015 |
Sex |
10h30m58.78s / -07°38'15.20" |
AC |
6m.5 |
10m.1 |
61.7" |
315° |
2015 |
René Merting
100mm (107x) |
AB: bei 107x ploppt südlich ganz dicht ein schwacher Stern auf - bei 142x ist B dann deutlicher und knapp getrennt erkennbar - A ist gelblich und strahlt etwas von seiner Färbung auf B ab AC: bei 32x ist C nordwestlich von A erkennbar - C steht gut abgesetzt und ist mindestens 3 Größenklassen schwächer |
HU880 |
10m.1 |
10m.4 |
0.9" |
144° |
2017 |
LMi |
10h31m14.44s / +37°07'27.40" |
Mark McCarthy
508mm (333x) |
Exceptionally fine split, white stars |
HJ482, 33 LMi |
AB |
5m.9 |
11m.8 |
57.7" |
247° |
2014 |
LMi |
10h31m51.36s / +32°22'46.30" |
Mark McCarthy
317mm (553x) |
33 LMi. Very bright A, with widely separated, very faint B. |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Bei diesem Doppelstern liegt die Herausforderung beim sehr großen Helligkeitsunterschied von gut 6 mag. Komponente A strahlt schön weißlich. |
STF1442 |
8m.2 |
8m.5 |
13.3" |
157° |
2017 |
Leo |
10h31m58.95s / +22°02'22.00" |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
27.04.2021: Bei 22x auffällig mit ähnlich hellen Komponenten und moderatem Abstand, farblich leicht verschieden. Die Zuordnung der Farben war schwierig. Bei 44x verbesserter Farbeindruck: dunkelorange & eisblau. |
René Merting
100mm (20x) |
bei 32x schön anzusehen - ein eng stehendes Pärchen mit einem kaum spürbaren Helligkeitsunterschied - leichter Farbkontrast, der nicht wirklich greifbar ist - zurück auf 20x sind beide Sterne auch noch knapp getrennt erkennbar |
Mark McCarthy
508mm (333x) |
Near equal white with a hint of yellow, wide. [not physical] |
Berthold Fuchs
130mm |
schwieriger DS |
HDS1511 |
7m.5 |
9m.1 |
0.1" |
38° |
2012 |
Leo |
10h32m17.36s / +24°26'32.10" |
Mark McCarthy
508mm (1067x) |
Out of round olive, airy disk swimming in diffraction |
STF1443 |
9m.9 |
10m.0 |
5.3" |
161° |
2018 |
LMi |
10h33m17.07s / +37°40'25.00" |
Robert Zebahl
Leipzig (Germany) |
120mm (50x) |
Bei 50x knapp getrennt bei geringem Abstand. Bei 75x deutlich getrennt mit geringem Helligkeitsunterschied. |
Mark McCarthy
317mm (553x) |
White, near equal, 3-4" |
Mark McCarthy
508mm (333x) |
Wide pair, white, ~1 delta |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Gut zu trennender Doppelstern mit identischer Helligkeit. Beide Sterne leuchten weißlich. |
Berthold Fuchs
130mm |
einfacher DS |
STF1446 |
9m.3 |
10m.0 |
5.5" |
250° |
2018 |
Leo |
10h33m33.32s / +15°12'49.60" |
Mark McCarthy
178mm (205x) |
Fairly faint for a Struve, 1 delta mag, pretty wide, white. Physical |
Mark McCarthy
317mm (553x) |
Two faint stars, pretty well separated, 1 delta mag. |
STF1447 |
7m.5 |
8m.9 |
4.6" |
124° |
2019 |
Leo |
10h33m47.28s / +23°21'02.40" |
Robert Zebahl
Leipzig (Germany) |
70mm (67x) |
10.04.2020: Bei 44x sehr dichtes, ungleiches Paar. Die Hauptkomponente wirkt weißlich mit einem sehr schwachen Begleiter. Bei 67x ist der schwache Begleiter deutlich zu sehen, aber noch dicht an der Hauptkomponente stehend. |
René Merting
100mm (64x) |
bei 64x ist Komponente B ganz schwach südöstlich von A knapp abgesetzt zu erkennen - Helligkeitsunterschied 2-3 Größenklassen (lt. Stelle Doppie nur 1.36 mag) |
Mark McCarthy
317mm (277x) |
Both white, A (7.5) 2x brighter than B (8.9). Wide separation (4"). |
Mark McCarthy
508mm (333x) |
Nice pair of yellow stars, ~1.5 delta mag, wide |
HU1338 & STF1448 |
HU1338 |
AB |
7m.5 |
13m.6 |
3.5" |
184° |
1920 |
Leo |
10h34m23.24s / +21°35'36.40" |
STF1448 |
AC |
7m.5 |
9m.6 |
11.0" |
259° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (44x) |
STF1448 (AC): 10.04.2020: Moderater Abstand, deutlicher Helligkeitsunterschied. A zeigt sich in einem schönen, hellen Orange, C als schwacher, gräulicher Begleiter. |
René Merting
100mm (32x) |
STF1448 (AC): bei 32x zeigt sich Komponente C im NW von A knapp getrennt - C ist nur ein Hauch von einem Stern - Helligkeitsunterschied enorm, ich schätze 3 Größenklassen (nur 2 mag laut Stelle Doppie) |
Mark McCarthy
317mm (277x) |
STF1448 (AC): Pretty orange and blue pair, 2 delta mag, ~10" |
Mark McCarthy
317mm (277x) |
STF1448 (AC): An orange and blue pair. Fainter than Alberio but just as pretty. |
STF1450, 49 Leo |
5m.8 |
7m.9 |
2.0" |
157° |
2019 |
Leo |
10h35m02.16s / +08°39'01.60" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
B-Komponente als eindeutige Aufhellung des ersten Beugungsrings der Hauptkomponente im richtigen Positionswinkel sichtbar. |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
Begleiter klebt am ersten Ring |
Mark McCarthy
317mm (277x) |
White and slight yellow, ~6-7", nice pair. |
Mark McCarthy
508mm (333x) |
49 Leo. Striking pair, light yellow A and a richer orange-yellow B, ~2.5 delta mag, well split |
STF1451 |
AB |
9m.8 |
12m.2 |
8.5" |
271° |
2015 |
Leo |
10h35m24.86s / +26°16'09.70" |
Mark McCarthy
508mm (333x) |
Easy pair, wide, ~1 delta mag |
STF1454 |
9m.0 |
11m.0 |
1.3" |
358° |
2016 |
LMi |
10h38m11.10s / +26°36'24.80" |
Mark McCarthy
317mm (553x) |
Quite tough: averted vision only, very tight, similar magnitude, when seeing stills. |
STF1456 |
8m.2 |
9m.8 |
13.7" |
45° |
2016 |
Sex |
10h38m17.33s / +01°14'38.40" |
René Merting
100mm (32x) |
bei 32x ein schön eng stehendes, gut getrenntes Sternpaar - A weiß, B im NO leicht bläulich - Helligkeitsunterschied 1.5 Magnituden |
Mark McCarthy
508mm (333x) |
Easy bright pair, almost 2 delta mag, wide light orange stars |
STT222 |
7m.0 |
11m.7 |
4.0" |
339° |
2015 |
UMa |
10h38m19.89s / +60°07'30.10" |
Mark McCarthy
317mm (553x) |
Extremely faint star, B seen with averted vision, PA to north. |
STF1457 |
7m.7 |
8m.2 |
1.9" |
334° |
2019 |
Sex |
10h38m43.14s / +05°44'02.90" |
René Merting
100mm (142x) |
bei 107x sehe ich in guten Momenten eine Stäbchen, manchmal auch schon leichte Einschnürungen - bei 142x zeigt sich das Sternpaar deutlich als 8 und mit etwas Geduld auch getrennt - B steht im NO und ist eine halbe Größenklasse schwächer - bei 213x dann eindeutige Trennung |
Mark McCarthy
508mm (333x) |
Attractive bright sunny yellow pair, more than 2" separation, slight mag difference |
J79 |
9m.0 |
10m.1 |
1.5" |
132° |
2017 |
Leo |
10h38m54.93s / +07°21'26.00" |
Mark McCarthy
508mm (333x) |
Very nice, ~2 delta mag, close ~2" separation, blue-white stars |
BAR39 |
10m.7 |
12m.2 |
1.1" |
289° |
1959 |
Leo |
10h39m21.56s / +22°28'02.30" |
Mark McCarthy
508mm (533x) |
B appears with averted vision, very tight |
STT225 |
AC |
8m.5 |
10m.4 |
6.5" |
357° |
2017 |
Leo |
10h40m03.23s / +19°14'25.60" |
Mark McCarthy
508mm (333x) |
Very light yellow-orange A and ~2 delta mag, wide B. Did not see PER 2 AB, 8.53/10.60 0.4" |
STF1459 |
8m.3 |
8m.8 |
4.6" |
153° |
2019 |
LMi |
10h40m12.46s / +38°24'11.40" |
René Merting
100mm (64x) |
bei 32x muss ich sehr genau hinschauen, dann ist eine kleine 8 zu erkennen - bei 64x zeigen sich dann beide Sterne knapp getrennt - Komponente B im SO nicht ganz so glänzend weiß wie A |
Robert Zebahl
Leipzig (Germany) |
120mm (50x) |
Deutlich getrennt mit sichtbarem Helligkeitsunterschied. |
Mark McCarthy
317mm (553x) |
Pretty yellow-orange, 0.5 delta mag, 5-6". |
Mark McCarthy
508mm (333x) |
Wide light yellow-orange stars, ~2 delta |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Gut zu trennender Doppelstern mit leichtem Helligkeitsunterschied. Beide Komponenten leuchten gelblich weiß. |
STF1460 |
8m.7 |
8m.9 |
3.9" |
161° |
2019 |
UMa |
10h40m35.04s / +42°09'11.60" |
Robert Zebahl
Leipzig (Germany) |
70mm (57x) |
19.04.2020: Bei 44x als '8' klar erkennbar, insgesamt recht schwach und beinahe getrennt. Die Komponenten schienen gleich hell. Bei 57x getrennt, gleich hell. |
Mark McCarthy
178mm (205x) |
Very pretty near equal pair of white stars, well separated about 5". Not physical |
J1369 |
10m.1 |
11m.7 |
7.5" |
121° |
2017 |
Sex |
10h41m02.02s / +03°35'46.60" |
Mark McCarthy
508mm (333x) |
Easy, ~2 delta mag, pretty wide [I didn't think it would be physical but it is] |
STF1464 |
AB |
8m.3 |
10m.3 |
5.8" |
302° |
2016 |
Sex |
10h41m35.43s / -00°16'20.80" |
Mark McCarthy
508mm (333x) |
Light yellow A and blue B, pretty wide, attractive pair. Likely part of plus one [STF 1464 AC 8.26/10.51 66.7"] |
STT227 |
8m.3 |
8m.8 |
0.9" |
2° |
2017 |
Leo |
10h41m41.58s / +10°44'22.30" |
Mark McCarthy
317mm (277x) |
Faint reddish pair, near equal, just split but hazy, poor view. |
Mark McCarthy
508mm (333x) |
Pure white stars, ~1" separation, ~2 delta mag, very fine and striking |
A2483 |
9m.4 |
11m.4 |
2.2" |
227° |
2001 |
Leo |
10h42m08.09s / +16°17'03.60" |
Mark McCarthy
508mm (333x) |
Wow, very fine ~2 delta mag, ~2" separation. Very much fainter B about as faint as can be before needing averted vision |
A2768 |
6m.9 |
8m.4 |
0.6" |
238° |
2019 |
Sex |
10h42m37.53s / +03°34'58.90" |
Mark McCarthy
317mm (277x) |
Feels like a not round disk, but uncertain. |
Mark McCarthy
508mm (533x) |
34 Sex. Surprisingly difficult. Light orange A and a very small 2 delta mag pin prick appears within the first diffraction ring, so about 0.5" separation. Very tough. With seeing only |
STF1462 |
AB |
7m.4 |
10m.1 |
8.3" |
174° |
2015 |
UMa |
10h42m52.23s / +50°47'57.30" |
Mark McCarthy
178mm (205x) |
White A, very faint B, wide |
STF1463 |
9m.3 |
10m.4 |
7.9" |
258° |
2018 |
UMa |
10h42m54.25s / +46°41'25.20" |
Mark McCarthy
178mm (205x) |
Dim pair, significant magnitude difference, white, fairly wide. Physical |
BU913, 40 LMi |
AB |
5m.5 |
12m.6 |
23.8" |
108° |
2015 |
LMi |
10h43m01.95s / +26°19'32.50" |
Mark McCarthy
317mm (553x) |
40 LMi: Bright A, very faint B, very wide separation. B looks like a ghost. |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Leicht zu trennender Doppelstern mit sehr großem Helligkeitsunterschied. Komponente B ist schon mit 12,6 mag sehr schwach. |
STF1465 |
9m.8 |
10m.1 |
2.2" |
11° |
2019 |
UMa |
10h43m13.35s / +44°37'41.60" |
Mark McCarthy
178mm (205x) |
Faint pair, considerable magnitude difference, fairly wide |
Mark McCarthy
317mm (553x) |
Near equal well split ~3". 9th-10th mag. |
STF1466, 35 Sex |
AB |
6m.2 |
7m.1 |
6.8" |
240° |
2019 |
Sex |
10h43m20.91s / +04°44'51.60" |
René Merting
100mm (32x) |
bei 32x ein wunderschönes dicht stehendes Pärchen, knapp getrennt - Helligkeitsunterschied eine halbe Größenklasse - leichter Farbkontrast, A leicht gelblich |
Robert Zebahl
Leipzig (Germany) |
102mm (28x) |
Sehr schöner Anblick. Bei 28x deutlicher Helligkeitsunterschied und einfach zu trennen, wobei A leicht orange wirkte. Bei 86x erschien B grau-blau. |
Mark McCarthy
317mm (277x) |
Orange and a little blue, wide separation, bright, half a delta mag. |
Mark McCarthy
508mm (333x) |
35 Sex. Easy, wide, yellow-orange pair, ~2 delta mag. AC much further separated and 1 delta mag. [SkyTools showed a close CD pair: Hint of elongation with 533x, elongation is larger but more hazy at 1067x, but not resolved into stars -- but this one not in Stelle Doppie.] |
SMA75 |
AB |
5m.2 |
7m.3 |
288.0" |
88° |
2018 |
UMa |
10h43m32.89s / +46°12'13.90" |
AC |
5m.2 |
11m.1 |
152.0" |
16° |
2018 |
AD |
5m.2 |
9m.2 |
381.6" |
45° |
2018 |
BD |
7m.3 |
9m.2 |
259.2" |
357° |
2018 |
Christopher Hay
Seeheim (Germany) |
7x45 |
AB: Weit auseinander und großer Helligkeitsunterschied, A und B wirken dennoch absolut zusammengehörig. Kein besonderer Farbeindruck. Smart 75 AB (auch als Shaya (SHY) 216 bekannt) ist ein physikalischer Doppelstern in 121 Lichtjahren Abstand zu uns. Dies ist zufällig fast genau der gleiche Abstand zu uns wie Alpha UMa AC, ein weiteres Fernglas-Paar in UMa. |
Mark McCarthy
317mm (553x) |
AB: Wide 80mm finder pair, white and slight yellow. In the scope there are some more faint stars about, so it is likely a small cluster -- 7 stars in the system. |
A2771 |
9m.2 |
9m.7 |
0.6" |
112° |
2018 |
Sex |
10h44m38.71s / +05°29'55.00" |
Mark McCarthy
508mm (533x) |
Elongated with 333x but a good clean split with 533x. Stars settle to fine points with seeing , ~1 delta mag, ~0.5" separation |
STF1468 |
9m.7 |
9m.7 |
4.4" |
334° |
2019 |
Leo |
10h44m39.96s / +20°42'18.50" |
Mark McCarthy
317mm (553x) |
Faint near equal, close but a nice split |
Mark McCarthy
508mm (333x) |
Near equal white stars, wide |
STF1467 |
8m.6 |
10m.8 |
3.9" |
288° |
2018 |
UMa |
10h45m15.60s / +44°58'11.20" |
Mark McCarthy
178mm (205x) |
Nice! Very faint B, around 2 delta mag, pretty wide. I can just see B with direct vision and hold it in poor transparency. Physical |
Mark McCarthy
317mm (553x) |
Orange star with extremely faint wide split B. Needed averted vision to notice it as a smudge but could see it with direct vision as a small blue point when seeing stills. ~2 delta mag. |
42 LMi |
S612 |
AB |
5m.3 |
7m.8 |
196.4" |
174° |
2019 |
LMi |
10h45m51.91s / +30°40'56.60" |
ARN3 |
AC |
5m.3 |
8m.3 |
424.6" |
94° |
2013 |
Christopher Hay
Seeheim (Germany) |
15x45 |
Fernglas mit interner Stabilisierung, handgehalten. Beim Herumschwenken in der Himmelsgegend ist das Dreieck aus ABC sofort auffallend. Komponente A kalt-weiss, B rötlich, C keine besondere Farbwahrnehmung. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
11.04.2020: Weites, auffälliges Dreifachsystem, welches gut mit einem Fernglas beobachtet werden kann. A: recht hell, eher weiß, B: leicht orangefarben, C: Tendenz zu Orange. |
Mark McCarthy
80mm (13x) |
AB: Very widely separated, split in finder (196"!). white A with a slightly red B |
STT228 |
8m.2 |
8m.9 |
1.7" |
170° |
2017 |
Leo |
10h47m16.93s / +22°34'32.00" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
27.04.2021: Leicht länglich. |
Mark McCarthy
508mm (533x) |
With fine focus, split with seeing, ~1 delta mag, ~1" separation. Pretty tough needed 533x to split, elongated at 333x |
STF1473 |
AB |
7m.7 |
8m.9 |
30.5" |
10° |
2015 |
Hya |
10h47m36.55s / -15°37'36.10" |
AC |
7m.7 |
12m.5 |
97.6" |
333° |
2015 |
Christopher Hay
Seeheim (Germany) |
25x80 |
AC: Weit getrennt, kein bestimmter Farbeindruck. Visuell unspektakulär, STF1474 stiehlt die Schau im Gesichtsfeld. Ein physikalischer Doppelstern in 271 Lichtjahren Abstand zu uns. |
STF1474 |
AB |
6m.7 |
7m.0 |
65.9" |
28° |
2017 |
Hya |
10h47m37.93s / -15°15'42.90" |
AC |
6m.7 |
7m.6 |
72.6" |
27° |
2017 |
BC |
7m.0 |
7m.6 |
6.7" |
18° |
2017 |
Christopher Hay
Seeheim (Germany) |
7x50 |
AB: Auf Stativ. Deutlich getrennt. Komponente A erscheint zunächst leicht orange, aber der Eindruck schwindet schnell. Ein hübsches gleichmäßig helles Paar. Der leuchtend-roter Veränderlicher U Hydrae (ein roter Riese) wenige Grad nordwestlich verleiht dem Gesichtsfeld von 7,3° einen visuellen Glanzpunkt. |
Christopher Hay
Seeheim (Germany) |
25x80 |
AB: So weit auseinander, dass sie nicht mehr wie ein Doppelstern wirken. A bläulich, kein bestimmter Farbeindruck von BC. BC: Haarfein getrennt. Die Wirkung von ABC ist weniger jene eines 3fach-Systems, eher ein "Doppel im Doppel". |
STF1469 |
AB |
7m.7 |
10m.4 |
10.9" |
324° |
2015 |
UMa |
10h47m43.86s / +65°27'36.40" |
Mark McCarthy
317mm (553x) |
White and 2x fainter B, wide. |
STT229 |
7m.6 |
7m.9 |
0.6" |
262° |
2019 |
UMa |
10h48m02.55s / +41°06'35.80" |
Mark McCarthy
317mm (553x) |
Just wider than a thin hair split of equal white stars, ~8th mag. 0.63"! in 40 years it will be 0.2" |
A2572 |
9m.8 |
10m.1 |
0.8" |
121° |
2015 |
Sex |
10h48m48.88s / +01°24'12.20" |
Mark McCarthy
508mm (333x) |
Hairline split, white, near equal |
STF1476, 40 Sex |
7m.1 |
7m.8 |
2.4" |
17° |
2017 |
Sex |
10h49m17.31s / -04°01'23.80" |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
31.03.2020: Bei 67x sehr knapp getrenntes, ungleiches Paar. Auch bei 100x noch immer recht dicht zusammenstehend. Der Begleiter erscheint nur als schwaches Sternchen. |
René Merting
100mm (107x) |
bei 64x ist meist eine schöne 8 zu erkennen, manchmal aber auch nur ein Stäbchen - bei 107x zeigt sich B im Norden von A knapp abgetrennt - geringer Helligkeitsunterschied |
Mark McCarthy
317mm (340x) |
Tight white of equal brightness |
A2370 |
9m.9 |
10m.9 |
2.7" |
335° |
2017 |
Leo |
10h49m34.11s / +16°30'24.90" |
Mark McCarthy
508mm (333x) |
(Red giant branch star) Very nice, white A and B blue for faintness, very clear, widely split, ~ 2 delta mag |
A2371 |
9m.8 |
11m.0 |
2.7" |
320° |
2017 |
Leo |
10h49m45.93s / +18°05'09.60" |
Mark McCarthy
508mm (333x) |
Nice ~2 delta mag pair, ~2.5" separation. [not physical] |
A2373 |
8m.8 |
8m.8 |
0.2" |
228° |
2011 |
Leo |
10h52m02.94s / +16°05'44.00" |
Mark McCarthy
508mm (889x) |
Just split hairline at best moments, touching disks otherwise, 1 delta mag, very tough. In my notes I put the PA to the NNE, but this is a reversal of what is listed as SE. 100.26-year period, 0.218" now, it will make a barely perceptible arc to the south in the next couple of decades |
STF1482 |
8m.2 |
9m.2 |
12.0" |
305° |
2017 |
Leo |
10h52m10.61s / +07°27'39.40" |
René Merting
18x70 |
zunächst ist ein längliches Stäbchen erkennbar, in guten Momenten maximal eine 8, aber nur im Ansatz |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
27.04.2021: Bei 22x sehr schön getrennt mit moderatem Helligkeitsunterschied. Ein leichter Farbunterschied war erkennbar, welcher sich bei 44x verbesserte: zart orange & leicht bläulich. |
René Merting
100mm (32x) |
bei 32x ein enges Pärchen, knapp getrennt - Helligkeitsunterschied eine dreiviertel Größenklasse - A strahlt warmweiß, B reinweiß |
Mark McCarthy
178mm (205x) |
Very light orange, wide, 1 delta mag. Physical |
René Merting
320mm (72x) |
bei 144x ordentlich getrennt - Komponente A im Südosten ist weißgelb, B ist eine dreiviertel Größenklasse schwächer und weißbläulich - zurück auf 72x wirkt B farblich noch kühler - weiterhin gute Trennung zwischen beiden Sternen |
HO376 |
9m.9 |
11m.1 |
3.0" |
218° |
2012 |
Leo |
10h52m40.84s / +23°12'03.60" |
Mark McCarthy
508mm (333x) |
White A, B just seen direct, wide ~4", decent pair |
S617 |
6m.2 |
8m.7 |
35.2" |
179° |
2017 |
Leo |
10h53m24.96s / -02°15'18.80" |
René Merting
18x70 |
unauffällig - Komponente B ist ordentlich getrennt südlich von A erkennbar - Helligkeitsunterschied eine Magnitude (2.49 mag lt. Stelle Doppie!) - A reinweiß, B grau |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
31.03.2020: Klar getrennt mit deutlichem Helligkeitsunterschied. Farblich unauffällig. In der Nähe befindet sich noch ein hellerer Stern. |
René Merting
100mm (32x) |
bei 32x ist B im Süden von A mit ordentlich Abstand erkennbar - A ist warmweiß, leicht gelblich, die deutlich schwächere Komponente B wirkt farblos - das Sternpaar ist interessant in Kombination mit dem unmittelbar nordöstlich stehenden gelblich strahlenden Stern Rho? Leo |
Mark McCarthy
317mm (340x) |
Yellow A, blue B, wide separation |
STF1483 |
9m.5 |
9m.6 |
2.4" |
244° |
2019 |
UMa |
10h54m30.84s / +47°29'35.80" |
Mark McCarthy
317mm (553x) |
Two near equal wide split, fairly faint, 9.5 mag. |
STT230 |
8m.7 |
11m.9 |
9.2" |
40° |
2015 |
Leo |
10h54m32.46s / +20°46'22.90" |
Mark McCarthy
508mm (333x) |
Cool effect of B appearing with averted vision like a meteor out of the corner of my eye. Wide. [not physical] |
SKF59 |
7m.4 |
11m.5 |
34.1" |
59° |
2015 |
LMi |
10h54m44.78s / +36°45'31.70" |
Mark McCarthy
317mm (553x) |
Orange-yellow star with very wide separated very faint B, need averted vision. |
BU597 |
9m.2 |
10m.1 |
0.9" |
47° |
2015 |
Leo |
10h54m49.70s / +23°45'20.70" |
Mark McCarthy
508mm (333x) |
~2 delta mag and ~1" separation, light orange stars, very steady images. Really nice |
STF1486 |
8m.4 |
9m.7 |
31.6" |
100° |
2015 |
UMa |
10h55m01.14s / +52°07'18.20" |
René Merting
100mm (20x) |
bei 32x einfach, ordentliche Trennung - Komponente B im Osten ist halb so hell wie A - eigenartiger Farbkontrast, B wie so oft grau, aber A ist orangebraun - zurück auf 20x sind beide Sterne auch noch gut getrennt erkennbar |
STF1487, 54 Leo |
4m.5 |
6m.3 |
6.8" |
112° |
2019 |
Leo |
10h55m36.80s / +24°44'59.00" |
Robert Zebahl
Leipzig (Germany) |
55mm (27x) |
Bei 27x trennbar, aber sehr dicht zusammen bei deutlichem Helligkeitsunterschied. Bei 71x einfach zu trennen. Kein Farbunterschied erkennbar. |
Robert Zebahl
Leipzig (Germany) |
70mm (67x) |
13.04.2021: Bei 67x wunderschön getrennt mit deutlich sichtbarem Helligkeitsunterschied. Besonders schön ist der dezente Farbunterschied: hellgelb & hellblau. Bei 133x ist die Farbe des Begleiters etwas blasser: grau-blau. Die Hauptkomponente strahlt noch immer in einem schönen Hellgelb. |
Winfried Kräling
Marburg (Germany) |
127mm (250x) |
13.03.2017: Hauptkomponente gelblich, Begleiter bläulich, deutlicher Helligkeitsunterschied. Ebenfalls bei V=60x getrennt. |
Mark McCarthy
317mm (277x) |
Bright white pair (4.5, 6.3) wide sep (6") |
Mark McCarthy
508mm (333x) |
54 Leo. Brilliant pair, light white-yellow stars, ~2 delta mag, wide |
BRT2405 |
11m.4 |
11m.9 |
4.2" |
222° |
2015 |
Leo |
10h56m44.65s / +22°15'27.20" |
Mark McCarthy
508mm (333x) |
A is a blue star, B appearing with averted vision |
STF1492 |
8m.0 |
10m.2 |
21.6" |
165° |
2017 |
LMi |
10h57m35.85s / +30°39'09.70" |
Mark McCarthy
317mm (553x) |
3 delta mag white with widely separated B |
Karsten Kopp
Köln (Germany) |
600mm (180x) |
Leichter Doppelstern mit einem Helligkeitsunterschied von ca. 2,0 mag. |
STF1491 |
AB |
8m.4 |
11m.3 |
14.1" |
33° |
2017 |
UMa |
10h58m50.42s / +61°42'56.40" |
Mark McCarthy
178mm (205x) |
A is a light yellow, B not seen with direct at first, but it flashes brightly with averted vision, and I then can hold it direct. Very well split, three delta. Physical |
Mark McCarthy
317mm (553x) |
Orange and blue, pretty wide, ~3 delta mag. |
STF1495 |
7m.2 |
8m.8 |
34.2" |
36° |
2016 |
UMa |
10h59m49.47s / +58°54'23.30" |
René Merting
18x70 |
ein komfortabel getrenntes Sternpaar mit leichtem Farbkontrast - B steht versetzt nördlich von A und ist 1.5 bis 2 Magnituden schwächer |
René Merting
100mm (20x) |
bei 32x ein weit getrenntes Paar - Komponente B im NO ist knapp zwei Magnituden schwächer - A strahlend weiß, B die graue Maus, wie es sich gehört für die schwächere Komponente - zurück auf 20x immernoch ordentliche Trennung, der Helligkeitsunterschied wirkt nicht mehr ganz so groß |
René Merting
320mm (45x) |
bei 45x weit getrennt - ein schönes farbiges Kontrastpaar - Komponente B im NO ist gut 1.5 Größenklassen schwächer und strahlt kupfergrau, A dagegen ist weißgelb |
STF1500 |
7m.9 |
8m.3 |
1.3" |
299° |
2017 |
Leo |
11h00m02.02s / -03°28'16.50" |
Mark McCarthy
178mm (205x) |
Very fine white stars, ~1 delta, ~1.5". Physical with a 680-year period |
AG173 |
9m.9 |
10m.5 |
2.2" |
127° |
2015 |
Leo |
11h00m32.39s / +02°58'09.20" |
Mark McCarthy
178mm (205x) |
Faint pair, rather difficult given the poor transparency, white, ~1 delta mag, ~2-3" |
WEI26 |
9m.5 |
10m.0 |
14.2" |
174° |
2015 |
Leo |
11h01m12.86s / +21°05'28.90" |
Mark McCarthy
178mm (205x) |
Dual white stars, near equal, wide |
UC2059 & HDS1574 & COU1422 |
UC2059 |
AB |
7m.5 |
10m.7 |
46.9" |
46° |
2015 |
UMa |
11h01m45.73s / +36°40'41.60" |
HDS1574 |
Aa-Ab |
7m.6 |
11m.1 |
0.3" |
99° |
2019 |
COU1422 |
Ba-Bb |
11m.2 |
11m.5 |
0.6" |
38° |
2008 |
Mark McCarthy
317mm (553x) |
UC2059 (AB): Pretty well separated, 1.5 delta mag, not remarkable as I hoped given the odd designation. |
Mark McCarthy
762mm (1219x) |
COU1422 (Ba-Bb): Cou 1422 is a pair of 11th magnitude stars very close to UC 2059 -- best I could get of Cou 1422 was an elongation with the seeing. Tried 1219x without improving the elongation. |
COU961 |
AB |
7m.2 |
9m.4 |
1.2" |
328° |
2016 |
LMi |
11h01m49.33s / +29°52'16.60" |
Mark McCarthy
508mm (533x) |
Very close, tough split, ~2 delta, ~1" separation, light orange A. [Did not notice CHR 34 Aa,Ab 0.3"] |
STF1502 |
9m.5 |
10m.4 |
12.9" |
285° |
2015 |
Leo |
11h02m01.28s / +14°37'14.70" |
Mark McCarthy
178mm (205x) |
1 delta mag, wide, white A and light blue B. Physical |
STF1503, AM Leo |
9m.4 |
11m.1 |
11.6" |
271° |
2016 |
Leo |
11h02m10.88s / +09°53'42.60" |
Mark McCarthy
178mm (205x) |
Double double with HJ 172. Physical |
HJ172 |
10m.2 |
10m.3 |
13.6" |
94° |
2016 |
Leo |
11h02m12.14s / +09°44'59.80" |
Mark McCarthy
178mm (205x) |
Double-double with STF 1503. I wonder how either observer could have missed the other pair, they're identical. Physical. Checking GAIA EDR3, I find the two A stars are not physical (different PM) |
A1590 |
8m.9 |
9m.6 |
1.5" |
328° |
2017 |
UMa |
11h03m27.91s / +54°31'33.00" |
Mark McCarthy
178mm (205x) |
Light orange A and blue-green B, >1" separation, half delta mag. Physical with 163-year period, it's not at apastron and won't make significant change for several decades |
BU1077, alpha UMa, 50 UMa, Dubhe |
AB |
2m.0 |
5m.0 |
0.8" |
342° |
2017 |
UMa |
11h03m43.84s / +61°45'04.00" |
AC |
2m.0 |
7m.2 |
370.0" |
205° |
2015 |
Christopher Hay
Seeheim (Germany) |
7x45 |
AC: Sehr weit auseinander aber dennoch zusammengehörig erscheinend. A ist goldgelb, C scheint blau zu sein, eine sehr attraktive Erscheinung. A, B und C sind ein physikalisches Dreifachsystem in 123 Lichtjahren Abstand zu uns. Dies ist zufällig fast genau der gleiche Abstand zu uns wie SMA75 AB, ein weiteres Fernglas-Paar in UMa. |
René Merting
18x70 |
AC: Dubhe oder Alpha Ursae Majoris - hm, naja - C zeigt sich im Süden in Riesenabstand zum intensivgelbem A - Komponente C wirkt dagegen wie eine graue Maus und der Helligkeitsunterschied ist so enorm, dass er nicht abschätzbar ist |
Christopher Hay
Seeheim (Germany) |
36mm (8x) |
Weit getrennt aber visuell noch zusammengehörig erscheinend (ist auch ein physikalisches Paar). A is cremig goldweiss. C wirkt sofort zartblau, der Farbeindruck schwindet jedoch nach einer Weile. Bei paralleler Beobachtung mit 3-Zöller bei 32x und 7-Zöller bei 67x will kein Farbeindruck von C aufkommen, ein interessanter Unterschied zur Beobachtung mit anderthalb Zoll. Ich schaue mit 7x42 Fernglas kurz hin, wieder erscheint C blau, wie immer mit Ferngläser aller Art. |
Robert Zebahl
Leipzig (Germany) |
70mm (22x) |
AC: 07.04.2020: Sehr weites, ungleiches & unscheinbares Paar. A erschien weiß-gelblich, bei C konnte ich keine Farbe ausmachen. |
STF1504 |
7m.9 |
8m.1 |
1.2" |
126° |
2018 |
Leo |
11h03m58.93s / +03°38'19.30" |
Robert Zebahl
Leipzig (Germany) |
70mm (133x) |
31.03.2020: Möglicherweise wirkte der Doppelstern leicht länglich. Beobachtung ist aber zu unsicher. |
Robert Zebahl
Leipzig (Germany) |
102mm (160x) |
28.03.2020: Bei 125x deutlich als '8' erkennbar. Beide Komponenten wirkten ähnlich hell. Bei 160x und 187x berührten sich die Beugungsscheibchen noch leicht. |
Mark McCarthy
178mm (205x) |
Lovely split, small scale at this magnification, white stars, <1 delta mag, very clean image with seeing |
Mark McCarthy
317mm (553x) |
White near equal, ~2", nice. |
HZG8, 51 UMa |
AC |
6m.0 |
7m.6 |
150.1" |
83° |
2017 |
UMa |
11h04m31.28s / +38°14'28.90" |
Mark McCarthy
317mm (553x) |
Very wide separation 1.5" mag. This is AC of 51 UMa, AB is Ho 377 which is 6.04,11.60 and 8.2" |
HO49 |
8m.4 |
11m.6 |
7.5" |
356° |
2015 |
UMa |
11h04m46.60s / +56°59'31.80" |
Mark McCarthy
178mm (205x) |
White A and faint B which appears consistently with averted vision, but I can't hold it direct even with foveal coaxing. Well separated, 2 delta mag. Physical |
HO378 |
AB |
8m.2 |
9m.1 |
1.1" |
237° |
2017 |
UMa |
11h04m57.29s / +38°24'38.20" |
Mark McCarthy
317mm (553x) |
In a pretty cluster in the finder (~ 12 stars loose and poor, wide magnitude range, triangle shape). Pair is a fine split 1 delta mag 1", ice blue A and slightly yellow B. |
KUI54, chi Leo |
AB |
4m.7 |
11m.0 |
4.9" |
268° |
2018 |
Leo |
11h05m01.02s / +07°20'09.60" |
Mark McCarthy
178mm (205x) |
Nice! B is a tiny sharp point separated pretty well from bright A |
A2378 |
9m.9 |
9m.8 |
0.4" |
140° |
2017 |
Leo |
11h05m20.40s / +16°35'21.40" |
Mark McCarthy
508mm (533x) |
Split with seeing, near equal, white |
WX UMa |
VBS18 |
AB |
8m.8 |
14m.6 |
32.0" |
125° |
2017 |
UMa |
11h05m27.65s / +43°31'38.70" |
CSN7 |
AC |
4m.8 |
7m.5 |
7.3" |
168° |
2003 |
Robert Zebahl
Leipzig (Germany) |
70mm (100x) |
AC: 31.03.2020: Bei Vergrößerungen zwischen 22x und 100x nicht identifizierbar. WX UMa (Komponente A?) ist ein Veränderlicher (b14m2-16m53) und wohl zu schwach. |
STF1505 |
AB |
8m.9 |
10m.6 |
8.2" |
312° |
2015 |
UMa |
11h05m41.23s / +62°37'01.50" |
AC |
8m.9 |
12m.0 |
217.7" |
177° |
2015 |
Robert Zebahl
Leipzig (Germany) |
70mm (80x) |
AB: 14.04.2020: Trennung einfach mit ziemlich schwachem Begleiter. |
Mark McCarthy
178mm (205x) |
AB: Very light orange A, and faint B can just hold direct vision, brightens with averted vision, well split, 2 delta mag. Physical |
STF1507 |
8m.8 |
10m.2 |
8.5" |
165° |
2016 |
Leo |
11h06m07.42s / +07°02'00.50" |
Mark McCarthy
178mm (205x) |
2 delta mag, pretty wide. Physical, unusual for one so wide |
BU599, 65 Leo |
5m.7 |
9m.7 |
2.8" |
106° |
2015 |
Leo |
11h06m54.20s / +01°57'19.90" |
Mark McCarthy
178mm (333x) |
A is a very light orange, and when seeing stills and the diffraction rings are steady, B appears as the tiniest fleck, well outside the first ring about 3", a deeper duller orange color. Physical. Burnham discovered with the 18.5-inch Washburn refractor at 1.8" -- his extra aperture helped as mine is wider but with just a 7-inch, and explains why Struve never saw it. He wrote: "It is obvious from the measures that this belongs also to the small star, and they must form a physical system." |
Mark McCarthy
317mm (553x) |
Bright light orange star. As seeing resolves it to a disk and eliminates the diffraction, a tiny, faint star appears, planet-like, (~3") from the star. Only at the best moments, visibility of B star helped by averted vision. |
STF1511 |
9m.3 |
9m.5 |
7.6" |
287° |
2015 |
Leo |
11h07m11.56s / +10°54'48.20" |
Mark McCarthy
203mm (205x) |
Plain white pair, near equal, wide |
STF1510 |
7m.7 |
9m.0 |
5.7" |
328° |
2019 |
UMa |
11h08m00.06s / +52°49'17.90" |
René Merting
100mm (64x) |
bei 32x wirkt der Stern leicht länglich - bei 64x dann gelingt die Trennung - Komponente B hängt nordwestlich über A und ist mehr als eine Größenklasse schwächer - ein schönes enges Paar bei dieser Vergrößerung - B wirkt trotz des Größenunterschiedes nicht so schmutzig grau, wie es sonst immer ist |
Mark McCarthy
178mm (205x) |
>1 delta mag, wide pair. Physical with a 3156.3519-year period |
STF1512 |
9m.3 |
9m.5 |
9.9" |
51° |
2015 |
UMa |
11h09m13.09s / +62°29'51.00" |
Mark McCarthy
178mm (205x) |
Mark McCarthy
317mm (553x) |
Pretty, near equal bluish-white stars |
MLB408 |
AB |
9m.2 |
10m.9 |
8.0" |
348° |
2015 |
UMa |
11h10m45.23s / +64°42'44.50" |
Mark McCarthy
178mm (205x) |
Faint B seen with averted vision only, wide, 1 delta mag |
STF1514 |
9m.5 |
10m.6 |
1.3" |
341° |
2015 |
UMa |
11h11m38.55s / +66°06'48.00" |
Mark McCarthy
317mm (553x) |
Extremely fine! It is at the base of a kite asterism, the fainter star of four. The three arcing the top of the kite are equal magnitude. STF 1514 is a very tight 1.5" but clean split, 1 delta mag. Nice! |
ENG45 |
AB |
7m.2 |
8m.3 |
135.0" |
247° |
2016 |
UMa |
11h11m48.95s / +42°49'55.60" |
Mark McCarthy
80mm (13x) |
Finder split, white, 0.5 delta mag. |
HO50 |
6m.5 |
8m.4 |
3.0" |
35° |
2017 |
UMa |
11h13m40.09s / +41°05'19.80" |
Mark McCarthy
178mm (205x) |
Cream white A and can see B nicely separated, about 3". Used averted vision at first to see B, then could hold direct after foveal coaxing |
Mark McCarthy
762mm (457x) |
The pair split immediately at 457x. A little diffraction but no doubt a small blue point just outside the first ring. Using the 8-inch aperture mask (effectively 8-inch f/18!) had a nice star image of A but B disappeared -- it became an averted vision, threshold object. Barlow here was no help to show it better. I think Ho 50B is fainter than the current data, and if the older data say it should be fainter, then it may well be variable. However, later in the night, I estimated Ho 50B to be as bright as STF 1964D, which is 9.02 |
STF1517 & BU1431 |
STF1517 |
AB |
7m.5 |
8m.0 |
0.7" |
314° |
2017 |
Leo |
11h13m40.99s / +20°07'43.30" |
BU1431 |
AB-C |
7m.5 |
10m.8 |
246.1" |
97° |
2015 |
Sarah Gebauer
Germany |
100mm (200x) |
STF1517 (AB): die Komponenten AB und C lassen sich natürlich problemlos bei geringer Vergrößerung trennen, für A und B reichen auch 200x nicht aus (Beobachtungsversuch erfolgte ohne vorherige Recherche, denn 0,7'' schafft mein Refraktor nicht) |
Robert Zebahl
Leipzig (Germany) |
102mm (187x) |
STF1517 (AB): 28.03.2020: Der Doppelstern erscheint sofort länglich. Bei genauem Hinsehen konnte der geringe Helligkeitsunterschied erkannt werden. Eine Einschnürung war nicht sichtbar. Höhere Vergrößerungen brachten keinen Gewinn. Beobachtung bei recht ruhiger Luft (4/5). |
Uwe Pilz
Leipzig (Germany) |
105mm (200x) |
STF1517 (AB): länglich |
Robert Zebahl
Leipzig (Germany) |
152mm (225x) |
STF1517 (AB): 27.03.2020: Deutlich länglich. In ruhigeren Momenten war eine Einkerbung sowie ein geringer Helligkeitsunterschied erkennbar. Beobachtung bei mäßig ruhiger Luft (3/5). |
Mark McCarthy
Fremont (California/USA) |
317mm (340x) |
STF1517 (AB): Very tight, hair split small orange stars of equal magnitude. Wow! |
Mark McCarthy
508mm (533x) |
STF1517 (AB): Touching disks with 333x, clean slit with 533x, ~0.5" separation, Yellow-orange stars, near equal |
delta Leo, 68 Leo, Duhr, Zubra, Zosma |
STT573 |
AB |
2m.5 |
10m.9 |
202.7" |
341° |
2014 |
Leo |
11h14m06.51s / +20°31'25.80" |
BU1282 |
AC |
2m.5 |
12m.7 |
95.5" |
31° |
2014 |
DAL35 |
AD |
2m.5 |
13m.3 |
44.8" |
38° |
2014 |
Uwe Pilz
Leipzig (Germany) |
50mm (9x) |
AB: Begleiter wirkt wie ein Feldstern im Sucher |
René Merting
100mm (32x) |
AB: bei 32x habe ich zunächst den 9.7 mag hellen Stern SAO 81724 westnordwestlich für Komponente B gehalten - Komponente B habe ich auch gesehen, sie aber für einen weitere Komponenten gehalten - B stand nur 1/3 soweit nördlich von A und ist noch schwächer - Helligkeitsunterschied nicht abschätzbar - der Doppelstern ist kein Burner |
René Merting
320mm (72x) |
AB: bei 72x nicht wirklich eine Freude - Komponente B steht zu weit entfernt nordöstlich von A - ein grauer Minikleks gegen den gleißend hellen weißen Stern Zosma (Delta Leo) |
STF1518 |
BC |
11m.3 |
11m.5 |
3.5" |
354° |
2018 |
Leo |
11h14m22.54s / +05°15'25.40" |
Mark McCarthy
508mm (205x) |
A is light orange color, wide BC appears as a smear with the 7-inch mask but is a well split pair of near equal blue stars with 20-inches, ~3". Nice pair |
BU1283 |
9m.8 |
10m.4 |
0.3" |
174° |
2010 |
